187 oil pan ? #1021157
06/27/11 02:09 AM
06/27/11 02:09 AM
grande prairie , ab , canada
68notch Offline OP
68notch  Offline OP
was wondering what this oil pan came off of , stamped 187 , now is on (under) 71 440 in a 68 barracuda , thought maybe that would tell me what the motor came out of , just curious , thanks guys
theres nothing as permanent as a temporary fix 70 super bee 79 red express 67 fargo 8o aspen rt
Re: 187 oil pan ? [Re: 68notch] #1021158
06/27/11 09:53 AM
06/27/11 09:53 AM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
#187 Pan 2532186 1967-1972 C Body 383 400 440
Some Same as #669 Pan . Strainer 2532264
Re: 187 oil pan ? [Re: R/T1968R/T] #1021159
06/27/11 12:13 PM
06/27/11 12:13 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
It may or may not have come with that engine originally but the 187 is one of about three pans that are known to work in the A bodies..... What is stamped on the pad to the right of the distributor? How about on the machined pad just above the oil pad on the passenger side of the block, just to the rear of the motor mount?.....
Re: 187 oil pan ? [Re: 1_WILD_RT] #1021160
06/27/11 01:42 PM
06/27/11 01:42 PM
68notch Offline OP
68notch  Offline OP
on pad by distributer
g 440
5 27 0
pass side of block
10 21 70
2538430-10
on machined pad above oil pan
1c25950
Re: 187 oil pan ? [Re: 68notch] #1021161
06/27/11 02:00 PM
06/27/11 02:00 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
g 440
5 27 0
pass side of block
10 21 70
2538430-10
1c25950
71 C barge engine , that's the pan it would have been born with .
Re: 187 oil pan ? [Re: 68notch] #1021162
06/27/11 03:22 PM
06/27/11 03:22 PM
68notch Offline OP
68notch  Offline OP
thank you, one more if i may , steel or forged crank ?
Re: 187 oil pan ? [Re: 68notch] #1021163
06/27/11 05:25 PM
06/27/11 05:25 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Steel and forged are interchangeable terms , but that one has a forged crank , not a CAST crank .
