steering pump - worth fixing or buy new ?
#1026892
07/05/11 09:31 PM
07/05/11 09:31 PM
Posts: 87 SE Mi
use2teech
SE Mi
Putting in the 440 and hooked up steering lines, filled and now leaks out of the resevoir....steady drip. I have the pump pictured. It's either cmoning out of the shaft or the housing itself....at the botton. Any one tried to fix these or should I just buy new ? BTW....any one know what model pump it is if I have to buy new.... Thanks
Re: steering pump - worth fixing or buy new ?
[Re: use2teech]
#1026895
07/06/11 08:38 AM
07/06/11 08:38 AM
Posts: 8,430 St Charles MO
70Coronet500Vert
St Charles MO
I have that exact pump and reservoir. They do not make an exact replacement. I am having mine rebuilt through the service at Rockauto.
All replacement reservoirs I have foud do not have the large return line and the two mounting bols on the rer are not there, only one.
No matter how responsible he may seem, never give your gun to a monkey! 1970 Coronet Vert 1972 Charger 1974 Satellite Sebring Plus Sundance 2001 Ram 4x4 2002 Intrepid 2006 300C
