vacuum advance #1019092
06/23/11 01:52 PM
06/23/11 01:52 PM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
..O.K. i know this is might stir things up.
to use or not to use...pros/cons
if you use it...what is your build and numbers?
Re: vacuum advance [Re: can.al] #1019093
06/23/11 04:30 PM
06/23/11 04:30 PM
I use it, better mileage/keeps plugs cleaner. I do not have a specific build in mind but it does take alot of work to get spot on. 3/32" allen wrench to change when (in hg) the slope starts (easy) & soldering strips of feeler gauge on the back side of the can to limit the total amt of adv (hard)
Re: vacuum advance [Re: RapidRobert] #1019094
06/23/11 08:42 PM
06/23/11 08:42 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
Some use it, some don't. I personally don't. My tune up is more aggressive. I don't care about fuel economy. If I did I'd drive a car with a bone stock 4-banger.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: vacuum advance [Re: Junky] #1019095
06/23/11 09:18 PM
06/23/11 09:18 PM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
..vac advance has other benefits.
engine runs cleaner,more efficient,cooler and makes more power at cruz.
at wot it will have no effect.
Re: vacuum advance [Re: can.al] #1019096
06/24/11 12:10 AM
06/24/11 12:10 AM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
Sounds like you got things figured out!
11:1 440......550hp. No vacuum advance here.
Re: vacuum advance [Re: Viol8r] #1019097
06/24/11 02:09 AM
06/24/11 02:09 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I run it, I see no reason not to. Mine doesn't ping at cruise.
Re: vacuum advance [Re: can.al] #1019098
06/24/11 05:51 AM
06/24/11 05:51 AM
NL
Frederick Offline
Frederick  Offline
NL
If you can, use it.
It has benefits, like mentioned before.
However, if you have a large cam, the vacuum will fluctuate too much, causing the timing to go all over the place.
Not good for fuel economy or the engine.
In this case you'd run locked timing.
Re: vacuum advance [Re: Frederick] #1019099
06/24/11 07:37 AM
06/24/11 07:37 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I've also heard they can be slow to respond to vacuum, like when you go from cruise to WOT...giving you way too much vacuum at WOT, if you have an aggressive base tune due to a lopey cam. Plus, if you adjust the mechanical advance so that it's all in at a lower RPM, then you need less vacuum advance
with the performance oriented distributors that don't have vacuum advance, should tell you that it's not critical to have it.
run it if you want, leave it unhooked if you don't.
for what it's worth, my Dakota with EFI never gives more than 38-39 degrees of total timing. apparently the magnum head design doesn't require the advance that older heads do.
**Photobucket sucks**
Re: vacuum advance [Re: 70Cuda383] #1019100
06/24/11 09:27 AM
06/24/11 09:27 AM
arizona, usa
lokalik Offline
lokalik  Offline
arizona, usa
thanks for starting the post. is vac adv hooked up to manifold or ported vac?
Re: vacuum advance [Re: lokalik] #1019101
06/24/11 09:43 AM
06/24/11 09:43 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Factory is ported vac source .
Re: vacuum advance [Re: lokalik] #1019102
06/24/11 09:51 AM
06/24/11 09:51 AM
Berlin, N.J.
abodyjoe Offline
abodyjoe  Offline
Berlin, N.J.
curious to see where this thread goes...
i never ran it for the longest time. always ran my small blocks with the total in by about 2200 rpm and no vac advance.
recently i figured lets see if i can get some better mileage from the car and not lose any performance. i was going to set up a mp distributor i had here laying around be me being an idiot and in a rush broke a few things pulling it apart.
over the years i have heard good and bad about FBO. i figured i may as well give them a try so i can make my own informed opinion. well he set me up a distributor that has more mechanical initial timing, the same total and actually has the mechanical total come in about 500 rpm later. he also said to hook the vac. advance up to constant vac. i thought that was weird but i did like he said.
so now when i set the timing i set the initial at 14* which made the total 34* and with the vac. advance hooked up i have 31* at idle. i have to say so far i only have about 150 miles on it since i put it in but the car cruises smoother and seems to run about 5* cooler. when cruising at say 35-45 mph i do notice i need a lot less throttle then before to pick up speed. really hard to explain. you would have to had to drive the car before and after to understand i think. car starts great when cold and hot. infact i think it actually runs better cold with he extra timing. carlisle will probably be the first long trip i take with it so we will see how the mileage is then.
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
www.MoparMisfits.com
Re: vacuum advance [Re: abodyjoe] #1019103
06/24/11 10:02 AM
06/24/11 10:02 AM
...gently down the stream
LAR_414 Offline
LAR_414  Offline
I've messed with it for years in all configurations (ported vac, crusing vac), locked out timing, etc.....
Right now I run it and I've found a sweet spot that I like.
414 cube smallblock 34 degrees full out mechanical advance.
Intitial timing at 20 degrees that starts to mechanically advance up to the 34 degrees around 1500rpm, full out around 2500rpm.
Vacuum can pulls 15 degrees more for a total of 49 degrees after 2500rpm under light/no load.
Vacuum is plugged into the timed spark port on the carb,...that way it is not messing with idle.
I've found the key to good idle is having no timing fluctuation! So make sure the mechanical advance doesn't start until a few hundred rpm after idle speed, and make sure the vacuum advance doesn't kick in until crusing.
Works great.
15.5 MPG with a low 11 second 3400lbs 550hp car on pump gas!
Re: vacuum advance [Re: LAR_414] #1019104
06/24/11 10:44 AM
06/24/11 10:44 AM
BDW Offline
BDW  Offline
What kind of gears / OD?
I've got a mild 340 with 3.73's that only gets 12mpg
Re: vacuum advance [Re: BDW] #1019105
06/24/11 11:08 AM
06/24/11 11:08 AM
LAR_414 Offline
LAR_414  Offline
4.30 gears, 30" tall tires, no OD....3400rpm going 65mph down the highway. This was with the automatic trans....it will probably do better MPG with the stick that's in it now.
Also I run TWO 650 demon carbs on a cross ram.
Re: vacuum advance [Re: LAR_414] #1019106
06/24/11 05:33 PM
06/24/11 05:33 PM
New York
rarefish Offline
rarefish  Offline
New York
Not to hijack the post but, I'm getting a slight surging when driving under a light load at part throttle. A friend told me to disconnect the vacuum advance and that should solve the problem. Have not tried it yet, but does that sound right?
The car is a bone stock 68 Charger R/T. I checked the timing and found that I have 14 degs at 650 rpm. A total of 34 degs mechanical advance. Not sure at what RPM and with the vacuum reconnected I get a total of 53 degs advance. The car runs good other wise and does not ping.
Re: vacuum advance [Re: rarefish] #1019107
06/24/11 06:36 PM
06/24/11 06:36 PM
block the metering rods all the way up on the power step & take it back out for a spin/holler back
Re: vacuum advance [Re: rarefish] #1019108
06/24/11 11:11 PM
06/24/11 11:11 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
The car is a bone stock 68 Charger R/T. I checked the timing and found that I have 14 degs at 650 rpm. A total of 43 degs mechanical advance. Not sure at what RPM and with the vacuum reconnected I get a total of 53 degs advance. The car runs good other wise and does not ping.
When I had the stock police 318 four barrel in my Gran Fury, I changed ignition for lean burn to a MP kit. The car surged a little at cruising speeds you described. Disconnecting vac advanced stopped it.
Facts are stubborn things.
Re: vacuum advance [Re: can.al] #1019109
06/25/11 01:31 AM
06/25/11 01:31 AM
Overland Park, KS.
Joshs68 Offline
Joshs68  Offline
Overland Park, KS.
10.5/1 470 w [Email]265@.050[/Email] I run 20* initial w 35* total. No vaccuum advance. I am also using an FBO setup distributor and would reccommend him to anybody. He removed the vac mechanism on my dist and it came setup for a great price. Dropped in and works great.
Re: vacuum advance [Re: rarefish] #1019110
06/25/11 06:11 PM
06/25/11 06:11 PM
NL
Frederick Offline
Frederick  Offline
NL
43 Total is too much, it should be around 35 with stock heads.
It's most likely stumbling because of too much advance, plugging the vacuum advance would solve it, but isn't really the right way to do it.
I suggest you plug off the vacuum advance, check if the stumble is gone.
-If it is, limit the total mechanical advance to 35deg by welding up the advance slot.
(Trial and error, should be all in by 3000rpm)
Then re-attach the vacuum advance.
-On the other hand if the stumble isn't gone, it either needs more advance taken out, or the mixture is too lean.
Cheers
Fred
383B, 9.8:1, Lunati 60302(220/226@0.050 262/268Dur, 0.475"/0.494", Stealth heads, Performer manifold, QF SS-750-AN carb, 3.31Diff, A833 4-speed manual.
Re: vacuum advance [Re: Frederick] #1019111
06/25/11 06:17 PM
06/25/11 06:17 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I dont use it on my street/strip cars. I run a very fast mech advance all in by 1800 and I really dont need it as they run fine like that on pump gas. Ron
