brake pedal wont pump up????
#1016109
06/19/11 03:49 AM
06/19/11 03:49 AM
Posts: 8,849 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
its not just soggy i can shove the pedal to the floor with my hand iv swaped the rear over to disc brakes,and added a alum master cyl from a 85 cordova when pedal is held to the floor i cam crack a bleeder screw and nothen but a clean stream of brake fluid no air will shoot6-10 inches out the end of the bleeder have bled the mc before hooking lines up to it i have plenty of fluid coming out of both bleederd when crack one of them open and no leaks what the heck???
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
Re: brake pedal wont pump up????
[Re: toplescuda]
#1016110
06/19/11 04:36 AM
06/19/11 04:36 AM
Posts: 13 NY
KillerB
NY
Sounds like you gotta leak, internal or external, master cylinder might be bleeding down internally.
[Re: toplescuda]
#1016111
06/19/11 10:08 AM
06/19/11 10:08 AM
RapidRobert
At your parts house in the "Edelman" brass fittings cabinet get a pair of inverted flare straight thread plugs to cap the M/C ports. On the end they will have a recessed flare a mirror image of the brass seat(s)in the M/C. Cap the M/C & if it's good (& bled out) the pedal w b rock hard w virtually no travel. (1)Jump on the pedal hard and (2) put steady light pressure on it, these 2 tests will tell you if it is the prob or look further downstream. Or if not wanting to grab some fittings rebleed the M/C as it sounds like it's bad or there's air in it
[Re: Andrewh]
#1016113
06/19/11 01:03 PM
06/19/11 01:03 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
the caliper is a metric for a s10 but the bleeder screw is at the very top would of thought by now the mc would of pushed the air to the lines as iv went threw a full bottle of fluid its got a slight pedal but i can still shove to floor with my hand i also removed the power brake booster to make room for the hemi
[Re: toplescuda]
#1016114
06/19/11 01:22 PM
06/19/11 01:22 PM
RapidRobert
dont know if this is one of these cases but I'd heard of some calipers needing to b tilted & the hole at the top of the bore needs 2 b at 12 o'clock where the bottom of the angled passage meets it as opposed to just the bleeder screw being at 12 o'clock at the top of the passage.
[Re: RapidRobert]
#1016115
06/19/11 01:32 PM
06/19/11 01:32 PM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
Did you bleed the fronts also?If you changed master you need to bleed them also.Rocky
Chrysler Firepower
[Re: therocks]
#1016116
06/19/11 01:54 PM
06/19/11 01:54 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
havent bleed the front yet got to go get a new bottle of fluid
[Re: toplescuda]
#1016117
06/20/11 10:33 AM
06/20/11 10:33 AM
toplescuda
I Whine
I Whine
poplar bluff mo.
well got to notice that the colar that goes around the line on the caliper is hitting the sway bar mount on the leaf spring so i get to pull it off and clearance it
