Weight Distribution??
#1022626
06/29/11 10:41 AM
06/29/11 10:41 AM
Posts: 690 New Hampshire, USA
oldiron
New Hampshire, USA
Am fighting traction issues 10.79 to 11.20 from 1 pass to the next (hook once, blow the tires off the next). Cant't seem to get consistency with a clutch adjustment - if I loosen it enough to hook, then I get the big slip Stick car, stock springs, caltracs, total weight 3960 with driver, 28 x 10" tires, 4.10 gears, caltrac fronts, ranchos rear (got my hands on scales for a week) Can anyone tell me what an ideal weight distribution would be front to back, left to right? Thanks Greg
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge New New Best: 10.56 @129 68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up https://www.youtube.com/watch?v=T4jDLKwd9Gs
Re: Weight Distribution??
[Re: oldiron]
#1022627
06/29/11 12:56 PM
06/29/11 12:56 PM
Posts: 43,255 Bend,OR USA
Cab_Burge
Am fighting traction issues 10.79 to 11.20 from 1 pass to the next (hook once, blow the tires off the next). Cant't seem to get consistency with a clutch adjustment - if I loosen it enough to hook, then I get the big slipStick car, stock springs, caltracs, total weight 3960 with driver, 28 x 10" tires, 4.10 gears, caltrac fronts, ranchos rear (got my hands on scales for a week)Can anyone tell me what an ideal weight distribution would be front to back, left to right?ThanksGreg
I don't know what the ideal weight distribution would be for your car but all of the stock Mopar A,B, and E bodys I have weighed had more weight on the front, 51 % + and the left front is the heavest, RF next and then left rear next to the lightest and the RR is the lightest. Ideally you will want the right rear to have 20 to 30 lbs more weight on it than the left rear and the more weight you can get on the rear the better I have two big RV marine batterys mounted behind the right rear tire and as closest to the rear bumper and outer fenderwell as I could get it on my street strip car. If you have bucket seats you can moved the drivers side closer to the trans. tunnel and as far back as is safest also Lots of ways to move weight, some are easy and some are not All cost time and money
[Re: Cab_Burge]
#1022628
06/29/11 01:47 PM
06/29/11 01:47 PM
Posts: 10,012 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Preload the right rear about 50 lbs. Your diagonal readings should come up 100 lbs heavier on the left front/right rear. Sounds like shocks to me. It takes a pretty tight setting for a stick car. How is the rest of the car set up? Front? Front shocks? Length of rear shocks? They should have 2/3 of their travel left at rest.
[Re: gregsdart]
#1022629
06/29/11 10:40 PM
06/29/11 10:40 PM
oldiron
New Hampshire, USA
so to get weight on the righ rear, either add weight and/or load the left torsion bar? At rest the rear shocks are extended only 3 inches. I tried the shock settings between 9 and 5 (rancho single adjustable) and seemed to work the best at 5. Front end is purely stock (except calvert 90/10) and I think its not all that free but havent figured out how to loosen it up. Just trying to convince my wife to sit on a bag of salt so I can weigh with a body in it. I won't tell her that I know the weight without her.
[Re: scatpacktom]
#1022631
06/29/11 11:35 PM
06/29/11 11:35 PM
oldiron
New Hampshire, USA
I could see the wheels turning as you looked at my car on the scales.
I feel like I could have typed your exact post Greg.
Yep Tom, you did it! Now something more to figure out. Nothing like sitting there waiting for the light trying to decide what I'll do if it hooks and what I'l do if it doesn't
Very Very Nice cars by the way
[Re: oldiron]
#1022632
06/30/11 12:03 AM
06/30/11 12:03 AM
Posts: 3,103 Phila Pa
scatpacktom
Phila Pa
Thanks Greg If it wasn't dark we could have scaled your car right there. Post your weights when you get em
[Re: oldiron]
#1022634
06/30/11 12:12 AM
06/30/11 12:12 AM
scatpacktom
Phila Pa
How about with no weight and you in the seat? You cant get it closer with the torsion bars?
[Re: scatpacktom]
#1022635
07/04/11 11:08 PM
07/04/11 11:08 PM
oldiron
New Hampshire, USA
Well been playing with it and added 100 lbs to rr. Weights are LF 1022 RF 946 LR 957 RR 999 My goal was to get more weight on the RR and seemed to work better at the track, but raced pro and wasn't allowed to use the 2 step and was trying to re-learn before getting knocked out. I didn't. In the limited testing that I did, looks like the burnout is key on this car.
