Correct Brake Booster?? #1016280
06/19/11 03:05 PM
06/19/11 03:05 PM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
I was wondering if I have the correct brake booster ? I have a 3580162 installed that i sent in and had Dewey rebuild. Can anyone tell me if this is the correct unit for a 73 ebody built in Oct 72?
Thanks Dennis
1966 Charger 383 4 speed (Black with Red interior)
1973 Cuda 340 4 speed (Lemontwist)
1972 Corvette
Re: Correct Brake Booster?? [Re: 19cuda73] #1016281
06/20/11 05:40 PM
06/20/11 05:40 PM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
I called and left a message with Dewey. One of the other reasons I am asking this question is that when I was putting the brake linkage on the brake pedal assembly it did not operate smooth. Chattering and Binding near the top. I also am curious as to are both pedals supposed to be the same height and even?
1972 Corvette
Re: Correct Brake Booster?? [Re: 19cuda73] #1016282
06/20/11 08:11 PM
06/20/11 08:11 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
The 73 parts manual says it should be a 3580225.
I just went out and looked at my origonal booster. The tag is hard to read but it looks like it says 3580152.
So I'd say the one you have is correct since both our cars were built in the Sept/Oct time frame.
Re: Correct Brake Booster?? [Re: burdar] #1016283
06/21/11 09:14 AM
06/21/11 09:14 AM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
Thanks Darren I really appreciate your help in checking this out for me. I think your right we do have the right ones and here is a picture of mine with the part number.
1972 Corvette
Re: Correct Brake Booster?? [Re: 19cuda73] #1016284
06/21/11 10:54 AM
06/21/11 10:54 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
That doesn't look like the booster I have. Can you post a picture of the entire unit?
My booster is banded. It has a tag on it where the band is bolted together. That's where I got the numbers.
I've see some 73/74 cars with black boosters. The ones I've seen have been crimped together like yours. I don't know why some got the banded booster and others got a black crimped booster. Disc brakes were standard by 73 I think...so that's not it.
I've got a picture of another 73 Cuda build at the same time yours was. It has a zinc dichromate plated booster on it.(banded style)
Re: Correct Brake Booster?? [Re: burdar] #1016285
06/21/11 11:26 AM
06/21/11 11:26 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Here's my original booster. The plastic vacuum fitting isn't correct. That's the one Dewey installed. I have the correct one and will be reinstalling it.
Re: Correct Brake Booster?? [Re: burdar] #1016286
06/21/11 12:22 PM
06/21/11 12:22 PM
owensboro, ky
rallye73 Offline
rallye73  Offline
owensboro, ky
I'll have to check the numbers off my booster also. I'm pretty sure it is original to the car. My booster was black. I've never seen a 73 that was gold zinc. I've owned two 73 Chargers and the boosters in both of them were black too.
Re: Correct Brake Booster?? [Re: rallye73] #1016287
06/21/11 12:30 PM
06/21/11 12:30 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
73 Cuda built in October 72
73 Challenger built February 73
Re: Correct Brake Booster?? [Re: burdar] #1016288
06/21/11 02:13 PM
06/21/11 02:13 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
Mine was a scheduled Nov 72 build and the booster looks like Darren's except not nearly as shiny (insert jealous green guy here)
Craig
Re: Correct Brake Booster?? [Re: 19cuda73] #1016289
06/21/11 03:35 PM
06/21/11 03:35 PM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
Here is a shot of it installed but now it is off the car for major touchup. I have some pitting and it is easier to fix on the bench. I like the style of your unit better..
1972 Corvette
Re: Correct Brake Booster?? [Re: 19cuda73] #1016290
06/21/11 03:36 PM
06/21/11 03:36 PM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
pitting repair needed
1972 Corvette
Re: Correct Brake Booster?? [Re: 19cuda73] #1016291
06/21/11 08:35 PM
06/21/11 08:35 PM
Indiana, Just Off I-70
BradD Offline
BradD  Offline
Dennis, is that a Dewey paint job? I've seen his ads for years but never had a booster rebuilt by him. Apparently he only cares about function and not quality or correctness for the application.
Brad
Check out the Dorn's 69 Barracuda "Switchblade" in the Nov.2010 MCG
Check out the Dorn's refurbished 36 Ford in the Feb.2011 Street Rodder
Re: Correct Brake Booster?? [Re: BradD] #1016292
06/22/11 04:08 AM
06/22/11 04:08 AM
Maple Valley, WA
70mopes Offline
70mopes  Offline
Maple Valley, WA
'cuda - Late Feb '73 build. Original power booster
Re: Correct Brake Booster?? [Re: BradD] #1016293
06/22/11 12:52 PM
06/22/11 12:52 PM
Washington
19cuda73 Offline OP
19cuda73  Offline OP
Washington
Yes this is. My suggestion after speaking with Dewey is to make sure the case exterior looks good prior sending it to him for rebuild. He currently is backlogged over a 100 units. Business is good.. I am hand sanding mine down for a fresh recoat.
1972 Corvette
Re: Correct Brake Booster?? [Re: 19cuda73] #1016294
06/22/11 01:02 PM
06/22/11 01:02 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
I've had several 73 B's and E's. Most were gold. Some were black. All my 74's were black. I though maybe the black 73's were factory replacements but maybe not.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Correct Brake Booster?? [Re: moparmarks] #1016295
06/22/11 01:07 PM
06/22/11 01:07 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Now here is the next question. If the car came with a black booster, was the master cylinder painted black as well just like in 1970?
