Re: Where to get 62-65 B-body Small Block motor mounts?
[Re: dizuster]
#1024010
07/01/11 07:03 PM
07/01/11 07:03 PM
Posts: 21,080 Niles , Ohio
therocks
Niles , Ohio
I know a member here was selling early mounts.I think he had bb and sb.Joesixpax I think was his name.Rocky
Chrysler Firepower
[Re: dizuster]
#1024017
07/03/11 10:30 AM
07/03/11 10:30 AM
Posts: 52,972 Romeo MI
MR_P_BODY
No I need a set just for the steel stamping parts. I have a set of rubber mounts that I can make the solid portion out of. It's just the side that bolts to the block that I'm missing.
You have that engine setting in there yet
[Re: dizuster]
#1024019
07/03/11 12:50 PM
07/03/11 12:50 PM
MR_P_BODY
Well it is, but I don't love it. I got some mounts out of a '65 coronet that had a 318 LA motor in it. The thing is, it only catches two of the motor mounts on each side. Trans mount lines up so I know its in the right spot, but I wouldn't want to run the motor like that in the car.
You about ready to get that welder fired up?
Yeah I'm thinkin you can bring it over next weekend or when you can
[Re: dizuster]
#1024021
07/03/11 01:47 PM
07/03/11 01:47 PM
MR_P_BODY
Sounds good. I'll hook up with you this week to get things sorted out when/how, etc..
Ok... you have my number... correct
[Re: 52savoy]
#1024023
07/03/11 10:11 PM
07/03/11 10:11 PM
Posts: 11,912 APACHE JUNCTION AZ
Joesixpack
APACHE JUNCTION AZ
sorry dont have any of the small block 273-318 steel brackets....somebody should have them sitting around...ears on the blocks are sorta different 273-318 poly and 318 LA. in different places. some missing...some have more on 1 side.
[Re: Joesixpack]
#1024027
07/05/11 10:15 AM
07/05/11 10:15 AM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
Oh... very interesting. So here I thought I had the wrong mounts holding the motor in right now, but maybe they are correct.
I thought they were wrong because I could only get 2 bolts in per side (instead of 3).
But you're saying that's normal when using a 318 poly mount on a 318 LA? I thought they were exactly the same?
EDIT... now that I'm looking at it... I understand. The poly 318 has the two bolts on the REAR of the mount on a the passenger side, while the LA 318 has the two bolts on the FRONT...
