340 ID and color help #1019595
06/24/11 12:16 PM
06/24/11 12:16 PM
Champaign IL
LXguy Offline OP
LXguy  Offline OP
Champaign IL
Hello:
I'm confused.
Is a 71 340 orange or blue?
If the block cast date is 6-71, is it a 71 or a 72 engine?
Anyone have a pic of the correct air cleaner for a '71?
Allpar says: "1970-71 engines were painted orange; they changed to blue in 1972-73, although some late 1971 engines ended up blue also." Is 6-71 a "later" engine?
Thanks for any help!
Steve
1971 Dodge Dart Swinger 5.9 Magnum, built 904 ET 11.70 / 113 mph Want to swap a Magnum into your Mopar? www.magnumswap.com
Re: 340 ID and color help [Re: LXguy] #1019596
06/24/11 12:28 PM
06/24/11 12:28 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I believe the change over to blue was in March or April of 71. That block would have been blue. You need to look on the block and find the assembly date. The block could have been cast quite awhile before it was assembled.
Re: 340 ID and color help [Re: burdar] #1019597
06/24/11 12:32 PM
06/24/11 12:32 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Blue for sure
Re: 340 ID and color help [Re: ademon] #1019598
06/24/11 12:33 PM
06/24/11 12:33 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
here are 71 parts
Re: 340 ID and color help [Re: ademon] #1019599
06/24/11 12:37 PM
06/24/11 12:37 PM
Champaign IL
LXguy Offline OP
LXguy  Offline OP
Champaign IL
Thanks for the help!
Where would I find the assembly date on the block?
Is there a date range where it could be either a 71 or a 72?
Want to sell that intake and/or air cleaner!?
Thanks again
Steve
Re: 340 ID and color help [Re: LXguy] #1019600
06/24/11 12:40 PM
06/24/11 12:40 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
should be on the D/S front where the head meets the block. i have a extra but don't want to part with it for some reason the date will be in Julian calendar
Re: 340 ID and color help [Re: ademon] #1019601
06/24/11 01:08 PM
06/24/11 01:08 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I have a 71 340 block that was cast in Feb 71 and it went into a 72 car - so I doubt that your motor was in a 72.
Check the VIN pad
Re: 340 ID and color help [Re: Morty426] #1019602
06/24/11 01:15 PM
06/24/11 01:15 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
for example my block has casting date of 7/70 was assembled 11/70 and did not go into the car till 4/2/71. since it was assembled 11/70 its orange but went into the car when most were getting blue engines. Not much set in stone with Chrysler!
Re: 340 ID and color help [Re: ademon] #1019603
06/24/11 01:49 PM
06/24/11 01:49 PM
Champaign IL
LXguy Offline OP
LXguy  Offline OP
Champaign IL
That's interesting. Is yours a '70 spec or '71? Weren't they lower compression in '71, or maybe that was '72.
Check the VIN pad
Do you mean its most likely mine went into a 72, rather than you doubt it went into a '72? Your block was cast earlier than mine.
Re: 340 ID and color help [Re: LXguy] #1019604
06/24/11 02:25 PM
06/24/11 02:25 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
they dropped cr in 72, mine is a 71
Re: 340 ID and color help [Re: LXguy] #1019605
06/24/11 06:55 PM
06/24/11 06:55 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Check the VIN pad
That it most likely went in to a 72
Re: 340 ID and color help [Re: Morty426] #1019606
06/24/11 07:54 PM
06/24/11 07:54 PM
MO
cdp Offline
cdp  Offline
MO
I have a 71 block that is early 71 cast date with a 400000 series 71 VIN. Block is for sure Blue.
I've seen cars with 300000 VIN's and were still blue. One being a survivor car.
Re: 340 ID and color help [Re: cdp] #1019607
06/26/11 04:57 PM
06/26/11 04:57 PM
Champaign IL
LXguy Offline OP
LXguy  Offline OP
Champaign IL
Thanks guys
Also curious, what do the first two digits on the VIN ID pad signify?
I've got one that's 0B, and one block that's 2B
Thanks,
Steve
Re: 340 ID and color help [Re: LXguy] #1019608
06/26/11 05:04 PM
06/26/11 05:04 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Thanks guys
Thanks,
Steve
0B = 1970 Hamtramck
2B = 1972 Hamtramck
Basically Year then plant the motor was installed at
