70 B-Body Alternator,, New or Restore?
#1023676
06/30/11 09:56 PM
06/30/11 09:56 PM
Posts: 1,066 California
70SportSatellite
super street
super street
California
I'll try to keep it short. I need an alt for my Sat. 383 no A/C. I had one restored about 4-5 years ago but now the finish is turning. Do I re-restore this one or is there a new on available that is up to restoration/show quality. I'm not going to quibble over date codes but it must appear original in looks and finish. I saw this online but can't tell from the pic's if it would work. new alt If I don't find a new one who does the best alt resto's?
Re: 70 B-Body Alternator,, New or Restore?
[Re: 70SportSatellite]
#1023677
06/30/11 10:13 PM
06/30/11 10:13 PM
Posts: 21,448 It's a dry heat
gtx6970
It's a dry heat
hands down, Jim Ridge at Dixie Restoration services. Price wise I think he is comparible with most any aftermarket rebuilt alternator.
problem is, if it's been rebuilt before it - usually has been glass beaded or even worst, sand blasted and it completely changes the surface texture of the case that you cannot get back
#1023678
06/30/11 10:51 PM
06/30/11 10:51 PM
Posts: 18,157 Mass
DAYCLONA
Mass
If your looking for a NEW, not rebuilt or "restored" altenator, Powermaster has a line of "Resto" altenators for Mopars, these have brand new cases, that have that nice newly cast milky aluminum appearance, and all new internals, rated for 13,000 rpm pulley speeds, and correct internals coated/plated/gylptoled/etc...retail is about $100 www.summitracing.com is probally your best source for purchase The part numbers are: PN# 7019....Double pulley/2 field terminals/round back PN# 7018 single pulley/2 field terminals/roundback design I have several of these in use, after you remove the Powermaster decal, they pass for "NOS' alternators, no casting numbers/stamps/logos
[Re: gtx6970]
#1023681
07/01/11 12:38 AM
07/01/11 12:38 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Mike, I I respectivly dis-agree. I have one of these on a car now and the problem I am having is the belt groove width is much narrower than any of the other pulleys. And I am having belt noises associated with such.
Bill, do you have one of the "resto" powermasters, or one of the "streetmaster" units?....I've had no issues with the "resto" alternators, nor with the pulleys
This here is the STREETMASTER 7419
#1023682
07/01/11 12:41 AM
07/01/11 12:41 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Thanks guys,
Bill, Can the stock pulley be put on one of the Powermaster units?
Yes,...I've had one unit, that the black double grove factory HEMI pulley was swapped on
[Re: DAYCLONA]
#1023685
07/01/11 09:39 AM
07/01/11 09:39 AM
gtx6970
It's a dry heat
Bill, do you have one of the "resto" powermasters, or one of the "streetmaster" units?....I've had no issues with the "resto" alternators, nor with the pulleys This here is the STREETMASTER 7419
Mike, To be honest, I do not know My customer supplied it when he was talked into it by the sales rep and Bouchillon. He ordered the under hood Vintage A/C components from them and they suggested it.
It's dual groove pulley alt, and they only thing that was on it is the powermaster decal. I threw the box away before I noticed the pulley differences.
But this is it .
[Re: 70RR383]
#1023686
07/01/11 10:53 AM
07/01/11 10:53 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Would these be OK for any 70 b body.I meen amp wise???Thanks
Yes they are rated for 75 amps, but come with a test sheet indicating exactly what the output was, basically an electrical dyno sheet, they avg 55-60 amps, regardless of the amp rating stated, powermaster does offer anthing and everything under the sun for starter/alts/generators, chrome/stock HO/race only units/marine/etc...
I have several in use on my DD, and toys, got tired of resto/rebuilts that gave up the ghost too soon, often leaving me stranded,....the one I have on my Charger Daytona sees sustained 140 MPH runs averaging up to 6200RPM, plus with 4:10 gears, see lots of high RPM's on the street, no problems been on there for 6 yrs,....I won't but another resto or rebuilt again,....same with the Powermaster mini starters, might cost more than the generic mini's,....but I've outlasted others running the Chrysler mini's...
Mike
[Re: gtx6970]
#1023687
07/01/11 11:02 AM
07/01/11 11:02 AM
Posts: 18,157 Mass
DAYCLONA
Mass
But this is it .
Bill, That looks like the "Streetmaster" Powermaster alt,that I posted a pic of above,....all the restos have the wide band stator/commutator gizmo between the cases, as original, the streetmaster I have on my Daughters 88 Dode Ram, is designed for 85 and up applications, so maybe that's the puley problem your experiencing, plus the 85 and up case/alignment is narrower, as I tried this one initialy on my Challenger, it fit, but the belt alignment was off some (that's kinda how my daughters truck got it instead )
Mike
