EFI / E85
#1017455
06/20/11 11:10 PM
06/20/11 11:10 PM
Posts: 2,034 NW Indiana
deansrr
NW Indiana
was planning on running E85 in my 340, like the idea of higher octane, running cooler and so on, purchased Quick fuel E85 Carb, but been thinking about fuel injection instead of carb. Anyone make kit for doing this, was going to go with FAST EZ-EFI, but doesn't work with E85, a flex fuel kit would be even better, any one?
1973 Road Runner
1974 Satellite (for sale)
1973 240z (wifes)
1993 Ramcharger (thanks Devil)
2002 Honda S2000
Re: EFI / E85
[Re: rbkt65]
#1017457
06/21/11 01:17 AM
06/21/11 01:17 AM
Posts: 1,305 Lakewood, Colorado
herkamer
Lakewood, Colorado
Any injection should work, the computer doesn't know what fuel you are using. Add 35% to the gasoline fuel maps and that should get you pretty close. You will need 35% bigger injectors as well. Megasquirt 2 and 3 has a flex fuel option so you can run either fuel without a map change. Utilizes the stock GM flex fuel sensor to determine ethanol content.
Matt 69 Dart Swinger 340 83 W350, Megasquirted with 46RH Old news: 72 Demon street/race mobile Latest: 70 Duster backhalf car and even more
Re: EFI / E85
[Re: deansrr]
#1017458
06/21/11 02:28 PM
06/21/11 02:28 PM
Posts: 1,938 Sonora CA
Mopar_Rich
Sonora CA
You are correct - the EZ-EFI will NOT work with E85. That's because the target AF maps will not go down low enough. Stociometric for E85 is 10:1. You'd have to step up the XFI system. BTW: The XFI directly interfaces to the Flex Fuel sensor and automatically adjusts to the fuel.
Re: EFI / E85
[Re: Mopar_Rich]
#1017459
06/21/11 02:36 PM
06/21/11 02:36 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
has anyone done this with a modified factory PCM? such as using SCT to flash custom tunes into the PCM? I've considered trying it, but I know that I'd need to first step up to bigger injectors, and maybe a stronger fuel pump too. I'm not really sure. it's basically a slightly modded 5.9L that I'd be doing this to.
can a 90% stock EFI system be converted to E85 by simply re-flashing the computer and putting in bigger injectors?
**Photobucket sucks**
Re: EFI / E85
[Re: 70Cuda383]
#1017460
06/21/11 02:39 PM
06/21/11 02:39 PM
moparpollack
Lil Herman
Lil Herman
85086
Not sure on the modification the first time I tried E-85 in a fuel injected vehicle it killed the truck. I had rented a new pick up and it messed with the computer and it wouldn't run well. ![](/ubbthreads/images/graemlins/down.gif)
