Correct looking battery "Tops" with the colored caps #1023971
07/01/11 01:35 PM
07/01/11 01:35 PM
Canal Fulton, (Akron) Ohio
Q
Quicksmopars Offline OP
Q
I'm looking for the battery top covers that cover regular old batteries and make them kinda look like the originals. I saw them a few years back then they seemed to vanish. Does anyone know who sells them?
Re: Correct looking battery "Tops" with the colored caps [Re: Quicksmopars] #1023972
07/01/11 01:54 PM
07/01/11 01:54 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
I think Year One still sells them?
Re: Correct looking battery "Tops" with the colored caps [Re: Quicksmopars] #1023973
07/01/11 02:59 PM
07/01/11 02:59 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
Re: Correct looking battery "Tops" with the colored caps [Re: Golden-Arm] #1023974
07/01/11 04:14 PM
07/01/11 04:14 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
too bad there are too wide for the factory hold down brackets
Re: Correct looking battery "Tops" with the colored caps [Re: 05dakota] #1023975
07/01/11 04:57 PM
07/01/11 04:57 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
FWIW, I was able to make an O.E. style '68 (Road Runner) hold-down work with a little tweaking..but you're right it's too bad they don't work right out of the box with the O.E. hold-down
MikeR
Re: Correct looking battery "Tops" with the colored caps [Re: A12] #1023976
07/02/11 07:19 PM
07/02/11 07:19 PM
Q
Q
Thats' a bummer that they don't fit with my hold down. Oh well, I'll still buy one if I ever see one in person again at a show.
Re: Correct looking battery "Tops" with the colored caps [Re: Quicksmopars] #1023977
07/02/11 08:37 PM
07/02/11 08:37 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
I don't know if you can just get the caps, but here's what I did. A buddy ordered a green cap battery and got a yellow cap battery, the CO. sent him the correct green caps for the repo battery he ordered and he gave me the yellow caps.
I took the yellow caps and ground down the threads so they would push into my Interstate battery. I am very pleased with the look but I have a MTP-24 ( MTP is a high cranking amp battery ) that has Interstate molded in the top, when I replace this battery I will order a MT-24 that only will have a Interstate sticker on top and once removed I will have a solid black case battery with the correct yellow caps for my car.
Re: Correct looking battery "Tops" with the colored caps [Re: rrunner] #1023978
07/02/11 09:38 PM
07/02/11 09:38 PM
Maryland
wally426ci Offline
wally426ci  Offline
Maryland
I have a red topper and I want to get another so I can put one on my truck too. How do I know what color to get?
I have a small block 71 Challenger built October 1970
and I have a 68 D100 318.
Re: Correct looking battery "Tops" with the colored caps [Re: wally426ci] #1023979
07/02/11 09:46 PM
07/02/11 09:46 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
https://board.moparts.org/ubbthreads/show...e=1#Post6708402
Re: Correct looking battery "Tops" with the colored caps [Re: 05dakota] #1023980
07/05/11 06:55 PM
07/05/11 06:55 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
How would one expect anything different? They are made to fit OVER an existing battery.
Re: Correct looking battery "Tops" with the colored caps [Re: JohnRR] #1023981
07/06/11 12:31 AM
07/06/11 12:31 AM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
i would expect them to be actually usable.
Re: Correct looking battery "Tops" with the colored caps [Re: 05dakota] #1023982
07/06/11 09:27 AM
07/06/11 09:27 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
They do exactly what they are designed to do, fit OVER an existing battery. That's what you get for cheaping out and not buying a resto battery
Re: Correct looking battery "Tops" with the colored caps [Re: JohnRR] #1023983
07/07/11 12:44 AM
07/07/11 12:44 AM
Texas
missu34 Offline
missu34  Offline
Texas
The resto batteries are expensive and they are short on performance and longevity. Enough said.
Re: Correct looking battery "Tops" with the colored caps [Re: missu34] #1023984
07/07/11 04:24 AM
07/07/11 04:24 AM
NotRussia
2
2fast4yourBrain Offline
Whack top Dodger
Whack top Dodger
2
NotRussia
Wasn't there the ability to just buy the case? And then you can stick in one of those lightweight race batteries inside???
Re: Correct looking battery "Tops" with the colored caps [Re: missu34] #1023985
07/07/11 09:38 AM
07/07/11 09:38 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Yes that is true so if one is going cheap out even though they demand the correct resto look they should not be when a halfassed compromise doesn't fit as well as the proper part.
Re: Correct looking battery "Tops" with the colored caps [Re: 2fast4yourBrain] #1023986
07/07/11 09:40 AM
07/07/11 09:40 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
No , you have to find someone with a dead battery that wants to sell it to you to do this and it's a messy job. It would be niceiif the battery companies did this though, sold an empty shell with no bottom , I'd gladly pay for one like that.
Re: Correct looking battery "Tops" with the colored caps [Re: JohnRR] #1023987
07/07/11 02:44 PM
07/07/11 02:44 PM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
..1/4 " round stock and a couple of pieces of 3/16" angle iron
..1/2" wider than stock, very easy to make
...oops 3/4" angle iron
Re: Correct looking battery "Tops" with the colored caps [Re: rrunner] #1023988
07/07/11 04:46 PM
07/07/11 04:46 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
One can buy the caps , I did a couple years ago , never ended up using them though. Nice tip on the interstate battery.
Re: Correct looking battery "Tops" with the colored caps [Re: JohnRR] #1023989
07/07/11 06:10 PM
07/07/11 06:10 PM
Northern NJ
68 Sat Offline
68 Sat  Offline
Northern NJ
I have one of those shells. I was told it was a display model..
1963 Chrysler 300 Pace Setter Convertible 21K mile survivor 1969 Dodge Coronet 500 1956 Desoto Hemi 1955 Chrysler C300
Re: Correct looking battery "Tops" with the colored caps [Re: 68 Sat] #1023990
07/07/11 06:12 PM
07/07/11 06:12 PM
Northern NJ
68 Sat Offline
68 Sat  Offline
Northern NJ
2nd pic. sorry for the small jpeg...?
