Best/Cost Effective Drop-in Roller Lifters for SBM
#1020311
06/25/11 08:50 PM
06/25/11 08:50 PM
Posts: 1,051 The Great White North
RAMM
Just like the post title says everyone- Who sells a high quality drop in solid roller lifter for the LA small blocks that oils through pushrods? I'm aware of a couple but am not sure if there are others? Thanks in advance. J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
Re: Best/Cost Effective Drop-in Roller Lifters for SBM
[Re: RAMM]
#1020312
06/25/11 10:14 PM
06/25/11 10:14 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Don't know about your exact application. Call Bullit Cams they are a dealer for Morrell lifters. I am very happy with mine. I also had great luck with crower.
Comp Cams not so much.
Leon
[Re: MIKES_DUSTER]
#1020315
06/26/11 12:43 AM
06/26/11 12:43 AM
Posts: 1,632 Lubbock,TX
DavidDean
Lubbock,TX
Doug Herbert SB Drop-in Roller lifter for $269.00 and they are NICE!!!!!
I like them too.I've used several sets
[Re: Streetwize]
#1020320
06/26/11 08:29 PM
06/26/11 08:29 PM
Posts: 9,146 Now - Port Orange,Fla. Former...
MIKES_DUSTER
I ordered the SBM from Herbert but they were on back-order, they sustituted the Morels which are allegedly a little bit heavier duty. The bodies are comparatively longer and required a shorter pushrod but they work fine. On my block they didn't exactly drop in without a little bit of dremel work around the valley ribs.
Heres the gringing I had too do.
[Re: MIKES_DUSTER]
#1020322
06/26/11 09:19 PM
06/26/11 09:19 PM
Posts: 6,145 Melbourne , Australia
LA360
I ordered Crane Pro series lifters for a friends engine a couple of years back. If he still has the box I can find out the part number. I think they needed a little clearancing, but they dropped in just fine, and because of the pushrod oiling, we bushed the lifter bores.
Alan Jones
[Re: LA360]
#1020323
06/27/11 02:36 PM
06/27/11 02:36 PM
Posts: 11,718 Portage,michigan
B3422W5
Portage,michigan
That is what i did on my old motor. Was an x block, so the same as a standard block is up top. Used crane ultra pro lifters, which required no clearancing at aall as i recall, and bushed the lifter bores( which is generally around a 500-550 dollar operation).Extremely trouble free for a real long time.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: J_BODY]
#1020326
06/27/11 10:32 PM
06/27/11 10:32 PM
Posts: 492 South Jersey, NJ
DragDart360
South Jersey, NJ
Ryan put Howards in my short block. Haven't ran it yet so I don't know the outcome. I think it will be successful though.
70 Dart Swinger, 2850 lbs SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
