8.75 axle seals #1013312
06/14/11 04:03 PM
06/14/11 04:03 PM
mi
E
ERAT340 Offline OP
ERAT340  Offline OP
E
mi
Hi. Im replacing axle bearings in my 8.75 does anyone know which direction the outer seals face in the adjuster/retainer?
Re: 8.75 axle seals [Re: ERAT340] #1013313
06/14/11 04:07 PM
06/14/11 04:07 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
The undercut should face the inside (lip points in)
Re: 8.75 axle seals [Re: roadhazard] #1013314
06/14/11 04:27 PM
06/14/11 04:27 PM
scratchnfotraction Offline
seal spring to inside,pack the back side of the seal with some greese to help keep the spring from poping off whale you them into place.
sink them to the lip of the axle tube so they are in far enuff.
good luck
Re: 8.75 axle seals [Re: ERAT340] #1013315
06/14/11 04:50 PM
06/14/11 04:50 PM
mi
E
ERAT340 Offline OP
ERAT340  Offline OP
E
mi
Thank you much guys!
Re: 8.75 axle seals [Re: scratchnfotraction] #1013316
06/14/11 06:36 PM
06/14/11 06:36 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
good luck
Unless you are replacing the bearings the outer seals in the retainers are rarely messed with, they are mostly a dust and seal, keeping brake and road dust out of the seal are. worry mostly about the inner seals in the axle tube. When installing them making sure that they are in square install into the tube to the little step lip in the tube. They will stop when in far enough.
Make sure that you clean, inspect and repack the bearings with a good grease before reassembly, this is the only lubrication that they should get. They are not lubricated from the rear end lube.
Re: 8.75 axle seals [Re: MoparforLife] #1013317
06/14/11 06:48 PM
06/14/11 06:48 PM
OH! I was thinking the axle seals
you mean the thin dust seals on the retainer and backing plate...DOOHH!!!
should have paid more attention to what i was reading before typeing
Re: 8.75 axle seals [Re: scratchnfotraction] #1013318
06/14/11 08:00 PM
06/14/11 08:00 PM
Upper Midwest
Upper Midwest
I should have added to my above post is that if he is leaking grease/oil into the brake area it is due to inner seal leakage - not out seal leakage. The lube should not be getting from the rear to the bearing area.
Re: 8.75 axle seals [Re: ERAT340] #1013319
06/14/11 09:57 PM
06/14/11 09:57 PM
mi
E
ERAT340 Offline OP
ERAT340  Offline OP
E
mi
Actually, Im replacing my E body rear with a B body axles and housing I picked up on a farm.I had to cut and press out old damaged Green bearings, pressed in new taper units with used retainers. I packed with some high dollar bearing grease.Job went very well, it helps to have a massive press at work!
Re: 8.75 axle seals [Re: ERAT340] #1013320
06/14/11 10:17 PM
06/14/11 10:17 PM
Upper Midwest
Upper Midwest
