Short-block Stuck! Help! #1014554
06/16/11 06:12 PM
06/16/11 06:12 PM
Wisconsin
Stewpar Offline OP
Stewpar  Offline OP
Wisconsin
I can't get my short-block to turn over. What's the best product to pour down the cylinders to try and "Free" them up? Any other ideas? Thanks in advance..............
Admiration For Multiple Carburetor Vehicles...
Re: Short-block Stuck! Help! [Re: Stewpar] #1014555
06/17/11 09:43 AM
06/17/11 09:43 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Is it in or out of the car ? heads on or off ? I had good results with PB blaster and a brass hammer on a 400 without heads .
Re: Short-block Stuck! Help! [Re: JohnRR] #1014556
06/17/11 09:55 AM
06/17/11 09:55 AM
Wisconsin
Stewpar Offline OP
Stewpar  Offline OP
Wisconsin
Out of the car on an engine dolly with the heads off.
Re: Short-block Stuck! Help! [Re: Stewpar] #1014557
06/17/11 10:00 AM
06/17/11 10:00 AM
JohnRR Offline
JohnRR  Offline
Are you trying to save the pistons ?
First I took a wire wheel on a drill and cleaned the cylinders above the pistons as best I could , then I tipped it so one cylinder bank was up and sprayed in the PB and let it sit for a day or 2 , did the same thing to the other side. Then I hit the tops of the pistons then worked the crank back and forth with breaker bar and a cheater pipe ( i have a socket that goes over the crank snout after you pull the balancer) , hit pistons again , sprayed in more PB , rinse and repeat, got it to eventually turn completely over after about a 1/2 hour of this .
Re: Short-block Stuck! Help! [Re: JohnRR] #1014558
06/17/11 11:07 AM
06/17/11 11:07 AM
Wisconsin
Stewpar Offline OP
Stewpar  Offline OP
Wisconsin
Yes, motor was completely rebuilt and never fired about 10-15 years ago. It turned over last summer, but sat W/O the heads on the motor all winter long. I will give your idea a shot and see what happens, thanks!
Re: Short-block Stuck! Help! [Re: Stewpar] #1014559
06/17/11 11:30 AM
06/17/11 11:30 AM
South Dakota
uponblocks Offline
uponblocks  Offline
South Dakota
I know it is dangerous but gasoline has worked for me with a 360 short block..
Re: Short-block Stuck! Help! [Re: uponblocks] #1014560
06/17/11 12:47 PM
06/17/11 12:47 PM
NY NY
3
340duster340 Offline
NY NY
brake fluid...just clean it down when your done .... i dont even use wd40 or pb blaster on anything any more...just brake fluid.
unless there is paint or surface finish you don't want to screw up, brake fluid will free up just about anything.
Re: Short-block Stuck! Help! [Re: Stewpar] #1014561
06/17/11 01:49 PM
06/17/11 01:49 PM
JohnRR Offline
JohnRR  Offline
In this case don't use my method , especially hitting the pistons, instead of PB blaster use some kerosene , get oil in it after you get it unstuck. Also make sure it's not dry bearings holding it stuck
Re: Short-block Stuck! Help! [Re: JohnRR] #1014562
06/17/11 01:53 PM
06/17/11 01:53 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Diesel/fuel oil also works very well. Lotsa detergent and the oil frees up the crud.
Re: Short-block Stuck! Help! [Re: moparpollack] #1014563
06/17/11 03:12 PM
06/17/11 03:12 PM
Arlington, Texas
bobby66 Online content
bobby66  Online Content
Arlington, Texas
Miracle Mystery Oil and Diet Coke has always worked for me.
Re: Short-block Stuck! Help! [Re: bobby66] #1014564
06/19/11 08:46 PM
06/19/11 08:46 PM
Wisconsin
Stewpar Offline OP
Stewpar  Offline OP
Wisconsin
Alright, I used a dentist tool to scrape all around the piston edge to get the gunk out. Then I sprayed Kroil all around over the last two days. Used a short 2x4 and tapped each piston a few times throughout both days. Put a 4 ft. pipe over my breaker bar, and she still won't budge???? What am I missing here............
Re: Short-block Stuck! Help! [Re: Stewpar] #1014565
06/19/11 08:48 PM
06/19/11 08:48 PM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
Rubbing alcohol will also work. Sounds crazy but sometimes.
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
Re: Short-block Stuck! Help! [Re: kilroy] #1014566
06/19/11 09:45 PM
06/19/11 09:45 PM
Castlegar, BC, Canada
That AMC Guy Offline
I use a concoction of diesel, ATF & WD40. I sometimes wonder myself if the WD40 does anything, but I've unstuck several engines now using my goop. I've always had to do this with heads ON, so hose the cylinders down with WD40. Next, equal parts diesel and ATF into each hole.
Usually takes 3 days to work it's magic. If it's stuck rings, it'll work. If the cylinder is rusty, it's rebuild time.
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
Re: Short-block Stuck! Help! [Re: That AMC Guy] #1014567
06/19/11 10:50 PM
06/19/11 10:50 PM
Wisconsin
Stewpar Offline OP
Stewpar  Offline OP
Wisconsin
Engine was re-built back in the mid 90's and sat. When I removed the heads, there was some rust dust that got into the cylinders upon removal. The cylinder walls are excellent?
Re: Short-block Stuck! Help! [Re: Stewpar] #1014568
06/20/11 09:46 AM
06/20/11 09:46 AM
JohnRR Offline
JohnRR  Offline
Did you pull any of the rod or main caps? Depending on the type of assembly lube used it could have solidified, had that happen with engine oil believe it or not.
I haven't had the luck others claim using kroil.
