RB intake on B engine #1019980
06/24/11 11:19 PM
06/24/11 11:19 PM
Tucson, Arizona
MRMOPAR Offline OP
MRMOPAR  Offline OP
Tucson, Arizona
Specifically, I have 440-1 heads on a B engine and thought at one time there were "spacers" to run RB intakes on the B block. I have no problem machining something like that up if it will work. (Or modify some type of existing spacer)
68 RR 528" INDY MAXX 07 2500 CTD Southwest International Raceway - IHRA - Tucson, AZ
Re: RB intake on B engine [Re: MRMOPAR] #1019981
06/24/11 11:26 PM
06/24/11 11:26 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
The RB intake is too wide. Spacers will be no help.
Getting old just means you were smarter than some and luckier than others.
Re: RB intake on B engine [Re: MRMOPAR] #1019982
06/24/11 11:29 PM
06/24/11 11:29 PM
I think your thinking of the Mopar Stage 6 heads only Not the 440-1 I recently swithed a set of 440-1 from a 440 block to my 400 stroker motor, I had to use a 440-3 intake on the 440 block and a 400-3 on the low deck
