Where to get 62-65 B-body Small Block motor mounts? #1024009
07/01/11 02:33 PM
07/01/11 02:33 PM
Oakland, MI
dizuster Offline OP
dizuster  Offline OP
Oakland, MI
Anybody have a source for 62~65 small block motor mounts. Obviously the original would be for a poly 318, but I know they are the same as an LA.
I'm not looking for the rubber parts, just the portion that bolts on to the block itself.
I know that schumacher has them, but they are fairly expensive. Just looking for stock ones so I can make my own solid motor mounts.
Anybody got one laying around, or know where to get them? Any moparts sponsors that would have a part like this?
Re: Where to get 62-65 B-body Small Block motor mounts? [Re: dizuster] #1024010
07/01/11 07:03 PM
07/01/11 07:03 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I know a member here was selling early mounts.I think he had bb and sb.Joesixpax I think was his name.Rocky
Chrysler Firepower
Re: Where to get 62-65 B-body Small Block motor mounts? [Re: therocks] #1024011
07/01/11 07:56 PM
07/01/11 07:56 PM
oak park, il.
dsd70bee Offline
dsd70bee  Offline
oak park, il.
w.cowger@comcast.net His name is Bill Cowger, he is a member here. He is a good guy and has been selling motor mounts for many years.
Re: Where to get 62-65 B-body Small Block motor mounts? [Re: dizuster] #1024012
07/02/11 01:56 AM
07/02/11 01:56 AM
I think the 1962 B body V8 mounts, engine and K memebers, are different than the 1963,64 and 1965 B bodys
Re: Where to get 62-65 B-body Small Block motor mounts? [Re: Cab_Burge] #1024013
07/02/11 11:40 AM
07/02/11 11:40 AM
Oakland, MI
dizuster Offline OP
dizuster  Offline OP
Oakland, MI
Thanks for the replies guys.
CAB you are correct. The '62 is slightly different, but I should have specified this was a /6 '62 car, so I snagged a poly 318 k-frame out of a '65 coronet...
Re: Where to get 62-65 B-body Small Block motor mounts? [Re: dizuster] #1024014
07/02/11 02:08 PM
07/02/11 02:08 PM
That is a good way to go in my book
Re: Where to get 62-65 B-body Small Block motor mounts? [Re: Cab_Burge] #1024015
07/02/11 08:22 PM
07/02/11 08:22 PM
gtx69 Offline
super gas
gtx69  Offline
super gas
Are you looking to borrow a set to make a copy?
Re: Where to get 62-65 B-body Small Block motor mounts? [Re: gtx69] #1024016
07/03/11 10:27 AM
07/03/11 10:27 AM
Oakland, MI
dizuster Offline OP
dizuster  Offline OP
Oakland, MI
No I need a set just for the steel stamping parts. I have a set of rubber mounts that I can make the solid portion out of. It's just the side that bolts to the block that I'm missing.
Re: Where to get 62-65 B-body Small Block motor mounts? [Re: dizuster] #1024017
07/03/11 10:30 AM
07/03/11 10:30 AM
MR_P_BODY Offline
MR_P_BODY  Offline
You have that engine setting in there yet
Re: Where to get 62-65 B-body Small Block motor mounts? [Re: MR_P_BODY] #1024018
07/03/11 11:12 AM
07/03/11 11:12 AM
Oakland, MI
dizuster Offline OP
dizuster  Offline OP
Oakland, MI
Well it is, but I don't love it. I got some mounts out of a '65 coronet that had a 318 LA motor in it. The thing is, it only catches two of the motor mounts on each side. Trans mount lines up so I know its in the right spot, but I wouldn't want to run the motor like that in the car.
You about ready to get that welder fired up?
Re: Where to get 62-65 B-body Small Block motor mounts? [Re: dizuster] #1024019
07/03/11 12:50 PM
07/03/11 12:50 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yeah I'm thinkin you can bring it over next weekend
or when you can
Re: Where to get 62-65 B-body Small Block motor mounts? [Re: MR_P_BODY] #1024020
07/03/11 01:42 PM
07/03/11 01:42 PM
Oakland, MI
dizuster Offline OP
dizuster  Offline OP
Oakland, MI
Sounds good. I'll hook up with you this week to get things sorted out when/how, etc..
Re: Where to get 62-65 B-body Small Block motor mounts? [Re: dizuster] #1024021
07/03/11 01:47 PM
07/03/11 01:47 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Ok... you have my number... correct
Re: Where to get 62-65 B-body Small Block motor mounts? [Re: dizuster] #1024022
07/03/11 01:54 PM
07/03/11 01:54 PM
State of Fascism
52savoy Offline
52savoy  Offline
State of Fascism
Local racers(and partners) Ray Christian and Shelby Starkey used to machine their max wedge/HEMI engine mounts out of aluminum(among other things). That was 40 years ago..
Good to know there are still a lot of thinkers out there.
and guess who came up with aluminum tranny drums? I'll give you one guess.
Re: Where to get 62-65 B-body Small Block motor mounts? [Re: 52savoy] #1024023
07/03/11 10:11 PM
07/03/11 10:11 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
sorry dont have any of the small block 273-318 steel brackets....somebody should have them sitting around...ears on the blocks are sorta different 273-318 poly and 318 LA. in different places. some missing...some have more on 1 side.
Re: Where to get 62-65 B-body Small Block motor mounts? [Re: Joesixpack] #1024024
07/04/11 11:44 AM
07/04/11 11:44 AM
Oakland, MI
dizuster Offline OP
dizuster  Offline OP
Oakland, MI
Thanks for looking Bill. Hopefully someone comes up with some around here...
Re: Where to get 62-65 B-body Small Block motor mounts? [Re: dizuster] #1024025
07/04/11 12:20 PM
07/04/11 12:20 PM
Oakland, MI
dizuster Offline OP
dizuster  Offline OP
Oakland, MI
By the way are you saying that the 318 poly mount WON'T work on an LA 62~65 b-body, or that they will but they are a little different.
Re: Where to get 62-65 B-body Small Block motor mounts? [Re: dizuster] #1024026
07/04/11 09:43 PM
07/04/11 09:43 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
the picture shows the 318 poly mounts from a 62-65 b-body, they will work on a LA 318 but not all of the mount ears on the mounts line up exactly with the LA 318 block ears. you can bolt up the ones that do and weld in a piece or two to hook up with the block ears.
Re: Where to get 62-65 B-body Small Block motor mounts? [Re: Joesixpack] #1024027
07/05/11 10:15 AM
07/05/11 10:15 AM
Oakland, MI
dizuster Offline OP
dizuster  Offline OP
Oakland, MI
Oh... very interesting. So here I thought I had the wrong mounts holding the motor in right now, but maybe they are correct.
I thought they were wrong because I could only get 2 bolts in per side (instead of 3).
But you're saying that's normal when using a 318 poly mount on a 318 LA? I thought they were exactly the same?
EDIT... now that I'm looking at it... I understand. The poly 318 has the two bolts on the REAR of the mount on a the passenger side, while the LA 318 has the two bolts on the FRONT...
