Fuel Tank Problem #1020630
06/26/11 02:04 PM
06/26/11 02:04 PM
Brandon, Ms
cornet684me Offline OP
Brandon, Ms
i just got back from a drive in my 68'coronet, i stopped in my driveway and laid the car on the floor and spun down my driveway i hit the brakes hard then drove into my garage, i noticed a small gas spot on the concrete right under where the vent tubes are on my gas tank, i am guessing when i hit my brakes hard and forced all the gas to the front of the tank caused this, is this normal? or is something wrong with my gas line vent tube?
Re: Fuel Tank Problem [Re: cornet684me] #1020631
06/26/11 02:28 PM
06/26/11 02:28 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Maybe the vent tubes are dry rotted and have cracks in them?
Re: Fuel Tank Problem [Re: Neil] #1020632
06/26/11 03:25 PM
06/26/11 03:25 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
or the piece of rubber line that connects the steel fuel line to the tank sending unit
Re: Fuel Tank Problem [Re: Neil] #1020633
06/26/11 03:32 PM
06/26/11 03:32 PM
Brandon, Ms
Brandon, Ms
the vent lines are all new, all the rubber lines are new with new clamps, is there a way to hook up the vent tubes wrong?
the leak is on the driver's side where the vent lines are connected
Re: Fuel Tank Problem [Re: cornet684me] #1020634
06/26/11 03:39 PM
06/26/11 03:39 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
not really as long as you used the right sized hose. you might want to jack up the back of the car and look for drips. or fill it up ouch!!
Re: Fuel Tank Problem [Re: mikemee1331] #1020635
06/26/11 03:47 PM
06/26/11 03:47 PM
Brandon, Ms
Brandon, Ms
what is strange, i have been working on the car for over 4years, never had the problem before, it is only doing this when i get on the car hard and then hit the brakes hard to stop it before going into the garage, all the gas is being forced to the front of the tank.
Re: Fuel Tank Problem [Re: cornet684me] #1020636
06/26/11 03:51 PM
06/26/11 03:51 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
maybe what it's doing is coming out the filler tube area and running along the outside of the tank to the back.
Re: Fuel Tank Problem [Re: mikemee1331] #1020637
06/26/11 06:15 PM
06/26/11 06:15 PM
Brandon, Ms
Brandon, Ms
i did not think about that, i guess i will get out there and get on it in the driveway and then jack up to see where it is coming from,
you might be on to something, i did take the fuel tank back out about 3 or 4months ago and reinstalled , how does the filler tube seal?
thanks
Re: Fuel Tank Problem [Re: cornet684me] #1020638
06/26/11 06:24 PM
06/26/11 06:24 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
if memory serves, it's stuffed into a large grommet and the tube is secured to the backside of either the cross memger or the bumper.
Re: Fuel Tank Problem [Re: mikemee1331] #1020639
06/26/11 07:27 PM
06/26/11 07:27 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
yup and those grommets are big sellers...
Re: Fuel Tank Problem [Re: mikemee1331] #1020640
06/26/11 07:32 PM
06/26/11 07:32 PM
Brandon, Ms
Brandon, Ms
update: i have found were it is leaking from, it is leaking from the small vent tube, there are 2 vent holes in the tank, 1 is connected to a short piece of vent pipe about 8inches long and the end of it is just open, when i hit my brakes hard the gas comes out this vent tube and runs down my frame and tank
the other hose is connected to another vent tube that is run inside the trunk compartment.
is this vent tube suppose to be connected to something else and when i took out the tank i did not hook it back up right?
Re: Fuel Tank Problem [Re: cornet684me] #1020641
06/26/11 07:53 PM
06/26/11 07:53 PM
Brandon, Ms
Brandon, Ms
how do i fix this?
Re: Fuel Tank Problem [Re: cornet684me] #1020642
06/26/11 08:33 PM
06/26/11 08:33 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
1 attaches to the line going into the trunk. the other attaches to a small line that i believe should be held to the frame x-member.
Re: Fuel Tank Problem [Re: mikemee1331] #1020643
06/26/11 09:43 PM
06/26/11 09:43 PM
Brandon, Ms
Brandon, Ms
do i need to make the short piece of vent pipe longer? never had a problem before?
do you think i need to switch the lines that i have hooked up now and switch them?
Re: Fuel Tank Problem [Re: cornet684me] #1020644
06/26/11 10:49 PM
06/26/11 10:49 PM
Brandon, Ms
Brandon, Ms
the only thing i did change, i went from a steel 5/16 gas line to 3/8 aluminum line, could this change something?
Re: Fuel Tank Problem [Re: cornet684me] #1020645
06/26/11 11:23 PM
06/26/11 11:23 PM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
Route the vent as high as possible. Had the same problem with a near-full tank.
Re: Fuel Tank Problem [Re: DennisH ] #1020646
06/27/11 01:00 AM
06/27/11 01:00 AM
Brandon, Ms
Brandon, Ms
so from the pic. do you think i do not have the vent tube far enough up?
Re: Fuel Tank Problem [Re: cornet684me] #1020647
06/27/11 07:26 PM
06/27/11 07:26 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
i can't tell from the pic. the short vent line is attached to the rear shock x-member and should be higher than the tank.
