Re: Gear Ratios for 1/4 mile small blocks
[Re: hemiparts]
#1020193
06/25/11 04:44 PM
06/25/11 04:44 PM
Posts: 1,532 off the grid
340B5
off the grid
I went from 4.56 to 4.88 in my Duster and there wasn't a whole lot of difference except 60' got a little more consistant, and it was easier to miss the 1-2 shift . This is w/2.74 low(904) Of course the whole combo has to be considered. Mine was 254@.050 ported j's , strip dominator intake.
Yeah, it's got a smallblock.
[Re: stevet340]
#1020197
06/25/11 10:48 PM
06/25/11 10:48 PM
Posts: 437 south central pa
bdaz smblk
south central pa
Maybe I should rev my car harder looking at what gears u guy's run.I have a 440 cube with 7,500 conv and 4.86 gear with a 29.5x10.5 tire.
3120lb, small block, 10.5" tire, NA, through exhaust, full int, WITH 83/4 REAR, 9.0 at 150mph
[Re: bdaz smblk]
#1020198
06/25/11 10:53 PM
06/25/11 10:53 PM
Posts: 2,177 ill
dennismopar73
ill
[Re: Leon441]
#1020201
06/26/11 08:27 AM
06/26/11 08:27 AM
Guitar Jones
I run a 4.86 with a 32" tall tire, shift at 7200 go through the lights about the same. When I had the 340 I used 5.13's with a 29.5 tire, shifted at 8000, whent through the lights about 8000, but I had W5's and a bigger cam.
[Re: hemiparts]
#1020203
06/26/11 11:42 AM
06/26/11 11:42 AM
Posts: 52,972 Romeo MI
MR_P_BODY
We are getting the Duster motor back together and ready for the Div2 race in August, what gear ratio are ya'll running in a small block with a 29.5 in tall tire. We have been running a 4.88, but have given some thought to backing it down some to lower the trap rpm. We are using a 5500 stall converter with a stock gear 727 and a .590 lift 312/312 duration cam in a stock stroke 343 cid engine. We apperciate all ya'lls help as always
Chris
Is that a roller cam and whats the total weight
[Re: hemiparts]
#1020204
06/26/11 12:15 PM
06/26/11 12:15 PM
Posts: 7,506 Az
Crizila
Az
IMO 4.56 with that tire diameter would be ideal.
Fastest 300
[Re: MR_P_BODY]
#1020205
06/26/11 07:09 PM
06/26/11 07:09 PM
Posts: 1,031 Raleigh N.C
hemiparts
"Missile Pilot"
"Missile Pilot"
Raleigh N.C
Chris
solid lift cam 3210 lbs total including driver.
