Hilborn carb hats.............................. #1019649
06/24/11 02:23 PM
06/24/11 02:23 PM
State of confusion
Thumperdart Offline OP
State of confusion
I`m thinking about ditching my 6-pac hood/scoop combo and gettin a flat pin on and sticking the hilborn hat through it. Do these actually work or are they for looks? I want my air inlet higher and figured this was an easy way to do it. Thankxxxx...........
Re: Hilborn carb hats.............................. [Re: Thumperdart] #1019650
06/24/11 03:32 PM
06/24/11 03:32 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Mopar Performance
Re: Hilborn carb hats.............................. [Re: moparniac] #1019651
06/24/11 04:04 PM
06/24/11 04:04 PM
State of confusion
State of confusion
Not injector hats but the single piece like you see on blower motors or tunnel ram setups and like the one 6packgut has.
Re: Hilborn carb hats.............................. [Re: Thumperdart] #1019652
06/24/11 04:06 PM
06/24/11 04:06 PM
Guitar Jones Offline
I have one on top of my two 750's. Works fine.
Re: Hilborn carb hats.............................. [Re: Guitar Jones] #1019653
06/24/11 04:18 PM
06/24/11 04:18 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
i have never really experimented with my hat because its a real pain to take off and on but i made a new base for mine and made a few mods to make it easier so i plan on it as soon as this car is done
Re: Hilborn carb hats.............................. [Re: sixpackgut] #1019654
06/24/11 04:25 PM
06/24/11 04:25 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I have always liked that scoop.
Re: Hilborn carb hats.............................. [Re: Guitar Jones] #1019655
06/24/11 04:27 PM
06/24/11 04:27 PM
State of confusion
State of confusion
Thankxx guys.............just figured it looks better than my current scoop and would think it would actually perform better too.
Re: Hilborn carb hats.............................. [Re: sixpackgut] #1019656
06/24/11 04:31 PM
06/24/11 04:31 PM
Well I took the easy route and drilled the top, put on two wing nuts and sealed the bottom.
Re: Hilborn carb hats.............................. [Re: moparniac] #1019657
06/24/11 04:34 PM
06/24/11 04:34 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
dom it's not real! it bolts down onto a 4 barrel carb .. its an aircleaner assembly
Mopar Performance
Re: Hilborn carb hats.............................. [Re: moparniac] #1019658
06/24/11 04:51 PM
06/24/11 04:51 PM
No filters in mine, just the scoop but it did come with filters and an inlet screen, I tossed that crap though.
Re: Hilborn carb hats.............................. [Re: moparniac] #1019659
06/24/11 05:39 PM
06/24/11 05:39 PM
State of confusion
State of confusion
What do u mean it`s not real? I`ll never run w/out an air cleaner again and figured I`d get a small k&n to filter out the junk.
Re: Hilborn carb hats.............................. [Re: Thumperdart] #1019660
06/24/11 05:41 PM
06/24/11 05:41 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
well its functional anyways! there is an aircleaner thats on top of the carb and that unit encases over the aircleaner/carb thats hidden inside! yes the stacks are open for air to enter!
Mopar Performance
Re: Hilborn carb hats.............................. [Re: moparniac] #1019661
06/24/11 08:57 PM
06/24/11 08:57 PM
Johnstown
69dart Offline
69dart  Offline
Johnstown
I just picked one of these up on ebay Link for Scoop
I was going to put it on my roadster but I can't bring myself to cut the hood. If your interested I'll save you a couple bucks.
feel free to email me at bemiller@insight.rr.com if interested
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
Re: Hilborn carb hats.............................. [Re: 69dart] #1019662
06/24/11 10:01 PM
06/24/11 10:01 PM
State of confusion
State of confusion
I really like that one much better and it looks lighter.........
Re: Hilborn carb hats.............................. [Re: Thumperdart] #1019663
06/24/11 10:15 PM
06/24/11 10:15 PM
Johnstown
69dart Offline
69dart  Offline
Johnstown
Yeah I thought it looked very cool but I just can't cut a hole in my hood.
I think I paid $100 for it. Hows $80 sound? Comes with air filter and brackets to bolt to the carb.
I might try it and just leave the hood off.
68 Dart - 340
66 Belvedere - 400
Re: Hilborn carb hats.............................. [Re: Thumperdart] #1019664
06/24/11 10:25 PM
06/24/11 10:25 PM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
Go to Rex marines web site. That scoop is around $150 brand new. Can also get it an a wide varity of ano. Colors.
Re: Hilborn carb hats.............................. [Re: boatracer572] #1019665
06/25/11 08:26 PM
06/25/11 08:26 PM
Here's a pic of mine. The reason I used it is because I put a cowl scoop on the hood to cover just the single carb. Then I put the tunnel ram on and after modifying the hood for the cowl scoop I can't go back. So not having the money to buy another hood and scoop I just cut the hole and put this on it.
You've probably seen this pic already and I hate to keep posting it but I lost a lot of pics when my confuser crashed so I'm limited on what I can show you.
Re: Hilborn carb hats.............................. [Re: Guitar Jones] #1019666
06/25/11 11:00 PM
06/25/11 11:00 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
IMHO, those scoops look at home only on dual quad tunnel rams and blowers. If you really want to run that kind of a scoop, it can give you the excuse to switch to a TR setup. No down side to running a TR on a street/strip car, except maybe gas mileage.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: Hilborn carb hats.............................. [Re: DusterDave] #1019667
06/26/11 12:46 AM
06/26/11 12:46 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
They have a shorter version also for single carb setups. In the small number of times the performance history of those hats came up. It was always positive. Ive got one myself for a single carb setup after Much research.
The other scoop pictured looks like it would perform well too.
Re: Hilborn carb hats.............................. [Re: Sport440] #1019668
06/26/11 09:55 AM
06/26/11 09:55 AM
I found another pic
