What's your favorite street/strip battery? #1025863
07/04/11 06:06 PM
07/04/11 06:06 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
What's your favorite street/strip battery for a car with an electric fuel pump, electric water pump, and an electric fan? My car has 13.8 volts with everything running and is still draining my Autozone Duralast Gold 800 CCA battery.
I'm thinking a red top battery may be the best bet but really can not spend $180+ dollars on a battery right now. Anything affordable out there?
Re: What's your favorite street/strip battery? [Re: ProSport] #1025864
07/04/11 07:07 PM
07/04/11 07:07 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`ve had great luck w/my Orbital gel batteries from Kragens one lasted me 7 years and the 2nd one is going on 5+ years iirc.
Re: What's your favorite street/strip battery? [Re: Thumperdart] #1025865
07/04/11 07:33 PM
07/04/11 07:33 PM
glendora, ca.
Deepockets Offline
Deepockets  Offline
glendora, ca.
you're going to get a lot of opinions here. too me it boils down to weight. the more lead you have, the better it will be. i've used them all. i tend to like the interstate batterys that have divisions in them to keep the lead plates from ever touching with severe use. also if you have to hot charge between rounds, i believe the acid filled batterys will last longer. the AGM batteries have no acid or level that need to be maintained, so it's just what the mat has absorbed. it will cook off quicker in the long run if hot charging. all in all, there all pretty dam good. thats my 10 cents.
Re: What's your favorite street/strip battery? [Re: Deepockets] #1025866
07/04/11 07:34 PM
07/04/11 07:34 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
optima red here no prob's
Re: What's your favorite street/strip battery? [Re: fishy340] #1025867
07/04/11 07:54 PM
07/04/11 07:54 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
X2 ... so far!
Mopar Performance
Re: What's your favorite street/strip battery? [Re: ProSport] #1025868
07/04/11 08:09 PM
07/04/11 08:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Not the battery... you better look at the alt or wiring...
the battery is nothing but a holding tank.... unless
it wont take a charge.... at Chrysler looked into
the Optima batteries for production but found they
werent that good
Re: What's your favorite street/strip battery? [Re: MR_P_BODY] #1025869
07/04/11 08:42 PM
07/04/11 08:42 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Pbody, I had the car checked on a machine with the car running and everything turned on including the headlights and it seems to be charging fine. Just seems that after cruising to a few places a day the battery gets weak and eventually hard starts. The guy at the shop said he thinks it's just the battery not holding a charge very well. Actually, if it sits in the garage for a week w/o being charged or driven it hard starts, won't turn over fast enough to start.
Re: What's your favorite street/strip battery? [Re: ProSport] #1025870
07/04/11 08:47 PM
07/04/11 08:47 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Well if it doesnt have a small draw on it then ihe
battery has a weak or dead cell so it cant hold the
charge... did he do a load test on the battery...
that would have shown a battery issue
Re: What's your favorite street/strip battery? [Re: ProSport] #1025871
07/04/11 08:49 PM
07/04/11 08:49 PM
Big Western Pencilveinya
U
Uncle Barry Offline
Uncle Barry  Offline
U
try another battery. if your car still does what you are saying it does, more than likely its in your wiring or alternator. i agree with mr p.
Re: What's your favorite street/strip battery? [Re: ProSport] #1025872
07/04/11 08:57 PM
07/04/11 08:57 PM
Idaho
Runner Offline
Runner  Offline
Idaho
i had the exact same problem after i upgraded my fan to the hhr fan. i tried the optima red top and hated it. made the situation worse just didnt have any reserve capacity. i thought seriously about going with 2 batteries but i decided to first try a new march crank pully that was 6.5 inches in diameter instead of the underdrive pully that was 5.25. the pulley has fixed the problem. in a street car with an underdrive pulley i just spent to much time at lower rpm where the powermaster alternator wasnt charging. i used to have to jump start the car if it didnt fire right up but now i can crank it for a good while cause the battery stays fully charged ( diehard gold)
Re: What's your favorite street/strip battery? [Re: Uncle Barry] #1025873
07/04/11 09:00 PM
07/04/11 09:00 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
My drag car runs 2 800amp regular batteries in the trunk & a 1-wire GM alternator. No problems.
Electric fan, water pump & vac pump and MSD6. Headlights if racing @ night.
Re: What's your favorite street/strip battery? [Re: MR_P_BODY] #1025874
07/04/11 09:00 PM
07/04/11 09:00 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
I already ditched the 5" crank pulley for the larger March pulley a couple years ago.
I'm not sure how many tests were done on the battery. Butch sent me home with a battery to try so I'll be doing that today or tomorrow.
Re: What's your favorite street/strip battery? [Re: topside] #1025875
07/04/11 09:01 PM
07/04/11 09:01 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
I've considered that also, 2 good batteries wired together properly.
Re: What's your favorite street/strip battery? [Re: ProSport] #1025876
07/04/11 09:15 PM
07/04/11 09:15 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
My car likes ballast anyway, so it's been a win/win.
Re: What's your favorite street/strip battery? [Re: topside] #1025877
07/04/11 10:03 PM
07/04/11 10:03 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I run Interstate batteries, have one in just about everything I own including the race car, they just work.
Re: What's your favorite street/strip battery? [Re: dartman366] #1025878
07/05/11 12:35 AM
07/05/11 12:35 AM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
Optima red top here and in my dads cars also.
Re: What's your favorite street/strip battery? [Re: Azzkikrcuda] #1025879
07/05/11 03:39 AM
07/05/11 03:39 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I have a 1000 cca group 24 lead acid on my Dart, it's six years old now and still going strong. Not sure who made it, no major brand name, just a local battery store.
Re: What's your favorite street/strip battery? [Re: Azzkikrcuda] #1025880
07/05/11 09:09 AM
07/05/11 09:09 AM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
X2
These work well up north. My lead acid batteries always froze in the winter and died. I have not had one of the red tops go bad yet, and they are pretty small in comparrison and they don't leak any acid onto my paint.
Re: What's your favorite street/strip battery? [Re: ProSport] #1025881
07/05/11 09:34 AM
07/05/11 09:34 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
For something budget friendly....the Johnson Controls manufactured batteries that Wally World sells are good pieces...especially the "upscale" ones with the yellow case.
At least I have had good luck with them.
Rich H.
Esse Quam Videri
Re: What's your favorite street/strip battery? [Re: ZIPPY] #1025882
07/05/11 12:59 PM
07/05/11 12:59 PM
Locomotion Offline
Locomotion  Offline
I've had good luck with Optimas on my race car with a small, 50 amp alternator. But I also charge it between rounds because of the water pump and fan draw on it. I currently have an Odyssey 1500 and have been very happy. (Maybe a 1200, I forgot at the moment.)
As for price, I was told that the Sears Platinum Die-Hard batteries are the same thing as Odyssey, just relabeled, and less expensive. But I haven't been able to confirm it 100%.
