loose AT column shift lever (68 satellite) #1026801
07/05/11 07:53 PM
07/05/11 07:53 PM
L.A., CA
P
plysat Offline OP
plysat  Offline OP
P
L.A., CA
This has bugged me for 20 years and since I'm currently in "fix stuff" mode, maybe I should tackle it... The column shift lever (auto trans) doesn't engage very well. The spring works but, for instance, when it's in reverse it sort of falls down out of position and the backup lights go off. To keep 'em on I have to hold the lever up a bit. Is there some sort of gate, detents or something in there that's worn? Weak spring that should pull it back harder? And, more importantly, is this a can of worms worth opening? I have a service manual, but even that is kind of vague as to what's in there. Any clues for me? Thanks!
Re: loose AT column shift lever (68 satellite) [Re: plysat] #1026802
07/06/11 02:05 PM
07/06/11 02:05 PM
L.A., CA
P
plysat Offline OP
plysat  Offline OP
P
L.A., CA
heh... must be more complicated than I thought.
Re: loose AT column shift lever (68 satellite) [Re: plysat] #1026803
07/06/11 02:12 PM
07/06/11 02:12 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
Might be worn plastic bushings in the shift linkage. There used to be some NOS bushings on eBay for sale?
Re: loose AT column shift lever (68 satellite) [Re: CompSyn] #1026804
07/06/11 02:26 PM
07/06/11 02:26 PM
L.A., CA
P
plysat Offline OP
plysat  Offline OP
P
L.A., CA
The bushings on the firewall end of the column seem to be OK, are there bushings or something in the column I should look at?
Re: loose AT column shift lever (68 satellite) [Re: plysat] #1026805
07/06/11 02:29 PM
07/06/11 02:29 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Must be, have you tried readjusting the linkage ? there aren't really any detents in the column , the shift detents are in the trans ...
Re: loose AT column shift lever (68 satellite) [Re: JohnRR] #1026806
07/06/11 02:37 PM
07/06/11 02:37 PM
L.A., CA
P
plysat Offline OP
plysat  Offline OP
P
L.A., CA
I'll check it again... It's been sloppy like that since I've owned the car, the trans was just rebuilt and there's no change. I was wondering about the column because it's not slipping out of gear, just the shift lever doesn't stay where it should. The only thing that sucks is in R when the lever slips down towards N and the reverse lights go off. Where's the spring that pulls the shift lever back?
Re: loose AT column shift lever (68 satellite) [Re: plysat] #1026807
07/06/11 02:42 PM
07/06/11 02:42 PM
JohnRR Offline
JohnRR  Offline
It's a good idea to readjust the linkage when the linkage is pulled off the car , which is would have been when the trans was dropped.
Re: loose AT column shift lever (68 satellite) [Re: JohnRR] #1026808
07/06/11 03:30 PM
07/06/11 03:30 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
There is a coil spring in the column that puts tension on the shift lever. That is why you have to pull the lever towards you to go from Park to any gear. It sounds like yours may be weak or missing. You may have other factors that are also contributing to that sloppy feel, like worn linkage bushings, missing washers under the linkage clips, etc. that all combine to contribute to a loose feel. I wish Lokar made a replacement cable that would eliminate all of the pivoting linkage in between the column and the valve body like they do for GM and Ford !
Re: loose AT column shift lever (68 satellite) [Re: Lee446] #1026809
07/06/11 05:51 PM
07/06/11 05:51 PM
L.A., CA
P
plysat Offline OP
plysat  Offline OP
P
L.A., CA
A cable would be nice... The spring is still there, but I think you're right, probably weakened over the years... Guess I need to tear into the column Or, just live with it for another 20 years
Re: loose AT column shift lever (68 satellite) [Re: plysat] #1026810
07/22/11 07:10 AM
07/22/11 07:10 AM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
Could be these, or if not you could replace them anyway: http://cgi.ebay.com/ebaymotors/Mopar-NOS...sQ5fAccessories
