Gear Ratios for 1/4 mile small blocks #1020187
06/25/11 01:18 PM
06/25/11 01:18 PM
Raleigh N.C
hemiparts Offline OP
"Missile Pilot"
"Missile Pilot"
Raleigh N.C
We are getting the Duster motor back together and ready for the Div2 race in August, what gear ratio are ya'll running in a small block with a 29.5 in tall tire. We have been running a 4.88, but have given some thought to backing it down some to lower the trap rpm. We are using a 5500 stall converter with a stock gear 727 and a .590 lift 312/312 duration cam in a stock stroke 343 cid engine. We apperciate all ya'lls help as always
Chris
Re: Gear Ratios for 1/4 mile small blocks [Re: hemiparts] #1020188
06/25/11 01:49 PM
06/25/11 01:49 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
I use 28" tire with 4.56's
Re: Gear Ratios for 1/4 mile small blocks [Re: MIKES_DUSTER] #1020189
06/25/11 01:59 PM
06/25/11 01:59 PM
ill
dennismopar73 Offline
ill
430/ 456 either one do fine
Re: Gear Ratios for 1/4 mile small blocks [Re: dennismopar73] #1020190
06/25/11 03:20 PM
06/25/11 03:20 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
What is your trap rpm? Seems like you could easily cross the stripe at 7k which I don't see the problem.
Re: Gear Ratios for 1/4 mile small blocks [Re: viperblue72] #1020191
06/25/11 03:35 PM
06/25/11 03:35 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
She sounds like a spinner to me.
I guess without knowing where peak power comes in , the best I could do is a bad guess.
I think if you cross at 500 r.p.m. over peak , you are getting the most out of it.
More r.p.m. is just more noise if it ain't pulling.
Re: Gear Ratios for 1/4 mile small blocks [Re: hemiparts] #1020192
06/25/11 03:52 PM
06/25/11 03:52 PM
SoCal
Brian Hafliger Offline
SoCal
Chris
Does the power seem to fall off before 7500rpm?
Brian Hafliger
Re: Gear Ratios for 1/4 mile small blocks [Re: hemiparts] #1020193
06/25/11 04:44 PM
06/25/11 04:44 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
I went from 4.56 to 4.88 in my Duster and there wasn't a whole lot of difference except 60' got a little more consistant, and it was easier to miss the 1-2 shift . This is w/2.74 low(904)
Of course the whole combo has to be considered. Mine was 254@.050 ported j's , strip dominator intake.
Yeah, it's got a smallblock.
Re: Gear Ratios for 1/4 mile small blocks [Re: 340B5] #1020194
06/25/11 05:02 PM
06/25/11 05:02 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
5000 stall 440ci sb 3.91 28x10.5 trap 7000g's
Re: Gear Ratios for 1/4 mile small blocks [Re: fishy340] #1020195
06/25/11 05:20 PM
06/25/11 05:20 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
6.17 let her scream
Leon
Re: Gear Ratios for 1/4 mile small blocks [Re: Leon441] #1020196
06/25/11 09:05 PM
06/25/11 09:05 PM
western PA
stevet340 Online content
stevet340  Online Content
western PA
6.17 let her scream
Leon
I run 5.86 gears in my 340, spin it up...
Re: Gear Ratios for 1/4 mile small blocks [Re: stevet340] #1020197
06/25/11 10:48 PM
06/25/11 10:48 PM
south central pa
bdaz smblk Offline
bdaz smblk  Offline
south central pa
Maybe I should rev my car harder looking at what gears u guy's run.I have a 440 cube with 7,500 conv and 4.86 gear with a 29.5x10.5 tire.
3120lb, small block, 10.5" tire, NA, through exhaust, full int, WITH 83/4 REAR, 9.0 at 150mph
Re: Gear Ratios for 1/4 mile small blocks [Re: bdaz smblk] #1020198
06/25/11 10:53 PM
06/25/11 10:53 PM
ill
ill
Re: Gear Ratios for 1/4 mile small blocks [Re: dennismopar73] #1020199
06/25/11 11:45 PM
06/25/11 11:45 PM
illinois
moparpiff Offline
moparpiff  Offline
illinois
I run a .02 over 360 with a 4:56, a 4:30 and now currently a 4:10 and they all have been similar. I have only noticed a difference in mph and of course now the 4:10 I am lacking motor for with the 29.5x13.5 tire in high gear. I shift at 6300 and trap right about 6000.
Re: Gear Ratios for 1/4 mile small blocks [Re: bdaz smblk] #1020200
06/26/11 12:24 AM
06/26/11 12:24 AM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
I ran a 33" tire with that gear at 150. Keep that in mind.
Leon
Re: Gear Ratios for 1/4 mile small blocks [Re: Leon441] #1020201
06/26/11 08:27 AM
06/26/11 08:27 AM
Guitar Jones Offline
I run a 4.86 with a 32" tall tire, shift at 7200 go through the lights about the same. When I had the 340 I used 5.13's with a 29.5 tire, shifted at 8000, whent through the lights about 8000, but I had W5's and a bigger cam.
Re: Gear Ratios for 1/4 mile small blocks [Re: Guitar Jones] #1020202
06/26/11 10:26 AM
06/26/11 10:26 AM
Colorado Springs, Colorado
Dartthunder340 Offline
Hemiparts, I have been using 4.56's in pretty much the identical combination. I am going to switch to 5.13's this fall.
Better get inside Ma. Looks like a storm's comin'.
Re: Gear Ratios for 1/4 mile small blocks [Re: hemiparts] #1020203
06/26/11 11:42 AM
06/26/11 11:42 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Chris
Is that a roller cam and whats the total weight
Re: Gear Ratios for 1/4 mile small blocks [Re: hemiparts] #1020204
06/26/11 12:15 PM
06/26/11 12:15 PM
Az
Crizila Offline
Crizila  Offline
Az
IMO 4.56 with that tire diameter would be ideal.
Fastest 300
Re: Gear Ratios for 1/4 mile small blocks [Re: MR_P_BODY] #1020205
06/26/11 07:09 PM
06/26/11 07:09 PM
Raleigh N.C
"Missile Pilot"
"Missile Pilot"
Raleigh N.C
Chris
solid lift cam 3210 lbs total including driver.
Re: Gear Ratios for 1/4 mile small blocks [Re: hemiparts] #1020206
06/26/11 09:13 PM
06/26/11 09:13 PM
Wisconsin
BLONDE BARRACUDA Offline
Wisconsin
depends how you et. I would think 456
