Help me identify a master cylinder please. #1015771
06/18/11 07:23 PM
06/18/11 07:23 PM
Rancho Cordova, California (Sa...
hemi71x Offline OP
hemi71x  Offline OP
I got this master cylinder with some disc brake parts that i purchased.
I don't know if it's for a disc - drum, application, or for a drum - drum application.
Also need to know if it's for a power brake application, or a regular manual brake application.
A casting number on the bottom is 29861 which i'm pretty sure is a Raybestos number, and that seems to show up as MC36221, but i can't find out what it's used on.
Can anyone reference it for me?
Thank's in advance.
Jim V.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Help me identify a master cylinder please. [Re: hemi71x] #1015772
06/18/11 09:51 PM
06/18/11 09:51 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
looks like a drum/drum. it can be used with drum/drum power brakes.
Re: Help me identify a master cylinder please. [Re: hemi71x] #1015773
06/19/11 05:33 PM
06/19/11 05:33 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
In the link below, click on INFO to see the applications.
http://www.rockauto.com/catalog/raframec...-MC36221-230437
Re: Help me identify a master cylinder please. [Re: John_Kunkel] #1015774
05/14/13 01:25 PM
05/14/13 01:25 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
Thank you.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: Help me identify a master cylinder please. [Re: hemi71x] #1015775
05/15/13 11:14 AM
05/15/13 11:14 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Jim , when you pop the cover are the res. the same size or different ?
Re: Help me identify a master cylinder please. [Re: hemi71x] #1015776
05/15/13 11:29 AM
05/15/13 11:29 AM
Look inside the piston recess in the back & if it's smooth like a tapered sewing thimble then it is a PB app & cannot be used on manual brakes as there's no groove to lock in the neoprene retainer. If it has a wide/shallow circular recessed depression about halfway down then it is a manual brake app as that is the groove that the retainer locks into but can also be used in a PB app since power brakes dont use the neoprene retainer on the end of the pushrod (assuming the bore dia is or close to what you need for your system which for the most part depends on the caliper type/bore dia/drum size/wheel cyl dia/pedal effort/feel desired etc)
