Took A Break #1026363
07/05/11 11:22 AM
07/05/11 11:22 AM
MR_P_BODY Offline OP
Well I took a break from working on the Rampage last
week and went up to my other place... just to relax
and let the brain cool off.... now I need to pull the
W-2 thats in the race car and put the W-9 back in...
I need a couple of parts off of the W-2 so I can build
a duplicate set(alt mount and the motor plate) I need
the water pump off of it also to make sure I clear
the radiator on the Rampage......... does it ever
end so I guess thats what I'll do tomorrow
Re: Took A Break [Re: MR_P_BODY] #1026364
07/05/11 11:48 AM
07/05/11 11:48 AM
Az
Crizila Offline
Crizila  Offline
Az
Taking a break is good. When it ends, that's a bad sign.
Fastest 300
Re: Took A Break [Re: Crizila] #1026365
07/05/11 12:27 PM
07/05/11 12:27 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
It's good to let the brain cool off every once in awhile; sometimes it helps devise a better or more elegant solution to a problem.
Plus, it means you have time to answer questions and provide input on my build!
Re: Took A Break [Re: MR_P_BODY] #1026366
07/05/11 01:33 PM
07/05/11 01:33 PM
Super Scamp Offline
Super Scamp  Offline
The Honey Do List never ends If it does you might as well stay up north and play with your Fishin Pole..
Just One Man's Opinion Mopar Mafia Racing
Re: Took A Break [Re: MR_P_BODY] #1026367
07/05/11 03:06 PM
07/05/11 03:06 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
Mike, isn’t retirement great? I’m so busy now; I often wonder how I found time to go to work before I retired. About once a month I take one day and just set around, do nothing and relax.
Re: Took A Break [Re: Dabee] #1026368
07/05/11 03:09 PM
07/05/11 03:09 PM
Guitar Jones Offline
I take lots of breaks, I'm old.
Re: Took A Break [Re: Guitar Jones] #1026369
07/05/11 03:37 PM
07/05/11 03:37 PM
Well for the time being I stole the water pump off
my W-9 and found something to simulate the 3/8" motor
plate.... I have a TON of room between the water pump
and the radiator/fan.... about .150 clearance... I knew
it was gonna be close but I wanted to make sure...
I get a couple of pics later today and post them on
my Drag Week build post
Re: Took A Break [Re: MR_P_BODY] #1026370
07/05/11 03:51 PM
07/05/11 03:51 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
THE LIFE of a retired CTC worker .... with a hefty "check" ...
MUST be nice ... !
Re: Took A Break [Re: dOc !] #1026371
07/05/11 04:04 PM
07/05/11 04:04 PM
MUST be nice ... !
Well the check use to be nicer.... not as much now days
Re: Took A Break [Re: MR_P_BODY] #1026372
07/05/11 04:57 PM
07/05/11 04:57 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Yikes, a WHOLE .150 clearance?!
Re: Took A Break [Re: MR_P_BODY] #1026373
07/05/11 05:11 PM
07/05/11 05:11 PM
Lehigh Acres, Florida
rickstershemi Offline
You'll get no sympathy here....lol How's the tractor running...???
Rickster
Re: Took A Break [Re: MR_P_BODY] #1026374
07/05/11 05:17 PM
07/05/11 05:17 PM
Still better than a sharp stick in the eye.
Re: Took A Break [Re: topside] #1026375
07/05/11 05:18 PM
07/05/11 05:18 PM
Thats not bad at all when working on small cars, thats
without grinding any clearance... here is the area
that I was concerned with
Rick.... the tractor was running fine
Re: Took A Break [Re: Guitar Jones] #1026376
07/05/11 05:23 PM
07/05/11 05:23 PM
Yes it is but I lost alot of my medical since I
retired... I dont know why Doc is so concerned with
my retirement check.... I was there 35 years so I think
it was deserved
Re: Took A Break [Re: MR_P_BODY] #1026377
07/05/11 05:25 PM
07/05/11 05:25 PM
Re: Took A Break [Re: MR_P_BODY] #1026378
07/05/11 05:50 PM
07/05/11 05:50 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
I am not "concerned" P ....I beeez jealous
Re: Took A Break [Re: dOc !] #1026379
07/05/11 05:55 PM
07/05/11 05:55 PM
All you had to do Doc was work there for 35 years
and you would have got one also... then you would
be pissed also when they take part of the medical away
Re: Took A Break [Re: MR_P_BODY] #1026380
07/05/11 06:02 PM
07/05/11 06:02 PM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
That COULD have been REALITY if I had followed-up the job interview I had with both Al Adams and Ron Mancini in the trans-lab with a simple phone call way-back-when ..
But THEN my life would have been a whole-lot-diff ...
Re: Took A Break [Re: dOc !] #1026381
07/05/11 06:31 PM
07/05/11 06:31 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Looks like you could move the radiator to the right a bit and gain some clearance between the shroud & pump. Can't tell what that projection on the shroud is, or if it could be trimmed, but I'm sure you'd be doing that already if you could. Or maybe change the angle of the radiator, or drop it down a bit?
Re: Took A Break [Re: topside] #1026382
07/05/11 07:20 PM
07/05/11 07:20 PM
I can trim the plastic on the fan brackets but it
doesnt need it... there's plenty of room... plus
I'll put a strut from the front of the engine to the
top of the radiator to help hold it so it might end
up with a touch more clearance
