No fuel like an old fuel. #102000
08/09/08 06:00 PM
08/09/08 06:00 PM
Anonymous OP
Anonymous OP
I am at my wits end, and the money is coming to an end too!
I recently got my car back from shop after having engine rebuilt, car sat before that and since for around 3 years.
I did not drain gas from car when I stored it. For 3 years. I then took it to the mechanic where it sat another 6 months.
When I got it back from the mechanic car ran fine then I kept running out of gas. Then I find that if I hooked up gas line to a plastic bottle full of gas it ran fine.
So I took it to the mechanic where he found someone had ran a screw up into the gas tank with some sort of caulk to seal it.
He figured the slime from the screw got in to the gas line and clogged it up. He dropped the gas tank, said gas tank was clean as a whistle, he then blew out the gas lines, fixed the hole witn a tin type solder using a giant soldering iron.
After picking up the car it ran fine, for about 25 miles. It happened the second day after I got it back. I drove around for about a half hour. Came home for about and hour then went to get in it and, it did not make it 100 yards, shutting down.
I ran the gas out of the carb and gas line, I guess trying to restart it. Walked back to the house got the plastic jug ran the line into that
primed the carb and the car is now running from gas in the jug.
Only thing left I can think of is the gas lines are fouled up, or I need somesort of vented gas cap. Are there any other senarios that I might not thave thought of. Please if you can't help send help. Thanks Mowpar
Re: No fuel like an old fuel. #102001
08/09/08 06:53 PM
08/09/08 06:53 PM
Montana
FuryUs Offline
FuryUs  Offline
Montana
Drive it without a cap for a while and you'll know if you need a vented cap or not. I had one do the same thing and it was the pickup in the tank that was clogged.
Re: No fuel like an old fuel. [Re: FuryUs] #102002
08/09/08 06:55 PM
08/09/08 06:55 PM
Kirkland, Washington
Pacnorthcuda Offline
Or when it stops running just remove the cap, listen for the woooosh, and see if it starts again.....
Re: No fuel like an old fuel. [Re: Pacnorthcuda] #102003
08/09/08 08:27 PM
08/09/08 08:27 PM
you are running a jug of gas to the inlet side of the pump? as opposed to the jug gravity feeding to the carb? I am wanting to eliminate the pump here.
Re: No fuel like an old fuel. [Re: RapidRobert] #102004
08/09/08 10:46 PM
08/09/08 10:46 PM
Anonymous OP
Anonymous OP
Yes the pump is doing its job of sucking gas from the temp gas supply under the hood. The gas is currently going through the filter so it is no clogged.
The shop took the tank out and fixed a hole in the tank, and blew out the lines but I guess they could have missed the pick up unit being clogged.
Re: No fuel like an old fuel. #102005
08/09/08 10:54 PM
08/09/08 10:54 PM
alright, the pump is Ok. This only leaves hole/loose connection in gas line, problem with pickup or as mentioned gas cap.keep us posted. EDIT & its a fuel DELIVERY problem & the carb bowl is clean?
Re: No fuel like an old fuel. [Re: RapidRobert] #102006
08/10/08 09:25 AM
08/10/08 09:25 AM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
You did'nt mention anything about a carb cleaner so...Don't forget to add a good carb cleaner to the fuel you add so it can flush the delivery system...It could simply be the carb is a little gummed up...Where's your fuel filter {in line} now ???One of those NAPA plastic filters plumbed in line{temporarily} before the pump would'nt be a bad idea until the fuel issue is solved...It'll catch any crap coming down the line and also make for a quick inspection wether or not the fuel is there...Also,you could disconnect the fuel line at the pump and blow back throught the line to see if it's clogged...
