Took A Break
#1026363
07/05/11 11:22 AM
07/05/11 11:22 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Well I took a break from working on the Rampage last week and went up to my other place... just to relax and let the brain cool off.... now I need to pull the W-2 thats in the race car and put the W-9 back in... I need a couple of parts off of the W-2 so I can build a duplicate set(alt mount and the motor plate) I need the water pump off of it also to make sure I clear the radiator on the Rampage......... does it ever end so I guess thats what I'll do tomorrow
Re: Took A Break
[Re: Dabee]
#1026368
07/05/11 03:09 PM
07/05/11 03:09 PM
Guitar Jones
I take lots of breaks, I'm old.
Re: Took A Break
[Re: Guitar Jones]
#1026369
07/05/11 03:37 PM
07/05/11 03:37 PM
MR_P_BODY
Well for the time being I stole the water pump off my W-9 and found something to simulate the 3/8" motor plate.... I have a TON of room between the water pump and the radiator/fan.... about .150 clearance... I knew it was gonna be close but I wanted to make sure... I get a couple of pics later today and post them on my Drag Week build post
Re: Took A Break
[Re: dOoC]
#1026371
07/05/11 04:04 PM
07/05/11 04:04 PM
MR_P_BODY
THE LIFE of a retired CTC worker .... with a hefty "check" ...
MUST be nice ... !
Well the check use to be nicer.... not as much now days
Re: Took A Break
[Re: MR_P_BODY]
#1026373
07/05/11 05:11 PM
07/05/11 05:11 PM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
You'll get no sympathy here....lol How's the tractor running...???
Rickster
Re: Took A Break
[Re: MR_P_BODY]
#1026374
07/05/11 05:17 PM
07/05/11 05:17 PM
Guitar Jones
Still better than a sharp stick in the eye.
Re: Took A Break
[Re: topside]
#1026375
07/05/11 05:18 PM
07/05/11 05:18 PM
MR_P_BODY
Yikes, a WHOLE .150 clearance?!
Thats not bad at all when working on small cars, thats without grinding any clearance... here is the area that I was concerned with
Rick.... the tractor was running fine
Re: Took A Break
[Re: Guitar Jones]
#1026376
07/05/11 05:23 PM
07/05/11 05:23 PM
MR_P_BODY
Yes it is but I lost alot of my medical since I retired... I dont know why Doc is so concerned with my retirement check.... I was there 35 years so I think it was deserved
Re: Took A Break
[Re: MR_P_BODY]
#1026377
07/05/11 05:25 PM
07/05/11 05:25 PM
Guitar Jones
Re: Took A Break
[Re: MR_P_BODY]
#1026378
07/05/11 05:50 PM
07/05/11 05:50 PM
Posts: 30,451 Florida STAYcation
dOoC
The village idiot's idiot
Florida STAYcation
I am not "concerned" P ....I beeez jealous
Re: Took A Break
[Re: dOoC]
#1026379
07/05/11 05:55 PM
07/05/11 05:55 PM
MR_P_BODY
All you had to do Doc was work there for 35 years and you would have got one also... then you would be pissed also when they take part of the medical away
Re: Took A Break
[Re: MR_P_BODY]
#1026380
07/05/11 06:02 PM
07/05/11 06:02 PM
dOoC
Florida STAYcation
That COULD have been REALITY if I had followed-up the job interview I had with both Al Adams and Ron Mancini in the trans-lab with a simple phone call way-back-when ..
But THEN my life would have been a whole-lot-diff ...
Re: Took A Break
[Re: topside]
#1026382
07/05/11 07:20 PM
07/05/11 07:20 PM
MR_P_BODY
Looks like you could move the radiator to the right a bit and gain some clearance between the shroud & pump. Can't tell what that projection on the shroud is, or if it could be trimmed, but I'm sure you'd be doing that already if you could. Or maybe change the angle of the radiator, or drop it down a bit?
I can trim the plastic on the fan brackets but it doesnt need it... there's plenty of room... plus I'll put a strut from the front of the engine to the top of the radiator to help hold it so it might end up with a touch more clearance
