steering pump - worth fixing or buy new ? #1026892
07/05/11 09:31 PM
07/05/11 09:31 PM
SE Mi
U
use2teech Offline OP
U
SE Mi
Putting in the 440 and hooked up steering lines, filled and now leaks out of the resevoir....steady drip. I have the pump pictured. It's either cmoning out of the shaft or the housing itself....at the botton. Any one tried to fix these or should I just buy new ? BTW....any one know what model pump it is if I have to buy new....
Re: steering pump - worth fixing or buy new ? [Re: use2teech] #1026893
07/05/11 09:46 PM
07/05/11 09:46 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
You should be able to buy the seals to fix it, and it should be way cheaper than buying a new pump.
There are two types of PS pumps, the Federal and the Saginaw(?), and that looks like the Federal version.
Re: steering pump - worth fixing or buy new ? [Re: Neil] #1026894
07/06/11 03:17 AM
07/06/11 03:17 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Its either a federal or TRW, do a search and you will find out which pump and kit you need. Tim
Re: steering pump - worth fixing or buy new ? [Re: use2teech] #1026895
07/06/11 08:38 AM
07/06/11 08:38 AM
St Charles MO
70Coronet500Vert Offline
St Charles MO
I have that exact pump and reservoir. They do not make an exact replacement. I am having mine rebuilt through the service at Rockauto.
All replacement reservoirs I have foud do not have the large return line and the two mounting bols on the rer are not there, only one.
No matter how responsible he may seem, never give your gun to a monkey!
1970 Coronet Vert
1972 Charger
1974 Satellite Sebring Plus Sundance
2001 Ram 4x4
2002 Intrepid
2006 300C
Re: steering pump - worth fixing or buy new ? [Re: 70Coronet500Vert] #1026896
07/06/11 10:56 AM
07/06/11 10:56 AM
Andrewh Offline
Andrewh  Offline
the few that I have had leak, were just the big o ring around the resevior.
I only replaced that and the gasket at the back, and they worked fine.
Re: steering pump - worth fixing or buy new ? [Re: Andrewh] #1026897
07/06/11 11:00 PM
07/06/11 11:00 PM
SE Mi
U
U
SE Mi
Thanks for the response. Agree that it's not a saginaw ? Any idea on where to pick up seals for this ?
Re: steering pump - worth fixing or buy new ? [Re: use2teech] #1026898
07/07/11 01:10 AM
07/07/11 01:10 AM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
It's not a Saginaw. I got my last pump seal kit from Napa a few months back
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
