Best/Cost Effective Drop-in Roller Lifters for SBM #1020311
06/25/11 08:50 PM
06/25/11 08:50 PM
The Great White North
RAMM Offline OP
RAMM  Offline OP
Just like the post title says everyone- Who sells a high quality drop in solid roller lifter for the LA small blocks that oils through pushrods? I'm aware of a couple but am not sure if there are others? Thanks in advance. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: Best/Cost Effective Drop-in Roller Lifters for SBM [Re: RAMM] #1020312
06/25/11 10:14 PM
06/25/11 10:14 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Don't know about your exact application. Call Bullit Cams they are a dealer for Morrell lifters. I am very happy with mine. I also had great luck with crower.
Comp Cams not so much.
Leon
Re: Best/Cost Effective Drop-in Roller Lifters for SBM [Re: RAMM] #1020313
06/25/11 10:50 PM
06/25/11 10:50 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I got Crane's through Ryan at Shady Dell , but they are offset and with the 48 degree block , fit isn't an issue.
Not cheap , but highly recommended........and when it comes to small block MoPar's , his word is pretty solid.
Re: Best/Cost Effective Drop-in Roller Lifters for SBM [Re: tubtar] #1020314
06/25/11 11:36 PM
06/25/11 11:36 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
Doug Herbert SB Drop-in Roller lifter for $269.00 and they are NICE!!!!!
Re: Best/Cost Effective Drop-in Roller Lifters for SBM [Re: MIKES_DUSTER] #1020315
06/26/11 12:43 AM
06/26/11 12:43 AM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
I like them too.I've used several sets
Re: Best/Cost Effective Drop-in Roller Lifters for SBM [Re: MIKES_DUSTER] #1020316
06/26/11 09:38 AM
06/26/11 09:38 AM
RAMM Offline OP
RAMM  Offline OP
I was looking at those last night--Do they oil through the pushrods? J.Rob
Re: Best/Cost Effective Drop-in Roller Lifters for SBM [Re: RAMM] #1020317
06/26/11 10:48 AM
06/26/11 10:48 AM
Toronto
mshred Offline
mshred  Offline
Toronto
I thought Brian at IMM had his own set or helped design a set with possibly comp?
Re: Best/Cost Effective Drop-in Roller Lifters for SBM [Re: RAMM] #1020318
06/26/11 12:35 PM
06/26/11 12:35 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Pushrod oiling will be the deal breaker for most of the cheaper ones I think.
SBC with MoPar tie bars and bushed bores ?
By the time you get all this done , you're into it for more than the $$$$$ lifters.
Re: Best/Cost Effective Drop-in Roller Lifters for SBM [Re: tubtar] #1020319
06/26/11 01:48 PM
06/26/11 01:48 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I ordered the SBM from Herbert but they were on back-order, they sustituted the Morels which are allegedly a little bit heavier duty. The bodies are comparatively longer and required a shorter pushrod but they work fine. On my block they didn't exactly drop in without a little bit of dremel work around the valley ribs.
WIZE
In Car:
Re: Best/Cost Effective Drop-in Roller Lifters for SBM [Re: Streetwize] #1020320
06/26/11 08:29 PM
06/26/11 08:29 PM
Heres the gringing I had too do.
Re: Best/Cost Effective Drop-in Roller Lifters for SBM [Re: MIKES_DUSTER] #1020321
06/26/11 08:30 PM
06/26/11 08:30 PM
#2
Re: Best/Cost Effective Drop-in Roller Lifters for SBM [Re: MIKES_DUSTER] #1020322
06/26/11 09:19 PM
06/26/11 09:19 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
I ordered Crane Pro series lifters for a friends engine a couple of years back. If he still has the box I can find out the part number. I think they needed a little clearancing, but they dropped in just fine, and because of the pushrod oiling, we bushed the lifter bores.
Alan Jones
Re: Best/Cost Effective Drop-in Roller Lifters for SBM [Re: LA360] #1020323
06/27/11 02:36 PM
06/27/11 02:36 PM
Portage,michigan
B3422W5 Online content
B3422W5  Online Content
Portage,michigan
That is what i did on my old motor. Was an x block, so the same as a standard block is up top. Used crane ultra pro lifters, which required no clearancing at aall as i recall, and bushed the lifter bores( which is generally around a 500-550 dollar operation).Extremely trouble free for a real long time.
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Best/Cost Effective Drop-in Roller Lifters for SBM [Re: B3422W5] #1020324
06/27/11 02:39 PM
06/27/11 02:39 PM
I did not have to do any gringing to the lifter bores,just the block where the rivet would rub a little.
Re: Best/Cost Effective Drop-in Roller Lifters for SBM [Re: MIKES_DUSTER] #1020325
06/27/11 10:26 PM
06/27/11 10:26 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
We ran comp cams rollers in our stroked 340. Had a porous head issue after 15 passes so we tore it down. I'd say 1/2 of the lifter bodies had cracks in them. Have no idea why. We replaced them with the lifters Brian at IMM offered. We'll find out this winter on how they are holding up. So far the engine is running great.
Re: Best/Cost Effective Drop-in Roller Lifters for SBM [Re: J_BODY] #1020326
06/27/11 10:32 PM
06/27/11 10:32 PM
South Jersey, NJ
DragDart360 Offline
DragDart360  Offline
South Jersey, NJ
Ryan put Howards in my short block. Haven't ran it yet so I don't know the outcome. I think it will be successful though.
70 Dart Swinger, 2850 lbs
SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
