What's your favorite street/strip battery?
#1025863
07/04/11 06:06 PM
07/04/11 06:06 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
What's your favorite street/strip battery for a car with an electric fuel pump, electric water pump, and an electric fan? My car has 13.8 volts with everything running and is still draining my Autozone Duralast Gold 800 CCA battery. I'm thinking a red top battery may be the best bet but really can not spend $180+ dollars on a battery right now. Anything affordable out there?
Re: What's your favorite street/strip battery?
[Re: ProSport]
#1025864
07/04/11 07:07 PM
07/04/11 07:07 PM
Thumperdart
State of confusion
I`ve had great luck w/my Orbital gel batteries from Kragens one lasted me 7 years and the 2nd one is going on 5+ years iirc.
[Re: ProSport]
#1025868
07/04/11 08:09 PM
07/04/11 08:09 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Not the battery... you better look at the alt or wiring... the battery is nothing but a holding tank.... unless it wont take a charge.... at Chrysler looked into the Optima batteries for production but found they werent that good
[Re: MR_P_BODY]
#1025869
07/04/11 08:42 PM
07/04/11 08:42 PM
ProSport
Akron, Ohio
Pbody, I had the car checked on a machine with the car running and everything turned on including the headlights and it seems to be charging fine. Just seems that after cruising to a few places a day the battery gets weak and eventually hard starts. The guy at the shop said he thinks it's just the battery not holding a charge very well. Actually, if it sits in the garage for a week w/o being charged or driven it hard starts, won't turn over fast enough to start.
[Re: ProSport]
#1025870
07/04/11 08:47 PM
07/04/11 08:47 PM
MR_P_BODY
Well if it doesnt have a small draw on it then ihe battery has a weak or dead cell so it cant hold the charge... did he do a load test on the battery... that would have shown a battery issue
[Re: ProSport]
#1025871
07/04/11 08:49 PM
07/04/11 08:49 PM
Posts: 1,070 Big Western Pencilveinya
Uncle Barry
try another battery. if your car still does what you are saying it does, more than likely its in your wiring or alternator. i agree with mr p.
[Re: MR_P_BODY]
#1025874
07/04/11 09:00 PM
07/04/11 09:00 PM
ProSport
Akron, Ohio
I already ditched the 5" crank pulley for the larger March pulley a couple years ago.
I'm not sure how many tests were done on the battery. Butch sent me home with a battery to try so I'll be doing that today or tomorrow.
[Re: topside]
#1025875
07/04/11 09:01 PM
07/04/11 09:01 PM
ProSport
Akron, Ohio
My drag car runs 2 800amp regular batteries in the trunk & a 1-wire GM alternator. No problems. Electric fan, water pump & vac pump and MSD6. Headlights if racing @ night.
I've considered that also, 2 good batteries wired together properly.
[Re: ZIPPY]
#1025882
07/05/11 12:59 PM
07/05/11 12:59 PM
Posts: 5,894 Florida
Locomotion
I've had good luck with Optimas on my race car with a small, 50 amp alternator. But I also charge it between rounds because of the water pump and fan draw on it. I currently have an Odyssey 1500 and have been very happy. (Maybe a 1200, I forgot at the moment.) As for price, I was told that the Sears Platinum Die-Hard batteries are the same thing as Odyssey, just relabeled, and less expensive. But I haven't been able to confirm it 100%.
