crane gold roller tip rockers-when??? #1026162
07/04/11 11:23 PM
07/04/11 11:23 PM
illinois
rbkt65 Offline OP
rbkt65  Offline OP
illinois
when will the new big block roller tip rockers be out??heard June 1 now July 1 now Aug 1-does anybody know when for sure-thanks in advance
Re: crane gold roller tip rockers-when??? [Re: rbkt65] #1026163
07/05/11 08:35 AM
07/05/11 08:35 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Why would we know? Call them directly and ask.
Re: crane gold roller tip rockers-when??? [Re: rbkt65] #1026164
07/05/11 10:28 AM
07/05/11 10:28 AM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
I am going to let Chase explain this one.... ...it wasnt quite cut and dry.
PM me if you need some.
RIP Monte Smith
Re: crane gold roller tip rockers-when??? [Re: CompWedgeEngines] #1026165
07/05/11 03:37 PM
07/05/11 03:37 PM
Daytona Beach, FL
cknight Offline
cknight  Offline
Daytona Beach, FL
The standard offset type rocker kits 64790-1 (1.5:1 ratio), and 64791-1 (1.6:1 ratio) are currently in stock. The 64792-1 (1.5)and 64793-1 (1.6) kits with the .290" offset Stage IV type intakes are about a month away, as we're currently manufacturing the intake rockers. Regards, Chase
Re: crane gold roller tip rockers-when??? [Re: Challenger 1] #1026166
07/05/11 04:00 PM
07/05/11 04:00 PM
organ
maximum entropy Offline
organ
because we are the great and powerful. the all knowing. the omniscient. silly.
Re: crane gold roller tip rockers-when??? [Re: maximum entropy] #1026167
07/05/11 11:56 PM
07/05/11 11:56 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Looking at the pic on Summit's website, no fulcrum bushing or rollers are visible; also no adjuster. Says "full roller", & "includes shafts", but no mention of hold-downs, fasteners, spacers or ball/cup adjusters. Priced at $536.95.
Someone at Crane should probably ask Summit to provide a better explanation & photos, if only to reduce the # of phone calls. Depending on what one gets with the kit, I could either be a customer or buy another kit from Harland Sharp.
Re: crane gold roller tip rockers-when??? [Re: topside] #1026168
07/06/11 01:48 AM
07/06/11 01:48 AM
Renton Wa
topfueldart Offline
topfueldart  Offline
Renton Wa
How about SB versions?
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
Re: crane gold roller tip rockers-when??? [Re: topfueldart] #1026169
07/06/11 10:06 AM
07/06/11 10:06 AM
Daytona Beach, FL
cknight Offline
cknight  Offline
Daytona Beach, FL
The small block LA 69790-1 (1.5:1 ratio) amd 69791-1 (1.6:1 ratio) aluminum rocker arm kits are currently in stock at Crane. The aluminum rockers run directly on the shafts. The LA and B/RB aluminum kits contain roller tip rocker arms with ball-type adjusting screws and locknuts, new heavy wall heat-treated centerless ground shafts, spacers (or springs), side thrust shims, and assembly lube. No hold-downs, or shaft fastening hardware, are included. Regards, Chase
Re: crane gold roller tip rockers-when??? [Re: topside] #1026170
07/06/11 10:09 AM
07/06/11 10:09 AM
long time lurker, short time p...
P
PorkyPig Offline
PorkyPig  Offline
P
Unless Crane is changing their parts (and IMO there is room for improvement), what you can expect from a "kit" is rockers, adjuster screws and nuts, shafts, springy-thingies to separate the rockers and shims to stick in between the springy-thingies and the rockers. No hold downs or other hardware.
Are they really over $500 now? Maybe I'm getting old because I remember when they were about $300. For $500 I'd be looking for different rockers.
Re: crane gold roller tip rockers-when??? [Re: PorkyPig] #1026171
07/06/11 10:45 AM
07/06/11 10:45 AM
Daytona Beach, FL
cknight Offline
cknight  Offline
Daytona Beach, FL
The current retail price of the aluminum rocker arm kits did increase. The major improvement has been to the shafts themselves. Instead of the former stock replacement grade pieces, these are now a much higher quality item as described previously. Regards, Chase
Re: crane gold roller tip rockers-when??? [Re: cknight] #1026172
07/06/11 10:54 AM
07/06/11 10:54 AM
Daytona Beach, FL
cknight Offline
cknight  Offline
Daytona Beach, FL
FWIW the retail price of these rocker kits was $322.00 in 1975. Chase
Re: crane gold roller tip rockers-when??? [Re: cknight] #1026173
07/06/11 01:22 PM
07/06/11 01:22 PM
P
PorkyPig Offline
PorkyPig  Offline
P
Understood, but the street price (mail order houses, Mancini Racing, etc.) was still under $350 for the kits as recently as around ten years ago.
Nobody remembers "retail" in this hobby / business anymore, which I know you know as long as you've been in the industry.
Re: crane gold roller tip rockers-when??? [Re: PorkyPig] #1026174
07/06/11 02:21 PM
07/06/11 02:21 PM
Daytona Beach, FL
cknight Offline
cknight  Offline
Daytona Beach, FL
I was comparing today's retail price (which is basically what you had stated) to the 1975 retail. What they are actually sold (not just especially what they're advertised for) certainly varies. Just do a Google Shopping search, and check the variations. Thanks, Chase
