wiring the cuda #1022231
06/28/11 09:15 PM
06/28/11 09:15 PM
Charleston
sixpackgut Offline OP
Drag Week Mod Champion
Charleston
one thing that always bothered me about the challenger is i couldnt reach the switches on the dash when i was belted in.
so i bought a TRICK switch panel from a local with the best of the best stuff in his cars.
so insted of doing the fuse block GM wiring kit like i did in the challenger i did this with the cuda. switch panel has circuit breakers.
almost afraid of posting this cuz someone will surely tell me its crap but if someone sees something wrong, now would be the time to find out
Re: wiring the cuda [Re: sixpackgut] #1022232
06/28/11 09:20 PM
06/28/11 09:20 PM
Orlando Florida
blown572dart Offline
Orlando Florida
Re: wiring the cuda [Re: sixpackgut] #1022233
06/28/11 09:43 PM
06/28/11 09:43 PM
ohio
HEMIDARTS Offline
HEMIDARTS  Offline
ohio
Re: wiring the cuda [Re: HEMIDARTS] #1022234
06/28/11 09:52 PM
06/28/11 09:52 PM
Arizona
Chris'sBarracuda Offline
Arizona
Crap.. You just reminded me that I'm supposed to call Gil @ Speedwire.. He's making my new system..
Your's looks awesome though.. I like..
I don't have the time or the talent..
Chris..
Re: wiring the cuda [Re: sixpackgut] #1022235
06/28/11 09:58 PM
06/28/11 09:58 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
Looks real good. Only suggestion I would make is to maybe use the molded connectors for the relays. If you have to replace a relay or have the wiring apart for some reason, the connectors make it real simple to get all the wires back in the correct position.
Re: wiring the cuda [Re: PC-CHARGER] #1022236
06/28/11 10:08 PM
06/28/11 10:08 PM
Charleston
Charleston
thanks, that's good advise and i do have them but they have wires comming out of them. i need to find the terminals that fit inside and i could redo them like that no problem. it was something i thought about already
Re: wiring the cuda [Re: sixpackgut] #1022237
06/28/11 11:58 PM
06/28/11 11:58 PM
Delray beach, Florida
P
Performance Only Offline
P
why not use the wires you need and remove the ones you don't? by the way, there's nothing special about the terminals. pop one out and you'll see what i mean. oh, almost forgot, i see a crooked wire, see it????
machine shop owner and engine builder
Re: wiring the cuda [Re: Performance Only] #1022238
06/29/11 12:27 AM
06/29/11 12:27 AM
Charleston
Charleston
the terminals have the clippy things to hold them in place. the retard and nitrous stuff not wired up yet. that is 2 days of work a couple hours a night.
Re: wiring the cuda [Re: sixpackgut] #1022239
06/29/11 12:39 AM
06/29/11 12:39 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Hey, it looks fine and organized. I too like the premolded pigtails for the relays. But I have a relay wired up just like yours for the fuel pump in the trunk of my car.
It takes alot of extra time, but I also like to use the epoxy heat shrinkwrap at all the wire terminal connections.
Re: wiring the cuda [Re: Sport440] #1022240
06/29/11 01:38 AM
06/29/11 01:38 AM
pacific northwest
Stroker Scamp Offline
pacific northwest
looks good, way nicer than the junk in my car
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: wiring the cuda [Re: sixpackgut] #1022241
06/29/11 01:45 AM
06/29/11 01:45 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
I cured that by sliding a piece of hose over the toggle.
home of the
Sox and Martin Hemi Duster
Re: wiring the cuda [Re: sixpackgut] #1022242
06/29/11 02:41 AM
06/29/11 02:41 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I really like it and have been rewiring different areas on my dart like, relaying my headlights and cleaning stuff up under the dash. I`d like to get a Painless or equal wiring kit and rewire the WHOLE car from scratch and end up w/something similar to what you have there.
Re: wiring the cuda [Re: HEMIFRED] #1022243
06/29/11 08:47 AM
06/29/11 08:47 AM
Charleston
Charleston
its simple things like that i never think of
Re: wiring the cuda [Re: sixpackgut] #1022244
06/29/11 09:22 AM
06/29/11 09:22 AM
Indy
FlyFish Offline
FlyFish  Offline
Indy
Looks GREAT!
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: wiring the cuda [Re: FlyFish] #1022245
06/29/11 09:24 AM
06/29/11 09:24 AM
tboomer Offline
tboomer  Offline
Nice work,Ray!
Re: wiring the cuda [Re: sixpackgut] #1022246
06/29/11 09:30 AM
06/29/11 09:30 AM
Out West
408strokerdart Offline
Out West
www.delcity.com for your electrical component needs. They sell the kit that has the terminals and molded plug.....I think under $2 each. I keep alot of items in my stash of parts.
Re: wiring the cuda [Re: sixpackgut] #1022247
06/29/11 09:46 AM
06/29/11 09:46 AM
an8sec70cuda Offline
Looks nice Ray! Wanna do my cuda next?
CHIP
'06 GMC 2500HD LBZ Duramax
Re: wiring the cuda [Re: an8sec70cuda] #1022248
06/29/11 10:03 AM
06/29/11 10:03 AM
Charleston
Charleston
I would need the car at my shop for awhile and i would have to test it repeatedly for a couple weeks to make sure no wires wiggle loose
