What could cause this? #1016839
06/20/11 11:52 AM
06/20/11 11:52 AM
Long Island NY
yellow sixpack Offline OP
Long Island NY
My 440 sixpack at start up is running great after 1/2 hr or so of street driving the car starts to run sloppy and stall at every stop sign and red light. The engine has a comp cam# 21 227-4.timing at 10 btdc engine compr 9.7/1. Also when I am trying to start it at this point fuel shoots out of center carb like a fountain....fooled with mixture screws still cant get it to run right. I let the car cool...drive it again starts all over. Also checked timing does not jump. Thanks Rob
If you can't be smart.....don't be stupid!
Re: What could cause this? [Re: yellow sixpack] #1016840
06/20/11 01:00 PM
06/20/11 01:00 PM
Andrewh Offline
Andrewh  Offline
if fuel is shooting out of it, you either have too much pressure(electric fuel pump) or floats are not set right. or some combination of the two.
mixture will not help.
Re: What could cause this? [Re: Andrewh] #1016841
06/20/11 01:27 PM
06/20/11 01:27 PM
Long Island NY
Long Island NY
No electric fuel pump here.
Re: What could cause this? [Re: yellow sixpack] #1016842
06/20/11 01:31 PM
06/20/11 01:31 PM
Andrewh Offline
Andrewh  Offline
could also be heat build up in the carb presurizing it. but I would say that should not last long.
either way, recheck your float levels first.
Re: What could cause this? [Re: Andrewh] #1016843
06/20/11 01:34 PM
06/20/11 01:34 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I would have to agree with the float adjutment. When the engine is cold it needs more fuel as air is more drnse. When it warms up it starts flooding. Hope this makes ence to you. Also how is you choke set?
Re: What could cause this? [Re: Andrewh] #1016844
06/20/11 01:34 PM
06/20/11 01:34 PM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
Pull the needle and seats......clean them. Stuck float.
Re: What could cause this? [Re: yellow sixpack] #1016845
06/20/11 03:02 PM
06/20/11 03:02 PM
ALBERTA CANADA
CUDA8U Offline
CUDA8U  Offline
ALBERTA CANADA
I WOULD SAY ITS A OVER FUEL PROBLEM OR BAD COIL......COULD BE A CHOKE STICKING OR THE FLOAT IN THE CARB AND IF YOUR RUNNING A COIL THEY CAN GO BAD WITH TOO MUCH HEAT.SOMETIMES IT COULD BE A BAD PLUG.
Re: What could cause this? [Re: yellow sixpack] #1016846
06/20/11 03:04 PM
06/20/11 03:04 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
choke may not be coming off
Re: What could cause this? [Re: yellow sixpack] #1016847
06/20/11 04:04 PM
06/20/11 04:04 PM
Minute debris in the gas letting the float leak/bad needle & seat assy/needle & seat or float mechanically hanging up in its range of travel/idle psi on the edge of too high. I'd replace the filter if any doubts about it's veracity and sub in a new needle seat assy & reset the level & go from there. EDIT meant to say minute debris letting the needle/seat leak
Re: What could cause this? [Re: RapidRobert] #1016848
06/20/11 06:14 PM
06/20/11 06:14 PM
Long Island NY
Long Island NY
Thanks...all good stuff for me to ponder anything else would be apprecited...nobody think electrical?
Re: What could cause this? [Re: yellow sixpack] #1016849
06/20/11 08:08 PM
06/20/11 08:08 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
CUDA8U seggested the coil might be getting heat soaked. (?)
Re: What could cause this? [Re: bboogieart] #1016850
06/20/11 08:23 PM
06/20/11 08:23 PM
ALBERTA CANADA
CUDA8U Offline
CUDA8U  Offline
ALBERTA CANADA
READ CAREFULLY.......FUEL OR COIL PROBLEM!!!!
Re: What could cause this? [Re: CUDA8U] #1016851
06/20/11 08:27 PM
06/20/11 08:27 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Yep but the O.P. asked about an electrical source for his problem and I just mentioned what you said. READ CAREFULLY AND TURN OFF THE CAP LOCK PLEASE.
Re: What could cause this? [Re: bboogieart] #1016852
06/20/11 08:48 PM
06/20/11 08:48 PM
organ
maximum entropy Offline
organ
is your heat riser blocked? fuel is most likely boiling in the center carb. try putting race gas in it (much less volatile) and see if it's ok.
Re: What could cause this? [Re: maximum entropy] #1016853
06/20/11 09:02 PM
06/20/11 09:02 PM
Tustin, CA
P
pishta Offline
pishta  Offline
P
Tustin, CA
Friends Nova did this after 5 minutes, bog and die and flame out when starting. it was fuel pressure related off a blue pump. contaminated seat would do the same.
12 Grand Caravan
06 T&C
02 T&C
96 Breeze
65 Barracuda "S"
Re: What could cause this? [Re: Viol8r] #1016854
06/20/11 09:06 PM
06/20/11 09:06 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
I would suspect a needle & seat issue.
Re: What could cause this? [Re: Pacnorthcuda] #1016855
06/20/11 09:13 PM
06/20/11 09:13 PM
Long Island NY
Long Island NY
I did read about the bad coil just wondering about the orange box heating up and shutting down should have been more specific I guess.
Re: What could cause this? [Re: yellow sixpack] #1016856
06/20/11 09:35 PM
06/20/11 09:35 PM
You say this: "Also when I am trying to start it at this point fuel shoots out of center carb like a fountain."
And you are asking if it could be electrical? I suppose if you were also having backfire issues (as in a distributor installed 180 degrees off, or mixed up plug wires) but absent that condition your problem most definately is fuel related.
Re: What could cause this? [Re: Pacnorthcuda] #1016857
06/21/11 08:58 AM
06/21/11 08:58 AM
Long Island NY
Long Island NY
It did backfire once.
Re: What could cause this? [Re: yellow sixpack] #1016858
06/21/11 11:24 AM
06/21/11 11:24 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Backfire on the trio of Holley 2300's isn't a good thing, you may have ruptured the power valve in the center carb,....I would start with establishing that all 3 carbs have a properly set fuel level, just ebbing out the brass sight hole plug is your minimum setting on the end carbs, I like to use clear Holley sight plugs to set all 3, center carb I usually set at halfway in the "window".......to check to see if your Power Valve is toast without pulling it and performing a vac check, you can turn the air/fuel idle screws located on each side of the metering block of the center carb all the way in, if it stalls your power valve is good, it it's still idleing, it's junk....
