Re: Anyone using an adjustable mini starter?
[Re: DJVCuda]
#1024935
07/03/11 01:07 AM
07/03/11 01:07 AM
Posts: 3,445 N.Wilkesboro,NC
DusterKrazy
N.Wilkesboro,NC
you mean clockable?
That's it!
I had the Mopar mini starter installed but it will not clear the steering box on my '41 Dodge truck (original straight axle frame).
So I think the clockable will be my solution. The mini almost gets me by.
[Re: HEMIFRED]
#1024937
07/03/11 05:33 AM
07/03/11 05:33 AM
Posts: 912 London, England
mopar_mark
London, England
98% of all starter failures I have seen here come from poor alignment and bad mesh with ring gear
That & poor distributor phasing
[Re: DavidDean]
#1024939
07/03/11 11:07 AM
07/03/11 11:07 AM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
I use a clockable powermaster w/ nose snout on my 408 SB. It hasnt missed a beat its always worked well for me.
You might want to send that starter back to them,,,let them look at it and maybe they can figure out how to produce another one JUST LIKE it!!! They re-worked mine 3 times and NEVER did get it to hold up. The idea is good, but the little screws that hold the too many sections together don't hold up very long. Mine had the alignment nose/snout, but when the starter motor would start flexing on the mount, things went bad. In my A-body/RB car with TTI headers, I knew I was going to be in for lots of work with a starter failure, so I paid $340. for the TTI recomended, and Powermaster advertised 'ultimate starter'. I also paid $1000.+ for a new convertor, as the starter ate my old one the 2nd time I got the starter back from them. The $45.00 Mopar mini starter fit the space better and does an excellent job of cranking my 493" 13.5:1 CR engine. Sorry this post is so long, but the time to read it is very short compared to changing starters 3-4 times with a combination like mine.
If you like drag racing, support your local track.
[Re: CHAPPER]
#1024940
07/03/11 05:30 PM
07/03/11 05:30 PM
Posts: 684 St. Charles, MO.
Slingshot383
St. Charles, MO.
I use the Powermaster in my altered, it was the only way to get a starter to fit as the frame rail is right there.
1994 Undercover Chassis 125" altered
stack injected big block, soon blown and injected
Member of The Torque and Recoil Club
[Re: Slingshot383]
#1024942
07/04/11 12:12 AM
07/04/11 12:12 AM
Posts: 877 ky
68roadrunner
ky
me to, but i am glad they told me it wont work, its only been in there two years.
[Re: DMax One]
#1024943
07/05/11 11:19 AM
07/05/11 11:19 AM
Posts: 11,179 Atco NJ
DJVCuda
Atco NJ
Might check into this one, http://www.robbmcperformance.com/products/mopar_starter.html
I haven't ever heard anything bad about them. I plan on geting one when I put my junk back together.
I just had to go this route with TTI's in an early - a body.
The starter rotates 360 degrees and seems fine - i did have to grind the block since it was in contact with a portion of it.
[Re: DJVCuda]
#1024945
07/06/11 06:24 PM
07/06/11 06:24 PM
DusterKrazy
N.Wilkesboro,NC
So the terminal portion can be rotated 360*? This looks like the solution...
Do you have a pic of the MC starter from the front view? I am wondering how wide the round part is compared to the stock mini??
[Re: DusterKrazy]
#1024946
07/06/11 10:02 PM
07/06/11 10:02 PM
DJVCuda
Atco NJ
as a matter of fact i do,
