Correct Brake Booster??
#1016280
06/19/11 03:05 PM
06/19/11 03:05 PM
Posts: 1,300 Washington
19cuda73
Washington
I was wondering if I have the correct brake booster ? I have a 3580162 installed that i sent in and had Dewey rebuild. Can anyone tell me if this is the correct unit for a 73 ebody built in Oct 72?
Thanks Dennis
1966 Charger 383 4 speed (Black with Red interior) 1973 Cuda 340 4 speed (Lemontwist) 1972 Corvette
Re: Correct Brake Booster??
[Re: 19cuda73]
#1016281
06/20/11 05:40 PM
06/20/11 05:40 PM
19cuda73
Washington
I called and left a message with Dewey. One of the other reasons I am asking this question is that when I was putting the brake linkage on the brake pedal assembly it did not operate smooth. Chattering and Binding near the top. I also am curious as to are both pedals supposed to be the same height and even?
[Re: burdar]
#1016283
06/21/11 09:14 AM
06/21/11 09:14 AM
19cuda73
Washington
Thanks Darren I really appreciate your help in checking this out for me. I think your right we do have the right ones and here is a picture of mine with the part number.
[Re: 19cuda73]
#1016284
06/21/11 10:54 AM
06/21/11 10:54 AM
Posts: 7,369 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
That doesn't look like the booster I have. Can you post a picture of the entire unit?
My booster is banded. It has a tag on it where the band is bolted together. That's where I got the numbers.
I've see some 73/74 cars with black boosters. The ones I've seen have been crimped together like yours. I don't know why some got the banded booster and others got a black crimped booster. Disc brakes were standard by 73 I think...so that's not it.
I've got a picture of another 73 Cuda build at the same time yours was. It has a zinc dichromate plated booster on it.(banded style)
[Re: burdar]
#1016288
06/21/11 02:13 PM
06/21/11 02:13 PM
Posts: 1,822 Colorado
denfireguy
Colorado
73 Cuda built in October 72
73 Challenger built February 73
Mine was a scheduled Nov 72 build and the booster looks like Darren's except not nearly as shiny (insert jealous green guy here) Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: 19cuda73]
#1016289
06/21/11 03:35 PM
06/21/11 03:35 PM
19cuda73
Washington
Here is a shot of it installed but now it is off the car for major touchup. I have some pitting and it is easier to fix on the bench. I like the style of your unit better..
[Re: 19cuda73]
#1016291
06/21/11 08:35 PM
06/21/11 08:35 PM
Posts: 543 Indiana, Just Off I-70
BradD
Dennis, is that a Dewey paint job? I've seen his ads for years but never had a booster rebuilt by him. Apparently he only cares about function and not quality or correctness for the application. Brad
Check out the Dorn's 69 Barracuda "Switchblade" in the Nov.2010 MCG Check out the Dorn's refurbished 36 Ford in the Feb.2011 Street Rodder
[Re: BradD]
#1016293
06/22/11 12:52 PM
06/22/11 12:52 PM
19cuda73
Washington
Yes this is. My suggestion after speaking with Dewey is to make sure the case exterior looks good prior sending it to him for rebuild. He currently is backlogged over a 100 units. Business is good.. I am hand sanding mine down for a fresh recoat.
