Body shop guy's, I have a quick question. #1017427
06/20/11 10:20 PM
06/20/11 10:20 PM
N of Detroit
DaveDudek Offline OP
N of Detroit
After you have a car sand blasted, it's back at your shop, you have blown all the sand out of her, what's the next step?
I talked to one guy and he said "blow the body off 100% and hit it with DP40", do your body work and everything right over that.
Another guy said after you blow the car off, acid etch the entire shell, hit it with a water hose, when it dries it will be orangeish, and hit it with DP90.
What's the correct way, I don't want any problems..... Thanks
Dave Dudek
1st Factory Stock legal car in the 10`s!!! [/b]
FAST & Factory Stock Rules: www.fastraces.org
FAST 69 Hemi RR 9.98@139
Re: Body shop guy's, I have a quick question. [Re: DaveDudek] #1017428
06/20/11 11:25 PM
06/20/11 11:25 PM
MO
cdp Offline
cdp  Offline
MO
What I learned in body shop class was to use a metal prep like 232 Dupont or similar product, wax/grease remover, then DP primer. Body work can be done over DP with proper prep for bodyfiller, etc.
I'm not a body guy by trade though.
You can also check out PPG's website for instructions and MSDS on their products.
Re: Body shop guy's, I have a quick question. [Re: DaveDudek] #1017429
06/20/11 11:41 PM
06/20/11 11:41 PM
Southeastern MI.
Q
QuickSilver Offline
mopar addict
QuickSilver  Offline
mopar addict
Q
Southeastern MI.
Dave, I would avoid hosing the car down starting rust and then priming over that. Blasted metal should never have a metal prep acid applied to it. You won't ever rinse that out of the pores and those left over salts will corrode. To me that spells trouble. The only thing I have ever done over freshly blasted metal panels is to blow off as well as possible and then I use fresh tack rags to remove any dust traces and then I like to apply several coats of DP40 epoxy primer. The DP primer has excellent adhesion characteristics already and certainly wouldn't need to be etch primed before hand. Once that stuff cures thoroughly you can't hardly scrap it off. After it has cured I do any finish work over that and have had awesome results over the years and never a blister or lift problem. Of course there are many different ways to skin a cat! Good luck! Way to make that Road Runner HONK!!!
Re: Body shop guy's, I have a quick question. [Re: DaveDudek] #1017430
06/20/11 11:50 PM
06/20/11 11:50 PM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
vacumme and blow it out like carzy, then back on the flat bed for a trip around the block and repeat step 1, step 2 one that most shops miss, d/a the whole car down with 220 grit,hand sand anywhere you cant d/a. then prep solvent the shell down 2-5 times untill rags look kinda clean.tack car with new tack rags, after that the best epoxy 2 part primer you can buy, unload the whole gallon one it, after that do your body work one panel at a time then prime with 2 part uro prime dont get crazy with that stuff more is never better and causes lots of shrinkage later. apply 2-3 fine coat wet like paint block and repeat till your arms fall off...
MOPAR OR NO CAR
Re: Body shop guy's, I have a quick question. [Re: DaveDudek] #1017431
06/21/11 01:20 AM
06/21/11 01:20 AM
Jacksonville Florida
elitecustombody Offline
Every shop has their own ways they do things,I'd shoot epoxy primer before any filler,also I would not D/A anything,blasted surface is the ultimate suface for epoxy primer IMO.
Re: Body shop guy's, I have a quick question. [Re: elitecustombody] #1017432
06/21/11 06:57 AM
06/21/11 06:57 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
.....sandblasted etched surface is the best for adhesion, I would vacumm the car out first, blowing it out last, to avoid a compounded dust film which the car has anyway from blasting, then wipe the panels down with a quality high flash enamel reducer, I prefer Dupont's etch primer Vari-prime, as it actualy etches into the surface because of it's acid base, epoxy sealer, is just a membrane, it actually has no "bite" on the metal surface,....the choice is yours, I would just recommend, whatever paint line you choose, you stick with, when you start mixing different manufacturers, you may have adhesion proplems down the road, or paint reactions....use QUALITY products, start to finish,...cheap crap doesn't get hidden, it only comes back to bit you later...
regarding "major" bodywork, I like to do all bondo work before etch priming, then a good coat of ureahthane primer builder like 2K, then block the car, 2 part putty for small surface defects/lows,...then finish the car off with approx. 3-4 coats of 2K block sanded between each coat, the last finished off with 600 grit....no wet block sanding, dry only...
final paint, I prefer Dupont Chroma Premier BC/CC, but rgardless of your choice, I spray 3 coats of base color, followed by 3-4 coats of a premium clear (Chroma Premier) then color sand with 1000 grit, followed by 1500, then 2000, then 2500, up to 3000 depending on the color,...black is best taken to 3000 grit, no compounding, just polish with 3M Finess-it II/III line of polish.....but thru-out the paint process don't allow bare hands to touch the car, or let it remain outside for periods of time not needed...
Mike
Re: Body shop guy's, I have a quick question. [Re: DAYCLONA] #1017433
06/21/11 09:50 AM
06/21/11 09:50 AM
DFW
68RRFlyer Offline
68RRFlyer  Offline
DFW
Dave,
The hardest battle is to get all the media out of the car after blasting. It does help putting it on a rotisserie and rolling it around a few times while using the air hose and vacuum (with some interesting attachments, I might add ) and focus on getting all that material out of there. The cowl and roof braces particularly come to mind. Once done, DA if you want to, but not necessary unless the blaster missed some areas. Follow that up with a good wax/de-grease session and then tack it off for a lint free shell. DPLF over that in whatever shade you chose. Bodywork over that. I've done several cars that way and no problems noted years later. Hope that helps and like what was said, ask a question to five people and be prepared for ten answers. Chose which one suits you the best with your ability/availability of materials/time, etc.
Cheers
Re: Body shop guy's, I have a quick question. [Re: 68RRFlyer] #1017434
06/21/11 01:42 PM
06/21/11 01:42 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
And when everything is done you'll still likely need to rust check the cracks.
Re: Body shop guy's, I have a quick question. [Re: elitecustombody] #1017435
06/21/11 03:17 PM
06/21/11 03:17 PM
South Dakota
hotairballoonpilot Offline
South Dakota
DO NOT ACID ETCH OR ACID PRIME SANDBLASTED METAL. EVER! Caps on to make you know. Acid pools in the pits and will cause you headach later. Didn't read all the responses just wanted this known. DP it after it is all cleaned/blown off and tack it too before you dp it. then let sit for a day and scuff the dp with 36 grit and do body work on the dp. some say you don't have to scuff the dp but I feel the more mechanical adheasion you get the better,
Corey
Contact Me about AMD Prices
Re: Body shop guy's, I have a quick question. [Re: hotairballoonpilot] #1017436
06/21/11 04:16 PM
06/21/11 04:16 PM
N of Detroit
N of Detroit
Thanks everybody.. With-in the next few weeks i'll be tearing into her.
Dave Dudek
Re: Body shop guy's, I have a quick question. [Re: hotairballoonpilot] #1017437
06/21/11 04:39 PM
06/21/11 04:39 PM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
Not to start a peeing contest but I have done this for over 30 years now. The few times I have things stripped this way anymore, not the prefered method IMO, I get the parts back to the shop. DA lightly to remove all impregnated particles. Wash down several times with DX330 or any such product. Then prime with 615/616S, DuPonts Vari Prime self etching primer. When it flashes off I cover with a quality urethane primer. Then onward we go until paint. Never once have had a problem. Just an FYI.
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
Re: Body shop guy's, I have a quick question. [Re: sixpackbee] #1017438
06/21/11 08:03 PM
06/21/11 08:03 PM
South Dakota
South Dakota
no peeing on my part either. Going off of being master certified with ppg and spraying for the last 20+ years that is what has been preached time and time again and it is in the p sheets not to apply over media blasted metal.https://buyat.ppg.com/refinishProductCatalog/ViewProduct.aspx?ProductID=d8c6f682-8348-491d-9c36-2eb5bdf84b61 click on the tech info. Just going by what i have been told over the years. Good for you that it hasn't happened. Maybe what that has saved you is that you are da'ing the metal down and smoothing that sandblasted profile down where the acid isn't pooling in the bottom.
Re: Body shop guy's, I have a quick question. [Re: sixpackbee] #1017439
06/21/11 08:05 PM
06/21/11 08:05 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
....been doing it this way for 30+ years as well,...it's all in the prep, some guys are all thumbs when it comes to prep, or just plain cut corners,...which comes back to bite them later...
Never had an issue doing a car/bike/truck this way, IMHO acid etched priming is the only way to go for rust prevention/conversion.....epoxy coating is just a "condom" on the car, waiting to slip off
Re: Body shop guy's, I have a quick question. [Re: DAYCLONA] #1017440
06/21/11 08:43 PM
06/21/11 08:43 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
After blasting I either epoxy or use etch primer as soon as possible.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Body shop guy's, I have a quick question. [Re: Silver70] #1017441
06/22/11 06:44 PM
06/22/11 06:44 PM
PNW
Danan Offline
Danan  Offline
PNW
Sandblasted metal begins rusting instantly. I used to use PPG metal cleaner and conditioner, but didn't like the fact that you have to wash the metal with water (the water needs to "sheet" over the metal per PPG). The last couple years I've been using Picklex 20 immediately after blasting. It's $140/gallon through www.autobodystore.com. Not cheap, but what is these days?
It prevents microscopic flash rust just like the PPG products, but you just let it dry instead of washing off with water. I have had zero issues doing it this way, even though I live in Northwest WA state (high humidity...out-of-towners call it 'rain').
There are many ways to skin this cat.
Re: Body shop guy's, I have a quick question. [Re: DaveDudek] #1017442
06/22/11 08:07 PM
06/22/11 08:07 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
Acid, then water with a hose, let it flash rust and then prime it??? NO FREAKING WAY!!!!!!!!!!!!
Just blast it, blow it off clean, make sure there is no rust left, and shoot it with PPG DP40. If there are any smears from handling just clean em up witg grease remover or somthinf similar b4 DP40-
If any spots werent blasted good enough, leave em bare so you can spot em later on...and spot blast them again later and apply D40 over them. Or you can retocuh those spots with hand held tools and abrasives and prime them.
