904 Shifts high #102128
08/09/08 09:33 PM
08/09/08 09:33 PM
Millinocket, Maine
JonC Offline OP
JonC  Offline OP
Millinocket, Maine
340, 904,3.23's. When putting my foot in the carb the engine revs for a second when it kicks down to second gear and then is normal. What is wrong?
Re: 904 Shits high [Re: JonC] #102129
08/09/08 09:36 PM
08/09/08 09:36 PM
delivering your oil
nutso suave Offline
nutso suave  Offline
delivering your oil
904 Shits high
most hilarious misspelling ever.
Re: 904 Shits high [Re: nutso suave] #102130
08/09/08 09:40 PM
08/09/08 09:40 PM
Millinocket, Maine
JonC Offline OP
JonC  Offline OP
Millinocket, Maine
Holy shift, I spelled it wrong!!+
Re: 904 Shits high [Re: nutso suave] #102131
08/09/08 09:40 PM
08/09/08 09:40 PM
Madera, CA.
MowP4rsn Offline
MowP4rsn  Offline
Madera, CA.
904 Shits high
How did THAT get through????
Re: 904 Shits high [Re: MowP4rsn] #102132
08/09/08 09:43 PM
08/09/08 09:43 PM
delivering your oil
nutso suave Offline
nutso suave  Offline
delivering your oil
as for the question...i have no clue. is the engine revving before the shift or is the engine bogging before the shift and then responding after the shift?
Re: 904 Shits high [Re: MowP4rsn] #102133
08/09/08 09:46 PM
08/09/08 09:46 PM
the automatic moparts editor is on the blink & a day or so ago a post with a link to an eGay ad was allowed to stand EDIT almost forgot,I would adj the bands.
Re: 904 Shits high [Re: nutso suave] #102134
08/09/08 09:55 PM
08/09/08 09:55 PM
Millinocket, Maine
JonC Offline OP
JonC  Offline OP
Millinocket, Maine
Engine is not bogging, going 45 MPH and come down on it it revs up some and then comes back down. I had the tranny "refreshed" and it didn't do it before. Kickdown is adjusted right.
Re: 904 Shits high [Re: JonC] #102135
08/09/08 10:05 PM
08/09/08 10:05 PM
we better see what Kunkel has to say. EDIT I reread your post & it has been acting this way ever since it was "freshened"?
Re: 904 Shits high [Re: RapidRobert] #102136
08/09/08 10:09 PM
08/09/08 10:09 PM
Kirkland, Washington
Pacnorthcuda Offline
Agreed, but I will say I know from experience that loose bands can cause 'rpm flare' during the shift. I would suspect either worn bands or a severe need of a band adjustment.
Re: 904 Shits high [Re: JonC] #102137
08/09/08 10:11 PM
08/09/08 10:11 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Double check the kickdown band with the pan off so you can grab the lever and move it by hand. It should move about 1/8th inch at the tip, mabey a fraction more or less depending on the ratio but 1/8th is about perfect. If you are positive it is good then pull the VB and pull the front band apply piston out and check the sealing rings. You can also check for proper functioning with air when the VB is removed and the piston and band all in place. Last thing I discovered after going through all this on a 904 doing the exact thing you describe, I had been useing ATF+4 and after about 3 fills and fooling with everything in the kickdown band apply circuits and no luck it was getting expensive and I was out of ideas. Finally one of the local tranny gurus here said the new fluid had way less friction makeing ability to give the newer trans smoother shifts. He recomended I refill it with typy F and I did and the problem was 100% gone. I have pretty much always used type F in old mopars and I will always use it. It made all the shifts better.
Re: 904 Shits high [Re: HotRodDave] #102138
08/09/08 10:14 PM
08/09/08 10:14 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I do agree to listen to John Kunkel he is purty smart, I just slept at a super 8 a couple years ago.
Re: 904 Shifts high [Re: JonC] #102139
08/09/08 10:31 PM
08/09/08 10:31 PM
Millinocket, Maine
JonC Offline OP
JonC  Offline OP
Millinocket, Maine
Thanks Mod.
Re: 904 Shifts high [Re: JonC] #102140
08/10/08 04:21 PM
08/10/08 04:21 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Previous advice is spot on. When you floor it to kickdown, the front clutch is releasing but the kickdown band isn't applying right away so the rpm's flare up.
Adjust the kickdown band; if that doesn't help there is a problem with the band or the servo.
Re: 904 Shifts high [Re: John_Kunkel] #102141
08/10/08 08:23 PM
08/10/08 08:23 PM
Millinocket, Maine
JonC Offline OP
JonC  Offline OP
Millinocket, Maine
I've never opened up a transmission before, is this something I can do myself? And can someone walk me through it?
Re: 904 Shifts high [Re: JonC] #102142
08/10/08 08:45 PM
08/10/08 08:45 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
We'll help.
First pull the pan, take all the back row of bolts off then one side then the other( so all the fluid comes out the back and is easier to catch) then loosen the front row then remove the front row and hold the pan from falling.
Then you got to look for the front band apply lever. It will be located on the piston at the front of the trans. Grab the tip over the piston with two fingers and firmly pull it up and down, it should move about 1/8th inch.
Report back to us at that point before putting it back together or adjusting it.
Re: 904 Shifts high [Re: HotRodDave] #102143
08/11/08 10:02 AM
08/11/08 10:02 AM
Millinocket, Maine
JonC Offline OP
JonC  Offline OP
Millinocket, Maine
I will, it will be a few days tho. And thanks!
Re: 904 Shifts high [Re: JonC] #102144
08/11/08 03:04 PM
08/11/08 03:04 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
No need to pull the pan to adjust the kickdown band, it's the external adjuster.
Loosen the 3/4" jam nut, back it off several turns, tighten the adjuster just snug with a short wrench, back the adjuster off two turns, hold the adjuster while tightening the jam nut.
If that doesn't cure the flareup the pan can then be removed for a look see.
Re: 904 Shifts high [Re: John_Kunkel] #102145
08/14/08 11:39 AM
08/14/08 11:39 AM
Millinocket, Maine
JonC Offline OP
JonC  Offline OP
Millinocket, Maine
