How can I tell a 273 from a 318 from a 340 from a 360?
#1020595
06/26/11 12:45 PM
06/26/11 12:45 PM
Posts: 220 Aurora, CO
jbeintherockies
Aurora, CO
I though I already posted this question, but I can't find it. Maybe it got deleted? Anyway, I simply want to know how I can visually tell the different LA engines from one another (not disassembled)? If someone tells me they have a 340 in their car that I am thinking about buying, how can I tell it is a 340 versus a 318 or 273 or 360? Also, how can I tell a carburated magnum engine versus the LA engines? All of these questions apply to an engine residing in a car. Thank you in advance.
Re: How can I tell a 273 from a 318 from a 340 from a 360?
[Re: jbeintherockies]
#1020596
06/26/11 12:56 PM
06/26/11 12:56 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Drivers side of block theres a fairly large cast in number... In that number you will see the engine displacement....Also on the front face of the block, just below the drivers cylinder head you'll find a series of stamped numbers... The displacement will be stamped there too...
#1020597
06/26/11 12:58 PM
06/26/11 12:58 PM
Posts: 773 Crofton, Ky.
rattler
Crofton, Ky.
If you don't mind crawling under the car, the engine size and build date are cast on the side of the block just above the freeze plugs. I forget which side.
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
#1020599
06/26/11 01:08 PM
06/26/11 01:08 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
LA engine valve cover has 5 bolts, Magnums use 10.
[Re: OzHemi]
#1020601
06/26/11 01:54 PM
06/26/11 01:54 PM
jbeintherockies
Aurora, CO
What about the magnum engine blocks? Do they also have the displacement cast into it?
Also, I was told the magnum engine blocks (I think they started in 91 correct?) have better oiling and cooling passages. Is this true? How do they compare to the older 360 blocks in terms of strength? This question goes out to everyone.
#1020602
06/26/11 02:01 PM
06/26/11 02:01 PM
Posts: 12,422 Kalispell Mt.
HotRodDave
Kalispell Mt.
Magnum block have a crank sensor mount at the rear of the block on the passenger side kind of near the top of the bell housing. Yes they have cast into the side a number and in there will be either 318 or 360.
Water passages are the same and oiling is a little different, they oil the rockers from the pushrod instead of through the shaft. To tell if it has magnu heads look for the verticle intake bolts instead of nearly horizontal ones on an LA. However, that can be changed through re-drilling and so can the valve covers, simply by putting 5 bolt covers on magnu heads because the 5 holes still line up with 5 of the ten on a magnum.
#1020603
06/26/11 02:05 PM
06/26/11 02:05 PM
Posts: 1,822 Colorado
denfireguy
Colorado
Biggest advantage is the roller cam. Less worry about no zinc in modern oil. My 318 is now a 5.2L for that reason. BTW we are fairly close to each other in Aurora. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: MoparforLife]
#1020604
06/26/11 03:18 PM
06/26/11 03:18 PM
Posts: 4,324 St. Louis, Mo
318 Stroker
St. Louis, Mo
340 only available in A bodies 68/74 or E bodies 70/74.
Also available in 71-73 B-bodies...
[Re: ScottSmith_Harms]
#1020608
06/28/11 12:25 PM
06/28/11 12:25 PM
HotRodDave
Kalispell Mt.
My 68 273 did not have any thing stamped there and I have seen quite a few other motors in that time period that that had nothing stamped there. Any idea why some don't have nothing there?
#1020610
06/28/11 11:33 PM
06/28/11 11:33 PM
jbeintherockies
Aurora, CO
closer look
That was very helpful. I actually thought it was cast into the drivers (?) side of the block; more like an emboss versus a stamp.
Is the CID embossed on the engine blocks also?
#1020611
06/29/11 09:05 AM
06/29/11 09:05 AM
Posts: 6,167 Maryland
GO_Fish
Maryland
yes, the engine size is also cast in large numbers on the driver side of the block. The numbers are about 1" tall if I remember correctly. Unfortunately, they are nearly behind the starter, so they can be real tough to see if you can't get under the car and the block is greasy.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: MoparforLife]
#1020612
06/29/11 04:40 PM
06/29/11 04:40 PM
Posts: 4,127 Ramona, CA
NicksGarage
Ramona, CA
340 was always a 4 barrel. 360 2 barrel had a much larger Holley 2 barrel than the small 2 barrel that the 318/273 had. 340 only available in A bodies 68/73 or E bodies 70/73.
340s were also available in B-bodies.
Getting the info off the block is a good start but other parts do get mixed in over the years. I had a '71 340 Demon that had a 318 block swapped into it under the 340 top end. I also got a 340 engine out of an A100 van (not original of course). You gotta look.
