Re: vacuum advance
[Re: can.al]
#1019093
06/23/11 04:30 PM
06/23/11 04:30 PM
RapidRobert
I use it, better mileage/keeps plugs cleaner. I do not have a specific build in mind but it does take alot of work to get spot on. 3/32" allen wrench to change when (in hg) the slope starts (easy) & soldering strips of feeler gauge on the back side of the can to limit the total amt of adv (hard)
Re: vacuum advance
[Re: can.al]
#1019096
06/24/11 12:10 AM
06/24/11 12:10 AM
Posts: 780 Woodinville, WA
Viol8r
Woodinville, WA
..vac advance has other benefits. engine runs cleaner,more efficient,cooler and makes more power at cruz. at wot it will have no effect.
Sounds like you got things figured out!
11:1 440......550hp. No vacuum advance here.
Re: vacuum advance
[Re: can.al]
#1019098
06/24/11 05:51 AM
06/24/11 05:51 AM
Posts: 90 NL
Frederick
NL
If you can, use it. It has benefits, like mentioned before.
However, if you have a large cam, the vacuum will fluctuate too much, causing the timing to go all over the place. Not good for fuel economy or the engine. In this case you'd run locked timing.
Re: vacuum advance
[Re: Frederick]
#1019099
06/24/11 07:37 AM
06/24/11 07:37 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I've also heard they can be slow to respond to vacuum, like when you go from cruise to WOT...giving you way too much vacuum at WOT, if you have an aggressive base tune due to a lopey cam. Plus, if you adjust the mechanical advance so that it's all in at a lower RPM, then you need less vacuum advance
with the performance oriented distributors that don't have vacuum advance, should tell you that it's not critical to have it.
run it if you want, leave it unhooked if you don't.
for what it's worth, my Dakota with EFI never gives more than 38-39 degrees of total timing. apparently the magnum head design doesn't require the advance that older heads do.
**Photobucket sucks**
Re: vacuum advance
[Re: lokalik]
#1019101
06/24/11 09:43 AM
06/24/11 09:43 AM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
thanks for starting the post. is vac adv hooked up to manifold or ported vac?
Factory is ported vac source .
Re: vacuum advance
[Re: LAR_414]
#1019104
06/24/11 10:44 AM
06/24/11 10:44 AM
Posts: 4,733 Florida
BDW
15.5 MPG with a low 11 second 3400lbs 550hp car on pump gas!
What kind of gears / OD?
I've got a mild 340 with 3.73's that only gets 12mpg
Re: vacuum advance
[Re: LAR_414]
#1019106
06/24/11 05:33 PM
06/24/11 05:33 PM
Posts: 2,252 New York
rarefish
New York
Not to hijack the post but, I'm getting a slight surging when driving under a light load at part throttle. A friend told me to disconnect the vacuum advance and that should solve the problem. Have not tried it yet, but does that sound right? The car is a bone stock 68 Charger R/T. I checked the timing and found that I have 14 degs at 650 rpm. A total of 34 degs mechanical advance. Not sure at what RPM and with the vacuum reconnected I get a total of 53 degs advance. The car runs good other wise and does not ping.
Re: vacuum advance
[Re: rarefish]
#1019107
06/24/11 06:36 PM
06/24/11 06:36 PM
RapidRobert
block the metering rods all the way up on the power step & take it back out for a spin/holler back
Re: vacuum advance
[Re: can.al]
#1019109
06/25/11 01:31 AM
06/25/11 01:31 AM
Posts: 1,472 Overland Park, KS.
Joshs68
Overland Park, KS.
10.5/1 470 w [Email]265@.050[/Email] I run 20* initial w 35* total. No vaccuum advance. I am also using an FBO setup distributor and would reccommend him to anybody. He removed the vac mechanism on my dist and it came setup for a great price. Dropped in and works great.
Re: vacuum advance
[Re: rarefish]
#1019110
06/25/11 06:11 PM
06/25/11 06:11 PM
Posts: 90 NL
Frederick
NL
Not to hijack the post but, I'm getting a slight surging when driving under a light load at part throttle. A friend told me to disconnect the vacuum advance and that should solve the problem. Have not tried it yet, but does that sound right? The car is a bone stock 68 Charger R/T. I checked the timing and found that I have 14 degs at 650 rpm. A total of 43 degs mechanical advance. Not sure at what RPM and with the vacuum reconnected I get a total of 53 degs advance. The car runs good other wise and does not ping.
43 Total is too much, it should be around 35 with stock heads. It's most likely stumbling because of too much advance, plugging the vacuum advance would solve it, but isn't really the right way to do it. I suggest you plug off the vacuum advance, check if the stumble is gone.
-If it is, limit the total mechanical advance to 35deg by welding up the advance slot. (Trial and error, should be all in by 3000rpm) Then re-attach the vacuum advance.
-On the other hand if the stumble isn't gone, it either needs more advance taken out, or the mixture is too lean.
Cheers
Fred
383B, 9.8:1, Lunati 60302(220/226@0.050 262/268Dur, 0.475"/0.494", Stealth heads, Performer manifold, QF SS-750-AN carb, 3.31Diff, A833 4-speed manual.
