trailer/towing questions #1015112
06/17/11 02:36 PM
06/17/11 02:36 PM
Kenosha, Wi
GOLDMYN Offline OP
GOLDMYN  Offline OP
Kenosha, Wi
Hi, Will a 16' open trailer be long enough to trailer a 68-70 b body? any pix?...thanks
Semper Fi
Re: trailer/towing questions [Re: GOLDMYN] #1015113
06/17/11 03:14 PM
06/17/11 03:14 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Been done many times. Remember to put a little more weight on the tongue than the rear. Too much tail weight results in fishtailing. I also recommend using a lad equalizing hitch. Gets part of the weight transferred to the to vehicle.
Re: trailer/towing questions [Re: MoparforLife] #1015114
06/17/11 04:02 PM
06/17/11 04:02 PM
Kenosha, Wi
GOLDMYN Offline OP
GOLDMYN  Offline OP
Kenosha, Wi
yeah, I've trailered w/18' open and I have the weight system, I just wasn't sure about the 16'lenght, The problem maybe in that the seller is including the dovetail in lenght....thanks
Re: trailer/towing questions [Re: GOLDMYN] #1015115
06/18/11 02:12 AM
06/18/11 02:12 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Yes, it will work OK. I only had a 16 ft trailer until a few years ago.
I have towed mostly 68-70 B bodies and a couple of C bodies.(short distance on the C body) !
You should have brakes on the trailer, as a 4k lb B body will need them !.
Re: trailer/towing questions [Re: sthemi] #1015116
06/18/11 02:26 AM
06/18/11 02:26 AM
Nampa, ID
None2Slow Offline
None2Slow  Offline
Nampa, ID
Whats the vehicle doing the towing? I towed a 2004 Ford F250 4x4 Superduty long bed diesel truck on my 16' trailer, but the tow vehicle was a F350 Superduty longbed. towed very smooth.
Re: trailer/towing questions [Re: None2Slow] #1015117
06/18/11 10:51 AM
06/18/11 10:51 AM
Norwich CT USA
moparts Offline
moparts  Offline
Norwich CT USA
A 16' foot open can hold a full size pickup truck no problem
Reg cab 8 foot bed, so yes on any B Body or even a C Body with a little over hang,
Tom ,
2011 Ram 3500 C&C Diesel
2009 Challenger R/T
1971 Challenger Conv. 511/4 speed
1970 Challenger R/T 503/727
Re: trailer/towing questions [Re: moparts] #1015118
06/18/11 11:03 AM
06/18/11 11:03 AM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
I had the same results as above, but I bet any overhang is probably illegal in most states?? Putting brakes on my 16' was the best move I ever made!
Re: trailer/towing questions [Re: Lee446] #1015119
06/18/11 04:58 PM
06/18/11 04:58 PM
Kenosha, Wi
GOLDMYN Offline OP
GOLDMYN  Offline OP
Kenosha, Wi
Thanks for the comments
Semper Fi
Re: trailer/towing questions [Re: GOLDMYN] #1015120
06/19/11 12:08 AM
06/19/11 12:08 AM
Newburgh, NY
Old_Moparz Online content
Old_Moparz  Online Content
Newburgh, NY
My trailer is a 16' with a dove tail on it & I've had several B-Bodies on it as well as a F-150 without any troubles.
Re: trailer/towing questions [Re: Old_Moparz] #1015121
06/19/11 01:09 PM
06/19/11 01:09 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I towed a 73 charger on my 16 foot open just fine. The rear bumper of the car hung off just past the end of the trailer.
Re: trailer/towing questions [Re: mopars4ever] #1015122
06/19/11 03:06 PM
06/19/11 03:06 PM
Nampa, ID
None2Slow Offline
None2Slow  Offline
Nampa, ID
Most places allow up to 36" to hang past, at which point you need to mark it with a flag or lights. I pulled a 67 Galaxie Convert on a 16' trailer with less overhang so I wouldn't think your car would be any different. What is the vehicle thats being used to tow with? A car of that size would be a tough ride with a 1/2 ton.
Re: trailer/towing questions [Re: None2Slow] #1015123
06/19/11 04:19 PM
06/19/11 04:19 PM
Kenosha, Wi
GOLDMYN Offline OP
GOLDMYN  Offline OP
Kenosha, Wi
I'm towing a 67 coronet with a 2002 Chevy 1500 Z71
Semper Fi
Re: trailer/towing questions [Re: GOLDMYN] #1015124
06/19/11 04:29 PM
06/19/11 04:29 PM
Western NC
68Bullit Offline
68Bullit  Offline
Western NC
I plan on using my 16 footer tandem (16' dovetail included) to haul my 68 B-Body some this year, and in the years to come, and not foreseeing any problems with it......and not to hi-jack the thread, but what is THE preferred style of straps to tie down with that are the quickest, easiest, and yet still highly trusted????
Re: trailer/towing questions [Re: 68Bullit] #1015125
06/19/11 10:15 PM
06/19/11 10:15 PM
Nampa, ID
None2Slow Offline
None2Slow  Offline
Nampa, ID
I've used the big straps you can get at home depot.They run about $15 each and are rated for 10,000lbs. I use 2 on the front and 2 on the rear, plus the winch cable. This, along with the car in gear and the parking brake applied. If that don't hold it, your doing something wrong and your not on a paved road anymore. This has held with the afformentioned 8,500lb F250 4x4 as well as a Lincoln Towncar down to my 63 Valiant convert with no motor or trans.
Re: trailer/towing questions [Re: None2Slow] #1015126
06/20/11 12:00 PM
06/20/11 12:00 PM
Western NC
68Bullit Offline
68Bullit  Offline
Western NC
I ask because I've noticed the wheel mounted straps. They appear as though to cover the wheels/tires with a longer strap that runs to an anchoring point on the trailer. I like how they look easy to use but I wonder if they are actually any good, and safe to use
Re: trailer/towing questions [Re: 68Bullit] #1015127
06/20/11 12:20 PM
06/20/11 12:20 PM
Cruising!
Q
QuickDodge Offline
QuickDodge  Offline
Q
Cruising!
When it comes to holding a car on a trailer, consider the force exerted on the straps or chain if an accident occurs when towing. I'm NOT an engineer, but would guess a B-body could easily break a 10,000 lb strap in a high speed crash.
I know a guy who was towing a camaro on a trailer. He rear-ended an 18 wheeler. His tie down straps broke and the Camaro smashed into the rear of his pick-up cab. It nearly killed him! After hearing his story, I bought some U.S. made, DOT rated tie downs.
Re: trailer/towing questions [Re: 68Bullit] #1015128
06/20/11 12:21 PM
06/20/11 12:21 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Those u hauls with the front straps work well, I even put a 70 charger on trailer backwards(no eng or trans) and the straps secured the 275/60 m/t drag radials pretty well. I always add an extra strap or two on those deals anyway.
Re: trailer/towing questions [Re: 68Bullit] #1015129
06/20/11 02:13 PM
06/20/11 02:13 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I use chain and aircraft tiedowns like the one in the picture.Never had them break,and you can get them on Ebag.I installed eye bolts in the rear frame and on the front bumper brackets,tiedown hook goes to the eyes,chain is attached to the trailer.
Nautilus Racing-
Re: trailer/towing questions [Re: Chris2581] #1015130
06/21/11 01:36 AM
06/21/11 01:36 AM
Nampa, ID
None2Slow Offline
None2Slow  Offline
Nampa, ID
When I tow for a long distance, I use chain and binders. Just like you see them use on the tractors that are on low boy trailers running down the interstate. But for around town, I use a total of 4 straps, 2 in front and 2 in back. These are 10,000lbs each. If you rearend an 18 wheeler hard enough to knock the car off the trailer, my guess is you are going to have alot more things to worry about than the car comming in from behind. Ohh and I drive 18 wheelers for a living.
