Shielding gas comparison #101500
08/08/08 02:00 PM
08/08/08 02:00 PM
FarDarter Offline OP
I've been doing bodywork on my Dart and MIG welding in a bunch of patches. I'm a new welder and just got my first refill of gas. The stuff I've been using was pure argon and I refilled with C25. The new stuff seems to be working a lot better for me. I did most of a patch last night and didn't have any burn through incidents at all. Usually I'll get at least one on a patch. I'm using .023 wire.
Does anyone have a thought on what gas is best for doing sheetmetal work? My experience is very limited and I'm curious about some of you seasoned experts.
Re: Shielding gas comparison [Re: FarDarter] #101501
08/08/08 02:20 PM
08/08/08 02:20 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
100% Ar is used for aluminum work in most cases. You really don't want to use it when migging mild steel, especially thin panels, IMHO.
Ar usually creates a deep, narrow penetrating weld. Not what you need when working on sheetmetal. The C25 mix is better as it will allow you good arc quality, easier puddle control, less spatter.
Re: Shielding gas comparison [Re: RobX4406] #101502
08/08/08 03:14 PM
08/08/08 03:14 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
An argon mix works best with thin sheet metal (Mig Mix Gold is one of the trade names I've seen).
Re: Shielding gas comparison [Re: torkrules] #101503
08/08/08 07:38 PM
08/08/08 07:38 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
yep you want a 75% argon 25% CO2 mix for mild steel
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Shielding gas comparison [Re: dusturbd340W5] #101504
08/08/08 08:49 PM
08/08/08 08:49 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
, been using it for 20 years
