Are all rockershafts created equal? #1023382
06/30/11 01:59 PM
06/30/11 01:59 PM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
I want to buy some SS rockers from a local guy but they dont
Have shafts. Can i use my stock shafts? Are they all supposed
To be the same dia? These rockers are not bushed as far as i know
Clearance on the shaft about .003?
74 dart sport 440 www.Csucarbs.com
Re: Are all rockershafts created equal? [Re: shoebox] #1023383
06/30/11 02:17 PM
06/30/11 02:17 PM
South Jersey, NJ
DragDart360 Offline
DragDart360  Offline
South Jersey, NJ
I would recommend not using your stock shafts. After market shafts are available from several sources.
70 Dart Swinger, 2850 lbs
SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
Re: Are all rockershafts created equal? [Re: DragDart360] #1023384
06/30/11 03:22 PM
06/30/11 03:22 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
To answer your question... No, there are not equal.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Are all rockershafts created equal? [Re: BloFish] #1023385
06/30/11 04:56 PM
06/30/11 04:56 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
You want hardened shafts.
Re: Are all rockershafts created equal? [Re: topside] #1023386
06/30/11 08:45 PM
06/30/11 08:45 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Who doesn't
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Are all rockershafts created equal? [Re: BloFish] #1023387
06/30/11 08:46 PM
06/30/11 08:46 PM
Kirkland, Washington
Pacnorthcuda Offline
Who doesn't
My ex-girlfriend.
Re: Are all rockershafts created equal? [Re: Pacnorthcuda] #1023388
06/30/11 09:04 PM
06/30/11 09:04 PM
ohio
HEMIDARTS Offline
HEMIDARTS  Offline
ohio
Who doesn't
My ex-girlfriend.
I like to get my hardened shafts polished!
Re: Are all rockershafts created equal? [Re: HEMIDARTS] #1023389
06/30/11 09:20 PM
06/30/11 09:20 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
Real men get bannana grooves cut in them!!
Re: Are all rockershafts created equal? [Re: Lee446] #1023390
06/30/11 10:52 PM
06/30/11 10:52 PM
mckinney texas
shoebox Offline OP
shoebox  Offline OP
mckinney texas
Ok where can i get some budget minded good shafts?
And how much? Where?
Re: Are all rockershafts created equal? [Re: shoebox] #1023391
07/01/11 01:27 AM
07/01/11 01:27 AM
A collage of whims
A collage of whims
Mancini's, Harland Sharp, MP, Comp Cams, and I think KMJ's are hardened. Also try 440Source, Ebay, Crane...
Re: Are all rockershafts created equal? [Re: shoebox] #1023392
07/01/11 05:13 PM
07/01/11 05:13 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Some aftermarket shafts that I've seen weren't round over the entire length, not critical on the original stamped rockers but unacceptable for cast/forged rockers.
Re: Are all rockershafts created equal? [Re: shoebox] #1023393
07/01/11 05:24 PM
07/01/11 05:24 PM
Ok where can i get some budget minded good shafts? And how much? Where?
you have a PM on this subject
Re: Are all rockershafts created equal? [Re: John_Kunkel] #1023394
07/01/11 05:28 PM
07/01/11 05:28 PM
Mo.
racerx Offline
racerx  Offline
Mo.
I have a set of the Indy shaft that came in the -1 kit and i broke a rocker so i ordered a replacement rocker,when i went to install the rocker it was giving me a fit trying to install it don't no if it is the shaft or the rocker out of tolerance so i decided to replace the shaft/rocker assembly with a new set of Harland's,T/D i still trying to do some research on which one.
Re: Are all rockershafts created equal? [Re: racerx] #1023395
07/01/11 05:52 PM
07/01/11 05:52 PM
CA
mojavered Offline
mojavered  Offline
CA
On Mancini's site, they have the HS kits and they also sell the HS hardened shafts. Are these different that what comes in the kit?
71 Challenger RT
440 / 727 / 8.75
