How can I tell a 273 from a 318 from a 340 from a 360? #1020595
06/26/11 12:45 PM
06/26/11 12:45 PM
Aurora, CO
jbeintherockies Offline OP
Aurora, CO
I though I already posted this question, but I can't find it. Maybe it got deleted?
Anyway, I simply want to know how I can visually tell the different LA engines from one another (not disassembled)? If someone tells me they have a 340 in their car that I am thinking about buying, how can I tell it is a 340 versus a 318 or 273 or 360?
Also, how can I tell a carburated magnum engine versus the LA engines? All of these questions apply to an engine residing in a car.
Thank you in advance.
Re: How can I tell a 273 from a 318 from a 340 from a 360? [Re: jbeintherockies] #1020596
06/26/11 12:56 PM
06/26/11 12:56 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Drivers side of block theres a fairly large cast in number... In that number you will see the engine displacement....Also on the front face of the block, just below the drivers cylinder head you'll find a series of stamped numbers... The displacement will be stamped there too...
Re: How can I tell a 273 from a 318 from a 340 from a 360? [Re: jbeintherockies] #1020597
06/26/11 12:58 PM
06/26/11 12:58 PM
Crofton, Ky.
rattler Offline
rattler  Offline
Crofton, Ky.
If you don't mind crawling under the car, the engine size and build date are cast on the side of the block just above the freeze plugs. I forget which side.
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
Re: How can I tell a 273 from a 318 from a 340 from a 360? [Re: 1_WILD_RT] #1020598
06/26/11 01:04 PM
06/26/11 01:04 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
340 was always a 4 barrel. 360 2 barrel had a much larger Holley 2 barrel than the small 2 barrel that the 318/273 had. 340 only available in A bodies 68/73 or E bodies 70/73.
Re: How can I tell a 273 from a 318 from a 340 from a 360? [Re: jbeintherockies] #1020599
06/26/11 01:08 PM
06/26/11 01:08 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
LA engine valve cover has 5 bolts, Magnums use 10.
Re: How can I tell a 273 from a 318 from a 340 from a 360? [Re: OzHemi] #1020600
06/26/11 01:17 PM
06/26/11 01:17 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Oil pan on 360 has different diameter ends on it. 273/318/340 are both same size. 360 car pan for A, B, E are stamped 392 on the bottom - and where the sump drops down, it is approx. 3" back from the front of the lip of the pan, C body 360 oil pan is stamped different number (think it may be 789 ???) and distance from sump to front lip is approx. 1.5" . . . . 360 truck oil pan is rear sump.
I just got schooled in this after getting a 360 rebuilt and having to locate a pan for it !
As others have stated, have to look on the side of the block to see the casting numbers (i.e. displacement size) . . .
Cheers
Mark
Re: How can I tell a 273 from a 318 from a 340 from a 360? [Re: OzHemi] #1020601
06/26/11 01:54 PM
06/26/11 01:54 PM
Aurora, CO
Aurora, CO
What about the magnum engine blocks? Do they also have the displacement cast into it?
Also, I was told the magnum engine blocks (I think they started in 91 correct?) have better oiling and cooling passages. Is this true? How do they compare to the older 360 blocks in terms of strength? This question goes out to everyone.
Re: How can I tell a 273 from a 318 from a 340 from a 360? [Re: jbeintherockies] #1020602
06/26/11 02:01 PM
06/26/11 02:01 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Magnum block have a crank sensor mount at the rear of the block on the passenger side kind of near the top of the bell housing. Yes they have cast into the side a number and in there will be either 318 or 360.
Water passages are the same and oiling is a little different, they oil the rockers from the pushrod instead of through the shaft. To tell if it has magnu heads look for the verticle intake bolts instead of nearly horizontal ones on an LA. However, that can be changed through re-drilling and so can the valve covers, simply by putting 5 bolt covers on magnu heads because the 5 holes still line up with 5 of the ten on a magnum.
Re: How can I tell a 273 from a 318 from a 340 from a 360? [Re: jbeintherockies] #1020603
06/26/11 02:05 PM
06/26/11 02:05 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
Biggest advantage is the roller cam. Less worry about no zinc in modern oil.
My 318 is now a 5.2L for that reason.
BTW we are fairly close to each other in Aurora.
Craig
Re: How can I tell a 273 from a 318 from a 340 from a 360? [Re: MoparforLife] #1020604
06/26/11 03:18 PM
06/26/11 03:18 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
340 only available in A bodies 68/74 or E bodies 70/74.
Also available in 71-73 B-bodies...
Re: How can I tell a 273 from a 318 from a 340 from a 360? [Re: denfireguy] #1020605
06/27/11 07:39 PM
06/27/11 07:39 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Craig
Hmm, mid 85 and later 318's and 89-91 360's had roller cams.
Don't be the exception.
Re: How can I tell a 273 from a 318 from a 340 from a 360? [Re: Supercuda] #1020606
06/28/11 02:33 AM
06/28/11 02:33 AM
Spokane Washington
ScottSmith_Harms Online content
Mr Wizzard
ScottSmith_Harms  Online Content
Mr Wizzard
Spokane Washington
Easy, any 60's to early 70's SB has the displacement stamped right on the front of the block. The catch is that you may have to dig off grease and scrape paint to see it and the PS pump can get in the way as well.
Re: How can I tell a 273 from a 318 from a 340 from a 360? [Re: ScottSmith_Harms] #1020607
06/28/11 02:34 AM
06/28/11 02:34 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
closer look
Re: How can I tell a 273 from a 318 from a 340 from a 360? [Re: ScottSmith_Harms] #1020608
06/28/11 12:25 PM
06/28/11 12:25 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
My 68 273 did not have any thing stamped there and I have seen quite a few other motors in that time period that that had nothing stamped there. Any idea why some don't have nothing there?
Re: How can I tell a 273 from a 318 from a 340 from a 360? [Re: HotRodDave] #1020609
06/28/11 10:03 PM
06/28/11 10:03 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Maybe yours was a Warranty block? Marine block?
Actually, I've never seen a small block that did not have the stamped numbers on the front of the block. But they are often stamped shallow, or incomplete, full of paint or grease, and its very easy to miss them if you are not specifically looking for it.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: How can I tell a 273 from a 318 from a 340 from a 360? [Re: ScottSmith_Harms] #1020610
06/28/11 11:33 PM
06/28/11 11:33 PM
Aurora, CO
Aurora, CO
closer look
That was very helpful. I actually thought it was cast into the drivers (?) side of the block; more like an emboss versus a stamp.
Is the CID embossed on the engine blocks also?
Re: How can I tell a 273 from a 318 from a 340 from a 360? [Re: jbeintherockies] #1020611
06/29/11 09:05 AM
06/29/11 09:05 AM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
yes, the engine size is also cast in large numbers on the driver side of the block. The numbers are about 1" tall if I remember correctly. Unfortunately, they are nearly behind the starter, so they can be real tough to see if you can't get under the car and the block is greasy.
Re: How can I tell a 273 from a 318 from a 340 from a 360? [Re: MoparforLife] #1020612
06/29/11 04:40 PM
06/29/11 04:40 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
340s were also available in B-bodies.
Getting the info off the block is a good start but other parts do get mixed in over the years. I had a '71 340 Demon that had a 318 block swapped into it under the 340 top end. I also got a 340 engine out of an A100 van (not original of course). You gotta look.
