Re: loose AT column shift lever (68 satellite)
[Re: plysat]
#1026805
07/06/11 02:29 PM
07/06/11 02:29 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
heh... must be more complicated than I thought.
Must be, have you tried readjusting the linkage ? there aren't really any detents in the column , the shift detents are in the trans ...
[Re: JohnRR]
#1026806
07/06/11 02:37 PM
07/06/11 02:37 PM
Posts: 252 L.A., CA
plysat
L.A., CA
I'll check it again... It's been sloppy like that since I've owned the car, the trans was just rebuilt and there's no change. I was wondering about the column because it's not slipping out of gear, just the shift lever doesn't stay where it should. The only thing that sucks is in R when the lever slips down towards N and the reverse lights go off. Where's the spring that pulls the shift lever back?
[Re: plysat]
#1026807
07/06/11 02:42 PM
07/06/11 02:42 PM
JohnRR
U.S.S.A.
It's a good idea to readjust the linkage when the linkage is pulled off the car , which is would have been when the trans was dropped.
[Re: Lee446]
#1026809
07/06/11 05:51 PM
07/06/11 05:51 PM
Posts: 252 L.A., CA
plysat
L.A., CA
There is a coil spring in the column that puts tension on the shift lever. That is why you have to pull the lever towards you to go from Park to any gear. It sounds like yours may be weak or missing. You may have other factors that are also contributing to that sloppy feel, like worn linkage bushings, missing washers under the linkage clips, etc. that all combine to contribute to a loose feel. I wish Lokar made a replacement cable that would eliminate all of the pivoting linkage in between the column and the valve body like they do for GM and Ford !
A cable would be nice... The spring is still there, but I think you're right, probably weakened over the years... Guess I need to tear into the column Or, just live with it for another 20 years
