Re: overheating
[Re: 68Bullit]
#1018411
06/22/11 03:34 PM
06/22/11 03:34 PM
Challenger 1
Cincinnati, Ohio
Those things could help, certainly, but I'm also thinking a brand new motor that is breaking in will naturally run warmer, maybe even as long as the first few hundred miles.
No I don't think so, I have rebuilt countless motors and they don't run hot when there new.
Re: overheating
[Re: can.al]
#1018417
06/22/11 05:17 PM
06/22/11 05:17 PM
Posts: 13 NY
KillerB
NY
340...L2316-30. xe-268, x heads, stock fan shroud,new clutch fan, 12 initial,35 tot all in at 2400, 49 tot. w/vac advance and will ping about twice when i get on it w 91 octane i tried E-10, 94 octane and it detonated badly ... makes me think lean. compression is probably borderline for iron heads
49 degree total advance, sounds a bit much. Disconnect vacuum and drive it around see if that helps.
