serrated washer under ground and neg battery cable? #1023346
06/30/11 12:00 PM
06/30/11 12:00 PM
PA
BTTG Offline OP
BTTG  Offline OP
PA
Thought I recalled seeing discussion about using a serrated washer under the hold down bolts for the engine ground to firewall cable as well as the negative batter cable recently? Is this "correct?" couldn't find the post discussing this.
for a 69 440 B-body
Re: serrated washer under ground and neg battery cable? [Re: BTTG] #1023347
06/30/11 02:23 PM
06/30/11 02:23 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
for a 69 440 B-body
Well, the negative cable (on a 69) only bolts to one location - on the engine, under the intake bolt and throttle return spring bracket (on non-AC cars for sure).
The rear strap bolts to the firewall with a similar screw (sometimes unique) that the voltage regulator and starter relay uses. They do usually have some kind of serration either under the head or have a serrated type captive spin washer incorporated into the screw.
Re: serrated washer under ground and neg battery cable? [Re: FJ5_Fish] #1023348
06/30/11 04:24 PM
06/30/11 04:24 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
Negative cable...
Re: serrated washer under ground and neg battery cable? [Re: FJ5_Fish] #1023349
06/30/11 04:26 PM
06/30/11 04:26 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
Ground strap on engine...
Re: serrated washer under ground and neg battery cable? [Re: FJ5_Fish] #1023350
06/30/11 04:31 PM
06/30/11 04:31 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
One style of firewall screw....this one has a flange with built-in serrations under the head of it. The ballast resistor and voltage regulator are using the serrated type captive spin washer screw in this pic.
Re: serrated washer under ground and neg battery cable? [Re: FJ5_Fish] #1023351
07/01/11 08:53 AM
07/01/11 08:53 AM
PA
BTTG Offline OP
BTTG  Offline OP
PA
Thanks a bunch. appreciate your effort....very helpful.
