info - 440 Source balanced kit, my measurements.
#1024368
07/02/11 12:20 PM
07/02/11 12:20 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
Just a For What its Worth post. I weighed the pistons, pins, rods, etc to see how they matched up with the Balance sheet from 440 Source. Note: I used the same numbers for oil weight and balance factor. The locks and rings measured the same when I checked them. There were some variation of piston and rod weights, but they were fairly small, less than 2 grams max. This is the 440 Source Balance Sheet Info:
440 Source Bob Weight Card Piston and Pin 755.8 Rod Bearing 47.8 Rings 57.7 Rotating End 528.8 Locks 4.4 Oil (each) 2 Rod Pin End 241.5 Reciprocaring Total 2118.8 Rotating Total 1157.2 balance Factor % 50 Reciprocaring Total ½ 1059.4 Bobweight Total 2216.6
My Measured Numbers:
Piston, Pin, Rod End 998.69 Rod Bearing 47.8 Rings 57.7 Rotating End 528.46 Locks 4.4 Oil (each) 2 Reciprocaring Total 2121.58 Rotating Total 1156.53 balance Factor % 50 Reciprocaring Total ½ 1060.79 Bobweight Total 2217.31 diff 0.71
My Individual part measurements:
Ref Number PISTON PIN TOTAL 1 598.5 158.1 756.6 2 598.1 158.3 756.4 3 597.3 158.1 755.4 4 599.6 158.2 757.8 5 598.3 158.2 756.5 6 597.3 158.2 755.5 7 597.9 158.3 756.2 8 598.9 158.0 756.9 AVE 598.2 158.2 756.4
ROD WEIGHTS Ref Number TOTAL BIG END PIN END 1 771.0 528.3 242.7 2 770.7 528.7 241.5 3 770.4 528.5 242.1 4 770.5 528.8 242.9 5 770.6 528.4 242.8 6 769.6 528.4 241.5 7 771.1 528.5 242.7 8 770.4 528.1 242 AVE 770.5 528.5 242.3
By matching the light pistons with the heavier rods, I minimized the variation in the reciprocating end (piston, pin, small end of rod) to an average weight of 998.7 grams with less than 0.5 gram variance) The lightest combination being 0.29 gram less, and the heavy combination being 0.41 gram more.
Note that the slight difference in rod end weights could just be a slight difference in leveling the rod balance fixture. We are talking weight differences less than half a sheet of paper (A 8-1/2"x11" sheet of printer paper is about 4.5 grams.) From this information, The Balance measurements from 440 Source look good. I would have to send the crank out to have the balance on it checked, but I'm going to use it as is.
Re: info - 440 Source balanced kit, my measurements.
[Re: 451Mopar]
#1024369
07/02/11 12:25 PM
07/02/11 12:25 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I don't know what the average + or - tolerance is with different scales,but looks like it's ready to go.Are you going to measure the crank journals,and see what they look like?
[Re: Chris2581]
#1024370
07/02/11 12:50 PM
07/02/11 12:50 PM
451Mopar
Aurora, Colorado
The journals were right on spec, just need to make sure the bearings clear the fillets at the ends of the journals. The Main bearings that come with the kit actually have a fairly tight oil clearance spec of 0.0005" to 0.0026" (Clevite MS-1795V), that may be the reason some shops polish the mains to get more oil clearance. The GM 2.2" rod bearings have a 0.0010" to 0.0030" oil clearance spec (Clevite CB-743HN.) My machine shop measured the 4.25" stroke crank 4.253" when measured to mill the block for zero deck? So fat i have only mocked it up for clearancing the 440 block and the crank and rods clear the cylinders easely, only close spot in the oilpump pickup boss. I took a small amount off the boss just to make sure, but it did clear, but was close before I removed the material. So far everything is going together pretty nice and easy, except the cam bearings (in another post), and I could have gone with them as is, but I'm going to get new ones and clearance them by hand if needed, as I did not like the results from the slotted cam clearance trick as I think it removed more material then necessary.
[Re: 451Mopar]
#1024374
07/03/11 09:20 AM
07/03/11 09:20 AM
Posts: 469 Tennessee
steeldust
Tennessee
A few of the pin bushings seem tight. Not sure if the edges of the bushings may have been dinged a bit in shipping, or if the entire bushing was machined tight? I'll have to examine them closer to see.
The reason I bothered to measure all this, was when I built my 500" stroked 400 block, with a balanced kit, the machine shop told me it was out of balance and needed weight added to the crank.
I am not going to say that all kits are not right but if you are going to spend the money to build a motor be 100% that the parts are right if you torque the rod bolts or mains or heads do you just torque and stop no i check them three or four times will a machine shop can fine little things and i think your rods needs honing i bet if you won"t ever thing to run smooth with NO TROUBLE but i could wrong . GOOD LUCK
[Re: 451Mopar]
#1024375
07/03/11 12:00 PM
07/03/11 12:00 PM
Posts: 1,491 Oologah, Oklahoma
Big Squeeze
Oologah, Oklahoma
How's the indexing?? I had one that had a journal off .035" in one direction........I sent it back, got another one, and my original was resold.......
If you can't handle the truth, you're living a lie.......
[Re: Big Squeeze]
#1024376
07/03/11 12:20 PM
07/03/11 12:20 PM
Posts: 2,091 Delray beach, Florida
Performance Only
how did the replacement crank check out?
machine shop owner and engine builder
[Re: Performance Only]
#1024381
07/03/11 06:06 PM
07/03/11 06:06 PM
Big Squeeze
Oologah, Oklahoma
Had issues with that one too.......and a thread on here got deleted about it quite a while ago...........long story short, if I moved the crank forward, the counter weight would hit the block before the thrust did.........and he blamed it on my block, but a stock 400 and 383 crank both fit perfectly fine......Then the third one was actually fixable and then useable......
not trying to stir the pot but how do you know your original was resold
Long story short, I brought the crank up in a thread and the Sourcerer goes into this huge spiel how about how I sent back a crank that was "supposedly bad" and he sent me another.........so I asked in that thread if he actually went through the trouble of checking that "supposedly bad" crank that I told him wasn't useable and he wouldn't answer, even though he was replying to other people and still bashing me.........I told him I wasn't worried about it.....just that I thought it'd be good for him to know to correct it on later cranks........Later in the thread, I said that since you won't answer and since you admitted you NEVER checked it yourself because you're saying that it was "supposedly bad" then I bet you've already resold it.........that's when the thread got deleted.......
If he'd have actually checked it, he'd have KNOWN it wasn't fixable .......and he knows that most people, especially Tight Wad Joe Dirte Mopar guys, aren't going to spend the coin to get their cranks indexed.......
That's when I put the wording in my sig below......
[Re: Mick70RR]
#1024383
07/03/11 09:58 PM
07/03/11 09:58 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
When I got mine from 440Source, Brandon told me the pins would need to be honed to fit. He said that there are different .990" pin manufacturers and that none of them were actually exactly .990, some a little under some a little over so he had his rods come in for the smallest known diameter and then you can hone them to fit ANY .990 pin.
I've said it before that I think buying a pre balanced kit is a waste of $$ because there is no such thing as ready to run parts. If you have to have all the parts checked to confirm the bob weight anyway, you've already paid for a large portion of a balance job. You might as well pay the shop to finish the job and do the final balance too.
Kevin
If that's the case, what about the pin fit in the piston. I hear of rods being honed to fit the pin all the time but I don't remember anyone saying they had to hone the pistons.
All of my pins fit the pistons fine it was just the rods that were tight. Brandon never told me about a fit to size rod bushing but like I said I just honed my rods to get the fit I wanted with the pins. Ron
[Re: Big Squeeze]
#1024386
07/04/11 02:22 AM
07/04/11 02:22 AM
451Mopar
Aurora, Colorado
Today I assembled all the piston/rod assemblies, Installed the crank and installed all the pistons/rods without rings to check piston deck heights and crank indexing. I did have three pins (on the rods) that were tight, but cleaned up easy. There was a post on turning torque, and with everything assembled (without) piston rings the turning torque is too low to measure with my ft/lb beam torque wrench. Even my click type torque wrench backed off to zero ft/lbs did not even click. The Machine shop did a good job of getting the deck milled for zero deck height. I put a flat edge across each piston at TDC, and they were right at zero deck I then installed my degree wheel and found TDC of #1. Then Verified TDC#6 was exactly the same. Then verified #4 and #7 were at TDC when #1 is at 180 degrees. I verified the TDC using a piston stop that stopped the piston at 22 degrees before/after TDC or 180 (depending on which pistons was measured.) Anyhow, once again no issues and everything checked out. I still need to check crank thrust and rod side clearance.
