1997 Caravan-warning light on dash? #1023787
07/01/11 12:58 AM
07/01/11 12:58 AM
Modesto CA
BFASTER Offline OP
BFASTER  Offline OP
Modesto CA
Can't find my manual so---On the right side of the little black bar on top of the dash; a yellow warning light comes on intermittently. It looks like a wheel or something round. It happened Sunday (again) and I can't seem to remember exactly what it looks like. I thought it was a brake light of some sort...but I think that one says "BRAKE" in red when first starting up the van. What is this little yellow symbol? It comes on after long trips, not around town too.
1969 Dodge Super Bee Hardtop 2007 Nissan Altima 3.5SE
Re: 1997 Caravan-warning light on dash? [Re: BFASTER] #1023788
07/01/11 09:21 AM
07/01/11 09:21 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Sounds like it might be an air bag light.Have the codes pulled.Those were known for the clock spring going bad.Rocky
Chrysler Firepower
Re: 1997 Caravan-warning light on dash? [Re: therocks] #1023789
07/01/11 09:29 AM
07/01/11 09:29 AM
tboomer Offline
tboomer  Offline
Rocky is correct...The clock spring is probably toasted..There was a recall on those and if yours wasn't repaired,Chrysler will pick up the tab!
Re: 1997 Caravan-warning light on dash? [Re: tboomer] #1023790
07/01/11 03:27 PM
07/01/11 03:27 PM
Modesto CA
BFASTER Offline OP
BFASTER  Offline OP
Modesto CA
The spring was replaced about 6 yrs ago when the airbag light stayed on. I guess I'll get the codes pulled today. Thank you both!
Re: 1997 Caravan-warning light on dash? [Re: BFASTER] #1023791
07/01/11 05:07 PM
07/01/11 05:07 PM
Modesto CA
BFASTER Offline OP
BFASTER  Offline OP
Modesto CA
Put MODIS OBD II on it.....ABS Control Module. Anyone ever have experience with this?
Re: 1997 Caravan-warning light on dash? [Re: BFASTER] #1023792
07/01/11 10:19 PM
07/01/11 10:19 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
sometimes you can unplug the abs and clean the pin's and it will be o k
Re: 1997 Caravan-warning light on dash? [Re: a493demon] #1023793
07/01/11 11:52 PM
07/01/11 11:52 PM
Modesto CA
BFASTER Offline OP
BFASTER  Offline OP
Modesto CA
Good idea....I'll try that!
