Acrylic urethane paint -engine compartment. Good idea? #1017094
06/20/11 05:20 PM
06/20/11 05:20 PM
Tri-Cities, Washington
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Body/paint guy wants to paint the jambs, engine compartment, trunk with single stage acrylic urethane instead of base/clear. Says that is more durable and much easier to fix in the event I damage it during reassembly. He said that I won't be able to see/tell any difference.
What your opinions?
Re: Acrylic urethane paint -engine compartment. Good idea? [Re: VITC_GTX] #1017095
06/20/11 06:26 PM
06/20/11 06:26 PM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
I used it in my Dusters Engine compartment and was very happy with it. Gives a nice original type finish.
Re: Acrylic urethane paint -engine compartment. Good idea? [Re: VITC_GTX] #1017096
06/20/11 09:02 PM
06/20/11 09:02 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I could/can't understand the "thinking" in what seems just a "mopar thing" to paint the jambs and engine compartment in a different paint/stage, then the main body in BC/CC,...or painting the car in pcs, then trying to hang and adjust all the panels later,...
...IMHO paint the car/jambs/engine compartment with the same type of paint you intend on painting the car with,....seen too many cars painted the way your painter intends to paint it,....looks like poo, you will see the difference,....your painter sounds lazy, or just cutting corners on paint mat'l ($$$$)....sorry but after painting cars/bikes/boats/trucks/etc for over 30 years I just hate hearing about these half ar$e "paint preparations"
Re: Acrylic urethane paint -engine compartment. Good idea? [Re: DAYCLONA] #1017097
06/21/11 09:01 AM
06/21/11 09:01 AM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
100%!
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: Acrylic urethane paint -engine compartment. Good idea? [Re: MOPARMIKE69] #1017098
06/21/11 11:35 PM
06/21/11 11:35 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Spoke to the body/paint guy and he said that he has no problem using the base/clear for the jambs, engine compartment, etc. He just prefers the other route for durability. He said he is happy to do it and it will be the same price.
Thanks all for the input.
Re: Acrylic urethane paint -engine compartment. Good idea? [Re: VITC_GTX] #1017099
06/22/11 08:41 AM
06/22/11 08:41 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
definitely the way to go. sure, no one will probably see the door jambs but you, but everyone will see the engine bay, and honestly, I think a base/clear will have more pop than a single stage gloss
**Photobucket sucks**
Re: Acrylic urethane paint -engine compartment. Good idea? [Re: 70Cuda383] #1017100
06/22/11 08:33 PM
06/22/11 08:33 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
For how much/little of the engine bay you really see once the motor and all the other crap is in there, I don't think you'd really notice the difference after.
Re: Acrylic urethane paint -engine compartment. Good idea? [Re: DaytonaTurbo] #1017101
06/22/11 11:47 PM
06/22/11 11:47 PM
IN
ahy Offline
ahy  Offline
IN
Mine's single stage in the engine compartment and jambs and base/clear outside. I don't think its a big deal either way and would tend to go with the painter's preference.
Re: Acrylic urethane paint -engine compartment. Good idea? [Re: ahy] #1017102
06/22/11 11:59 PM
06/22/11 11:59 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
How is a single stage "more durable" than BC/CC? Your painter is lazy and just wants to paint it once, not twice.
with the group. Use the same paint on the whole car so it looks right. The colors and finishe will be different.
Re: Acrylic urethane paint -engine compartment. Good idea? [Re: VITC_GTX] #1017103
06/23/11 12:14 AM
06/23/11 12:14 AM
Rome, GA
GTXX Offline
GTXX  Offline
Rome, GA
my brother painted a limelight car using single stage in the trunk and engine compartment and base/clear coat on the body and jambs and the paint colors were not the same even though they were mixed at the same time.
Re: Acrylic urethane paint -engine compartment. Good idea? [Re: VITC_GTX] #1017104
06/23/11 03:52 AM
06/23/11 03:52 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
What your opinions?
The acrylic urethane paint like Emeron is a very tough paint and resistant to most chemicals. It usually flows out nice without orange peel.
I think the clear coat may also be an acrylic urethane, but I think they have some orange peel which may require sanding and buffing?
I would ask the painter why he wants to do it that way?
I would just paint it all in base / clear, but maybe your painter has a good reason?
Re: Acrylic urethane paint -engine compartment. Good idea? [Re: MOPARMIKE69] #1017105
06/23/11 09:31 AM
06/23/11 09:31 AM
Jacksonville Florida
elitecustombody Offline
100%!
x eleventy billion
Re: Acrylic urethane paint -engine compartment. Good idea? [Re: VITC_GTX] #1017106
06/23/11 10:11 AM
06/23/11 10:11 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Well laziness is one thing but saving you money is another. To do all the jams and whatnot in base/clear will take more time not only to paint but also to cut and buff. If you're sparing no expense on a 100 point show car then go for the base/clear but if this is a nice "driver" then I'd go single stage in the jams.
Re: Acrylic urethane paint -engine compartment. Good idea? [Re: Stanton] #1017107
06/23/11 10:32 AM
06/23/11 10:32 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
"Saving you money" is just another way of saying "cutting corners"......seen to many guys after the car is assembled, comment that they should have done it the "right way".....
I believe in doing it the "right way", whether it be restoring the car with a single stage, 2 stage, or custom 4 stage paint system,....you finish the product entirely in the paint of choice,....so that means you budget what it will take to do it correctly,.....when I purchase parts or service for my vehicles I buy based on what I want/need, and the quality of said part or service,....price is the last thing I ask for, if it's beyond my budget, then I wait until the budget is sufficient enough to procure said part(s)/service(s).....I only want to do the car right, and do it once, other projects await,...who wants to revisit the same project because they're unhappy with the results, esp for the guy who drops it off, and picks it up later from the bodyshop?......guess what kind of hash job repaint it's going to get when you tell the painter you don't like it?....seen it too many times......But ya do as ya please.
Re: Acrylic urethane paint -engine compartment. Good idea? [Re: DAYCLONA] #1017108
06/23/11 10:45 AM
06/23/11 10:45 AM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
I can tell you from my experience....my jambs, trunk, engine compartment, passenger compartment, interior firewall and inside the door panels is all single stage Polo Green Metallic. I painted them myself. Its the exact color that my paint guy sprayed the car with in the 2 stage version. You can't tell the difference, its cheaper, its faster and b/c I painted it, my paint guy didnt have to open any doors or climb in somewhere to paint. 12 yrs later the paint is still the same. No expense was spared in the restoring my 69. The inside of the heaterbox is painted, the bolts hidden behind the dash are all grade 8, allen, or stainless. Since its already at your paintshop and he does it for a living go ahead and have him do the 2-stage....but when you are working in the engine bay and you drop a wrench by accident (we all use covers and blankets but sometimes we just wanna "do something quick") it will happen...a crater
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Acrylic urethane paint -engine compartment. Good idea? [Re: 451Mopar] #1017109
06/23/11 01:41 PM
06/23/11 01:41 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
On my '71 Charger, I painted everything with dupont chroma-base/croma-clear 20 years ago, and it has held up really well. I have no problem with the paint in the engine compartment, and I am pretty rough on it. I did'nt cut and buff the engine compartment, trunk, or door jams.
Re: Acrylic urethane paint -engine compartment. Good idea? [Re: VITC_GTX] #1017110
06/23/11 10:32 PM
06/23/11 10:32 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
The question still seems to be unresolved based on the above comments:
1. Which finish is the most durable?
2. Which finish has the best look in an engine bay?
3. Who/how many can see the difference?
4. Does it save the painter or the owner money, time, materials, headache, etc?
5. If the painter is indeed "lazy" he sounds upfront, and thats got to be a big plus.
I would single stage it.
