Re: Are all rockershafts created equal?
[Re: shoebox]
#1023383
06/30/11 02:17 PM
06/30/11 02:17 PM
Posts: 492 South Jersey, NJ
DragDart360
South Jersey, NJ
I would recommend not using your stock shafts. After market shafts are available from several sources.
70 Dart Swinger, 2850 lbs SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
[Re: DragDart360]
#1023384
06/30/11 03:22 PM
06/30/11 03:22 PM
Posts: 16,479 On the run…
BloFish
On the run…
To answer your question... No, there are not equal.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: Pacnorthcuda]
#1023388
06/30/11 09:04 PM
06/30/11 09:04 PM
Posts: 3,354 ohio
HEMIDARTS
ohio
Who doesn't
My ex-girlfriend.
I like to get my hardened shafts polished!
[Re: shoebox]
#1023392
07/01/11 05:13 PM
07/01/11 05:13 PM
Posts: 25,786 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Some aftermarket shafts that I've seen weren't round over the entire length, not critical on the original stamped rockers but unacceptable for cast/forged rockers.
[Re: John_Kunkel]
#1023394
07/01/11 05:28 PM
07/01/11 05:28 PM
Posts: 4,068 Mo.
racerx
Mo.
I have a set of the Indy shaft that came in the -1 kit and i broke a rocker so i ordered a replacement rocker,when i went to install the rocker it was giving me a fit trying to install it don't no if it is the shaft or the rocker out of tolerance so i decided to replace the shaft/rocker assembly with a new set of Harland's,T/D i still trying to do some research on which one.
[Re: racerx]
#1023395
07/01/11 05:52 PM
07/01/11 05:52 PM
Posts: 93 CA
mojavered
CA
On Mancini's site, they have the HS kits and they also sell the HS hardened shafts. Are these different that what comes in the kit?
71 Challenger RT 440 / 727 / 8.75
