Anyone using an adjustable mini starter? #1024929
07/02/11 11:31 PM
07/02/11 11:31 PM
N.Wilkesboro,NC
DusterKrazy Offline OP
N.Wilkesboro,NC
Which one are you using? I believe I will need one for my up coming project.
Re: Anyone using an adjustable mini starter? [Re: DusterKrazy] #1024930
07/02/11 11:33 PM
07/02/11 11:33 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
you mean clockable?
Re: Anyone using an adjustable mini starter? [Re: DJVCuda] #1024931
07/03/11 12:14 AM
07/03/11 12:14 AM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
.....NO POWERMASTER...
If you like drag racing, support your local track.
Re: Anyone using an adjustable mini starter? [Re: CHAPPER] #1024932
07/03/11 12:23 AM
07/03/11 12:23 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
DO NOT WASTE UR TIME ON POWERMASTER OR ANY WITHOUT THE NOSE SNOUT...just go with the mopar mini that comes outta of the dakota...trust me the shim style blow
Re: Anyone using an adjustable mini starter? [Re: fishy340] #1024933
07/03/11 12:36 AM
07/03/11 12:36 AM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
I use a clockable powermaster w/ nose snout on my 408 SB. It hasnt missed a beat its always worked well for me.
Re: Anyone using an adjustable mini starter? [Re: fishy340] #1024934
07/03/11 12:51 AM
07/03/11 12:51 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
100%
Mopar mini on all my motor.even have one on my 600" 16-1 compression no problems
98% of all starter failures I have seen here come from poor alignment and bad mesh with ring gear
home of the
Sox and Martin Hemi Duster
Re: Anyone using an adjustable mini starter? [Re: DJVCuda] #1024935
07/03/11 01:07 AM
07/03/11 01:07 AM
N.Wilkesboro,NC
N.Wilkesboro,NC
you mean clockable?
That's it!
I had the Mopar mini starter installed but it will not clear the steering box on my '41 Dodge truck (original straight axle frame).
So I think the clockable will be my solution. The mini almost gets me by.
Re: Anyone using an adjustable mini starter? [Re: DusterKrazy] #1024936
07/03/11 03:59 AM
07/03/11 03:59 AM
Fort Worth, TX
DMax One Offline
DMax One  Offline
Fort Worth, TX
Might check into this one,
http://www.robbmcperformance.com/products/mopar_starter.html
I haven't ever heard anything bad about them. I plan on geting one when I put my junk back together.
68 Barracuda FB "Exploded View" ...still :-( 2008 Ram 2500 CTD 2007 H.D. Softail Custom 92 Jeep Cherokee
Re: Anyone using an adjustable mini starter? [Re: HEMIFRED] #1024937
07/03/11 05:33 AM
07/03/11 05:33 AM
London, England
mopar_mark Offline
mopar_mark  Offline
London, England
That & poor distributor phasing
Re: Anyone using an adjustable mini starter? [Re: mopar_mark] #1024938
07/03/11 10:10 AM
07/03/11 10:10 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
what im sayin is the starters with NO SNOUT STINK,who the heak want to play all day w shims and all the other bs...if its aftermarket with snout! it might work well..just tryin to save u the time and effort
Re: Anyone using an adjustable mini starter? [Re: DavidDean] #1024939
07/03/11 11:07 AM
07/03/11 11:07 AM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
You might want to send that starter back to them,,,let them look at it and maybe they can figure out how to produce another one JUST LIKE it!!! They re-worked mine 3 times and NEVER did get it to hold up. The idea is good, but the little screws that hold the too many sections together don't hold up very long. Mine had the alignment nose/snout, but when the starter motor would start flexing on the mount, things went bad. In my A-body/RB car with TTI headers, I knew I was going to be in for lots of work with a starter failure, so I paid $340. for the TTI recomended, and Powermaster advertised 'ultimate starter'. I also paid $1000.+ for a new convertor, as the starter ate my old one the 2nd time I got the starter back from them. The $45.00 Mopar mini starter fit the space better and does an excellent job of cranking my 493" 13.5:1 CR engine. Sorry this post is so long, but the time to read it is very short compared to changing starters 3-4 times with a combination like mine.
Re: Anyone using an adjustable mini starter? [Re: CHAPPER] #1024940
07/03/11 05:30 PM
07/03/11 05:30 PM
St. Charles, MO.
Slingshot383 Offline
St. Charles, MO.
I use the Powermaster in my altered, it was the only way to get a starter to fit as the frame rail is right there.
1994 Undercover Chassis 125" altered stack injected big block, soon blown and injected Member of The Torque and Recoil Club
Re: Anyone using an adjustable mini starter? [Re: mopar_mark] #1024941
07/03/11 05:43 PM
07/03/11 05:43 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
THANKS i FORGOT THAT PART
home of the
Re: Anyone using an adjustable mini starter? [Re: Slingshot383] #1024942
07/04/11 12:12 AM
07/04/11 12:12 AM
ky
68roadrunner Offline
ky
me to, but i am glad they told me it wont work, its only been in there two years.
Re: Anyone using an adjustable mini starter? [Re: DMax One] #1024943
07/05/11 11:19 AM
07/05/11 11:19 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
I just had to go this route with TTI's in an early - a body.
The starter rotates 360 degrees and seems fine - i did have to grind the block since it was in contact with a portion of it.
Re: Anyone using an adjustable mini starter? [Re: DJVCuda] #1024944
07/05/11 12:59 PM
07/05/11 12:59 PM
Out West
408strokerdart Offline
Out West
Powermaster with snout here....no problems at all. I had to extend the snout (made a machined part to bolt on the existing snout)because of the mid plate, but works just fine and I needed one I could clock also.
Re: Anyone using an adjustable mini starter? [Re: DJVCuda] #1024945
07/06/11 06:24 PM
07/06/11 06:24 PM
N.Wilkesboro,NC
N.Wilkesboro,NC
So the terminal portion can be rotated 360*? This looks like the solution...
Do you have a pic of the MC starter from the front view? I am wondering how wide the round part is compared to the stock mini??
Re: Anyone using an adjustable mini starter? [Re: DusterKrazy] #1024946
07/06/11 10:02 PM
07/06/11 10:02 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
as a matter of fact i do,
